Author Topic: My First Lisp...  (Read 4292 times)
hudster
My First Lisp...
« on: February 16, 2004, 05:16:24 AM »
Hurrah.
I've just written my first lisp and It works, it's very basic but it's a beginning.
All it does is sets a few variables I like in AutoCAD, but up until now i've used scripts to set them, now I have a lisp that does it when I open a drawing.
(defun c:var ()
(command "_BLIPMODE" "off")
(command "_CELTSCALE" "1")
(command "_CMDDIA" "1")
(command "_COLOR" "bylayer")
(command "_DIMASSOC" "1")
(command "_DIMSHO" "1")
(command "_DRAGMODE" "AUTO")
(command "_FACETRES" "2" )
(command "_FILEDIA" "1")
(princ))
SMadsen
My First Lisp...
« Reply #1 on: February 16, 2004, 07:13:53 AM »
Excellent, Hudster. Keep it up!
If you wanna give yourself another assignment, you might want to look into other ways to write the same stuff. For example:
(defun c:varNext ()
  (setvar "BLIPMODE" 0)
  (setvar "CELTSCALE" 1.0)
  (setvar "CMDDIA" 1)
  (setvar "CECOLOR" "BYLAYER")
  (setvar "DIMASSOC" 1)
  (setvar "DIMSHO" 1)
  (setvar "DRAGMODE" 1)
  (setvar "FACETRES" 2.0)
  (setvar "FILEDIA" 1)
  (princ))
.. and don't stop until you can write it like this:
(defun c:varFinal ()
  (mapcar (function (lambda (var) (setvar (car var) (cdr var))))
          '(("BLIPMODE" . 0)("CELTSCALE" . 1.0)("CMDDIA" . 1)
            ("CECOLOR" . "BYLAYER")("DIMASSOC" . 1)("DIMSHO" . 1)
            ("DRAGMODE" . 1)("FACETRES" . 2.0)("FILEDIA" . 1)
  (princ))
hudster
My First Lisp...
« Reply #2 on: February 16, 2004, 08:46:49 AM »
I've not got to grips with why lines are indented.  is there a reason for this?
My First Lisp...
« Reply #3 on: February 16, 2004, 09:09:52 AM »
"improves text appearance and readability"
CADaver
My First Lisp...
« Reply #4 on: February 16, 2004, 09:10:12 AM »
Quote from: Hudster
Readability
Each step in is indented in a liitle more than the previous step so you can "see" the function's steps.
My First Lisp...
« Reply #5 on: February 16, 2004, 09:12:34 AM »
My First Lisp...
« Reply #6 on: February 16, 2004, 12:34:57 PM »
The VLIDE will format for you.
Pull down menu 'Tools'
  Select "Format Code in Editor"
Your code formatted.
(defun c:var ()
  (command "_FACETRES" "2")
Also when posting code on the forum use the CODE button as shown above.
Click the button, paste your code, click the CODE button again.
This will display the formatting and will keep the parenthesizes
from being miss interpreted buy the forum formatter.
Welcome aboard. :)
daron
My First Lisp...
« Reply #7 on: February 16, 2004, 12:41:47 PM »
Like that?^
Also another reason for using the code tag is the sometimes you have to use the number 8 in your code and put a ) after the 8 and the code ends up looking something like
(getfiled "etc" "etc" "etc" 8) <that and you end up with smilies all embedded throughout your code.
My First Lisp...
« Reply #8 on: February 16, 2004, 01:34:10 PM »
Formatting is important for lispers cause it helps us see what function we are in the middle of. Because there is a open paren and a close paren for each AutoLisp function, you indent when you nest other functions in functions. For instance:
(one
    (two
      (three)
     );_ end two
   );_ end one
Nesting occures when an AutoLisp function takes an argument you can then use another function for that argument. -i.e. (+ (* 2 1) 5)
Although you see it as weird now, when you start getting more involved in more complex lisps you will see the benifit of indentation.
