Author Topic: Tool Palettes Settings  (Read 4876 times)
One Shot
« on: February 28, 2006, 11:37:46 AM »
Is there a setting that you can use to lock the Tool Palettes to not allow users to edit them?
Thank you,
Brad
jonesy
  • SuperMod
Re: Tool Palettes Settings
« Reply #1 on: February 28, 2006, 12:15:38 PM »
Our tool palettes are located on a secure are on the server. Only 2 people have write access to this area
One Shot
« Reply #2 on: February 28, 2006, 01:02:04 PM »
Would that cause me not to be able to create a new Tool Palette and add new tools to it?
Thank you,
Brad
jonesy
  • SuperMod
« Reply #3 on: February 28, 2006, 04:42:54 PM »
I hope so! Thats why I set ours up that way.
The user could change the search path for the tool pallettes, but the original ones should (I hope) stay in tact.
Glenn R
« Reply #4 on: March 01, 2006, 06:18:23 AM »
I do the same. The main tool palettes are located on a server drive, with the folder permissions set so that only a SELECT few have write access to the palettes folder.
An easy way to know if the palettes are locked, is to look in the bottom left of the tool palettes window. If there is a little padlock symbol, then the palette is locked.
