Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
ObjectDBX Plotting
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ObjectDBX Plotting (Read 4961 times)
GDF
Water Moccasin
ObjectDBX Plotting
on:
February 25, 2006, 07:34:13 PM »
ObjectDBX Plotting. So why can't this be done? If not I wish Autodesk had a way to do it.
Gary
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: ObjectDBX Plotting
Reply #1 on:
February 25, 2006, 07:43:49 PM »
Any particular reason why you want to use DBX for Plotting Gary ?
Logged
whdjr
Guest
Reply #2 on:
February 26, 2006, 02:58:05 PM »
Gary,
What I was told from someone (I think it was on the AUGI Lisp Guild) a while back was the only way to use ObjectDBX to plot is to have a Liscenced version of ObjectDBX, not what we use it our Acad versions.
Logged
GDF
Water Moccasin
Reply #3 on:
February 27, 2006, 10:52:25 AM »
Just looking for a faster way to plot. We are using Acroplot for plotting and it runs from a script. Sets sdi to 1 a it is slooooooow.
From what I have seen from playing with objectdbx, its faaaaaaaaaaast.
Gary
Logged
Global Moderator
Seagull
Reply #4 on:
February 27, 2006, 11:20:04 AM »
Not sure if this will help you speed things up but there was a feature of PlotTabs where you can call it without the dialog box.
http://www.theswamp.org/forum/index.php?topic=1916.msg37939#msg37939
There were many changes to the routine and this feature may not be up to date with all the options.
i have not tested after the many updates to the routine as no one seemed to use that feature.
It's intent was to be able to call PlotTabs from a script or other lisp routine.
Logged
GDF
Water Moccasin
Reply #5 on:
February 27, 2006, 11:52:38 AM »
Allen
Thanks for the heads up. I will check into it.
I am just supprised that AutoCAD does not have a builtin objectdbx plotting.
I want to plot fast, without the need to open up each drawing. We only use
one layout per drawing.
Gary
Logged
Crank
Water Moccasin
Reply #6 on:
February 27, 2006, 02:06:11 PM »
Isn't 'background plotting' using objectdbx?
Logged
Vault Professional 2023 + AEC Collection
whdjr
Guest
Reply #7 on:
February 27, 2006, 02:43:27 PM »
Gary,
Have you tried using the publish command? Ya know..."just set it and forget it"...
Logged
GDF
Water Moccasin
Reply #8 on:
February 27, 2006, 03:29:38 PM »
I'm going to have to get back to you on the publish command. I think we always want the output to be in a pdf file.
No one here in our office has used publish.
Gary
Logged
whdjr
Guest
Reply #9 on:
February 27, 2006, 03:39:24 PM »
Gary,
If you have a PDF driver installed you can then make you a .pc3 file for AutoCad to use and therefore you can publish to it.
Logged
GDF
Water Moccasin
Reply #10 on:
February 27, 2006, 05:13:44 PM »
I will look into this. I am not the plotting guy in our office. I will get him to test out all of the tips.
Gary
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
ObjectDBX Plotting
