I do the same. The main tool palettes are located on a server drive, with the folder permissions set so that only a SELECT few have write access to the palettes folder.
An easy way to know if the palettes are locked, is to look in the bottom left of the tool palettes window. If there is a little padlock symbol, then the palette is locked.
