Author Topic: SPLINE convert ?  (Read 1665 times)
Andrea
SPLINE convert ?
« on: February 28, 2006, 10:29:18 AM »
We have received a drawing cantaining many SPLINE..
but..
can we explode, modify, convert to a PLINE or do anything else with a SPLINE ??
Keep smile...
dtkell
Re: SPLINE convert ?
« Reply #1 on: February 28, 2006, 12:30:00 PM »
...do anything else with a SPLINE ??
Yes, discard all splines!
Seriously, you can 'splinedit' which allows you to manipulate the spline.
Or you can search and download a lsp program to convert your spline to a polyline.
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
Gliderider
« Reply #2 on: February 28, 2006, 01:09:08 PM »
This works so-so...
(defun C:SPLINE2PLINE (/ SPLINES PLINETYPE OSMODE I SPL ED CODEPAIR)
    (setq SPLINES (ssget (list (cons 0 "spline"))))
         (zerop (setq PLINETYPE (getvar "plinetype")))
          (setvar "plinetype" 1)
          ) ;if
       (setq OSMODE (getvar "osmode"))
       (setvar "osmode" 0)
       (setq I 0)
       (while
         (setq SPL (ssname SPLINES I))
          (setq    I  (1+ I)
                ED (entget SPL)
                ) ;setq
          (command ".pline")
          (foreach
               CODEPAIR
                       ED
              (= 10 (car CODEPAIR))
               (command (cdr CODEPAIR))
               ) ;if
            ) ;foreach
          (command "")
          (command ".pedit" "l" "s" "")
          ) ;while
       (if PLINETYPE
         (setvar "plinetype" PLINETYPE)
       (setvar "osmode" OSMODE)
       ) ;progn
     ) ;if
  ) ;defun
Thanks to the unknown author.
Andrea
« Reply #3 on: February 28, 2006, 01:21:59 PM »
thanks..
i've found..this one..
;;CADALYST 12/03 AutoLISP Solutions  SPLINE-TO-PLINE.LSP
;;(c) 2003 Tony Hotchkiss
(defun spline-to-pline (/ i)
  (setq *thisdrawing* (vla-get-activedocument
(vlax-get-acad-object)
      ) ;_ end of vla-get-activedocument
*modelspace*  (vla-get-ModelSpace *thisdrawing*)
  ) ;_ end of setq
  (setq spline-list (get-spline))
  (setq i (- 1))
  (if spline-list
      (setq msg "\nNumber of segments <100>: ")
      (initget 6)
      (setq num (getint msg))
      (if (or (= num 100) (= num nil))
(setq num 100)
      ) ;_ end of if
      (repeat (length spline-list)
(setq splobj (nth (setq i (1+ i)) spline-list))
(convert-spline splobj num)
      ) ;_ end of repeat
    ) ;_ end of progn
  ) ;_ end of if
) ;_ end of spline-to-pline
(defun get-spline (/ spl-list obj spline no-ent i)
  (setq spl-list nil
obj nil
spline "AcDbSpline"
selsets (vla-get-selectionsets *thisdrawing*)
ss1 (vlax-make-variant "ss1")
  ) ;_ end of setq
  (if (= (vla-get-count selsets) 0)
    (setq ssobj (vla-add selsets ss1))
  ) ;_ end of if
  (vla-clear ssobj)
  (setq no-ent 1)
  (while no-ent
    (prompt "\nSelect splines: ")
    (vla-Selectonscreen ssobj)
    (if (> (vla-get-count ssobj) 0)
(setq no-ent nil)
(setq i (- 1))
(repeat (vla-get-count ssobj)
  (setq
    obj (vla-item ssobj
  (vlax-make-variant (setq i (1+ i)))
) ;_ end of vla-item
  ) ;_ end of setq
    ((= (vlax-get-property obj "ObjectName") spline)
     (setq spl-list
    (append spl-list (list obj))
     ) ;_ end of setq
  ) ;_ end-of cond
) ;_ end of repeat
      ) ;_ end of progn
      (prompt "\nNo entities selected, try again.")
    ) ;_ end of if
    (if (and (= nil no-ent) (= nil spl-list))
(setq no-ent 1)
(prompt "\nNo splines selected.")
(quit)
      ) ;_ end of progn
    ) ;_ end of if
  ) ;_ end of while
  (vla-delete (vla-item selsets 0))
  spl-list
) ;_ end of get-spline
(defun convert-spline (splobj n / i)
  (setq point-list   nil
2Dpoint-list nil
z-list      nil
spl-lyr      (vlax-get-property splobj 'Layer)
startSpline  (vlax-curve-getStartParam splobj)
endSpline    (vlax-curve-getEndParam splobj)
i      (- 1)
  ) ;_ end of setq
  (repeat (+ n 1)
    (setq i (1+ i))
    (setq p (vlax-curve-getPointAtParam
      splobj
      (* i
(/ (- endspline startspline) n)
      ) ;_ end of *
    ) ;_ end of vlax-curve-getPointAtParam
    ) ;_ end of setq
    (setq 2Dp        (list (car p) (cadr p))
  2Dpoint-list (append 2Dpoint-list 2Dp)
  point-list   (append point-list p)
  z        (caddr p)
  z-list       (append z-list (list z))
    ) ;_ end of setq
  ) ;_ end of repeat
  (setq summ (apply '+ z-list))
  (setq arraySpace
(vlax-make-safearray
   vlax-vbdouble ; element type
   (cons 0
(- (length point-list) 1)
   ) ; array dimension
) ;_ end of vlax-make-safearray
  ) ;_ end of setq
  (setq vert-array (vlax-safearray-fill arraySpace point-list))
  (vlax-make-variant vert-array)
  (if (and (= :vlax-true (vlax-get-property splobj 'IsPLanar))
   (= summ 0.0)
      ) ;_ end of and
    (setq plobj (add-polyline
  2Dpoint-list
  vla-AddLightweightPolyline
) ;_ end of add-polyline
    ) ;_ end of setq
  point-list
  vla-Add3DPoly
    ) ;_ end of setq
  ) ;_ end of if
  (vlax-put-property plobj 'Layer spl-lyr)
  (vla-delete splobj)
  (vlax-release-object splobj)
) ;_ end of convert-spline
(defun add-polyline (pt-list poly-func)
  (setq arraySpace
   vlax-vbdouble
   (cons 0
(- (length pt-list) 1)
   ) ; array dimension
  ) ;_ end of setq
  (setq vertex-array
(vlax-safearray-fill arraySpace pt-list)
  ) ;_ end of setq
  (vlax-make-variant vertex-array)
  (setq plobj (poly-func
*modelspace*
vertex-array
      ) ;_ end of poly-func
  ) ;_ end of setq
(defun c:s2p ()
  (spline-to-pline)
) ;_ end of c:s2p
(prompt
  "SPLINE-TO-PLINE by Tony Hotchkiss. Enter S2P to start"
) ;_ end of prompt
Keep smile...
