Author Topic: Get variable from a string..  (Read 5388 times)
Andrea
« on: February 24, 2006, 10:30:54 AM »
Hi All..
I would like to know the best and shorter way to get all item in this string...
"0*0v*234*test*variables*5677.89*12.4"
to have
"0"
"0v"
"234"
"test"
"variables"
"5677.89"
"12.4"
For now i use car cadr addr etc...
but just curious if there is anoother way.
thanks.
Keep smile...
zoltan
Re: Get variable from a string..
« Reply #1 on: February 24, 2006, 10:33:02 AM »
Check out my StrSpl function here: http://www.theswamp.org/forum/index.php?topic=8812.0
Joe Burke
« Reply #2 on: February 24, 2006, 11:36:29 AM »
I grow weary of folks pointing to their web sites for no other reason than to promote themselves or turn a buck.
This is a well known function which certainly does not need reinvention.
;String to List - by John Uhden
(defun String2List (str pat / i j n lst)
    ((/= (type str)(type pat) 'STR))
    ((= str pat)'(""))
    (T
      (setq i 0 n (strlen pat))
      (while (setq j (vl-string-search pat str i))
        (setq lst (cons (substr str (1+ i)(- j i)) lst)
              i (+ j n)
      (reverse (cons (substr str (1+ i)) lst))
) ;end
Command: (string2list "jack\tis\ta\tgood\tboy" "\t")
("jack" "is" "a" "good" "boy")
zoltan
« Reply #3 on: February 24, 2006, 11:41:58 AM »
Huh??  Who is pointing to what web site?
Thanks Joe.  I knew there was a better way to do that than my crap function!
« Reply #4 on: February 24, 2006, 11:53:11 AM »
    ((= str pat)'(""))
    (T
              i (+ j n)
) ;end
Someone a little grumpy today?  :lmao:
Joe Burke
« Reply #5 on: February 24, 2006, 12:10:33 PM »
My sincerest apologies. Obviously I mis-read and thought you were pointing to somewhere other than theswamp.
Time for me shut-up and go to bed.
LE
« Reply #6 on: February 24, 2006, 07:07:09 PM »
Joe Burke
« Reply #7 on: February 26, 2006, 09:43:26 AM »
Luis,
Is that your function, not John's? If so, I'm sorry... again.
« Reply #8 on: February 26, 2006, 01:01:17 PM »
Here is my reinvention of the routine.
  ;;  phraser by CAB
  (defun sphraser (str delim / ptr lst)
    (while (setq ptr (vl-string-search delim str))
      (setq lst (cons (substr str 1 ptr) lst))
      (setq str (substr str (+ ptr 2)))
    (reverse (cons str lst))
  Although very similar to John's.
  I used it in this routine and others so I think it works OK.
  http://www.theswamp.org/forum/index.php?topic=7263.msg89789#msg89789
« Reply #9 on: February 26, 2006, 01:11:28 PM »
 < snip >
hehehehehehehe .. yes, that one has had a few authors over the years. I have one published 97 by John Gibb and Jeff Pilcher, and I recokon that some could claim earlier publication dates.
There may have been a version in the NEW Rider book  "Inside AutoLisp" [ Rusty Gesner (et al) 1989 or so ] .. but my copy has been borrowed . and I can't check.
« Reply #10 on: February 26, 2006, 01:20:09 PM »
That's the thing about being new to LISP <mid 2003> seems that everything has been done at least twice already. :?
LE
« Reply #11 on: February 27, 2006, 05:29:07 PM »
Luis,
Hi Joe;
I do not know where my original function is now... has been a while.
Here is what my friend Don Butler did:
;;Don: (02-09-02)
;;First let me point out that the one you call JohnU is astually
;;Marc'Antonio's from November.
;;As Marc'Antonio sagely reminded us, setting string symbols is slower than
;;setting integers.
;;Your offering is the almost the same a Luis' except that yours doesn't
;;provide for validating the input or for multiple-character delimiters.
;;While Marc'Antonio's method is the fastest, I've grown a liking to the
;;multiple-character delimiter, which his will not handle.
;;Taking the best from Luis and Marc'Antonio, plus acknowledgments to Eric
;;Schneider, I now offer the following...
(defun Str2List (str pat / i j n lst)
    ((= str pat)'(""))
    (T
              i (+ j n)
;; It's not as fast as Marc'Antonio's, but pretty close.
And lately I wrote a new version using C++/ARX here:
http://www.theswamp.org/forum/index.php?topic=8460.0
« Last Edit: February 27, 2006, 05:32:38 PM by LE »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #12 on: March 05, 2006, 09:15:58 AM »
Here is my
if (= (strlen pat) 1)
(defun str-str-lst (str pat / i)
  (cond ((= str "") nil)
        ((setq i (vl-string-search pat str))
         (cons
           (substr str 1 i)
           (str-str-lst (substr str (+ 2 i)) pat)
         ) ;_  cons
        (t (list str))
  ) ;_  cond
) ;_  defun
if (> (strlen pat) 1)
         (cons
           (substr str 1 i)
           (str-str-lst (substr str (+ (strlen pat) 1 i)) pat)
         ) ;_  cons
        (t (list str))
  ) ;_  cond
) ;_  defun
Andrea
« Reply #13 on: March 06, 2006, 09:04:52 AM »
Here is the arx function, if anyone wants to give it a try
Usage:
delimiter = as string can include multiple patterns - see samples.
(StringToList < string > < delimiter >)
Samples:
Code:
Command: (stringtolist)
Invalid: function expects two string arguments!
nil
Command: (stringtolist "this is only a test" " ")
("this" "is" "only" "a" "test")
Command: (stringtolist "this\\is\\only\\a\\test" "\\")
Command: (stringtolist "this\\is*only*a\\test" "\\*")
Command: (stringtolist "this\\is*only*a-test" "\\*-")
For AutoCAD 2004-2006 and vertical products.
Note: the source code is under the (was C++) forum... in the String To List topic.
LE...your ARX is cool..
but tha fact is we need every time to be sure that the arx is loaded..
so i need to modify some lisp and sometime...remake some package installation.
but I like that....if there a way to make a VLX containing ARX.....please let me know..
I'll put also the DosLIB....
Keep smile...
LE
« Reply #14 on: March 06, 2006, 10:21:15 AM »
Just place the arx file into any of the support folders of autocad and use the normal loading for an arx (arxload "stringtolist.arx" nil)... inside of any MNL or acaddoc.lsp
I can make the arx to register itself for autoloading, but I prefer to leave the arx simple as-is.
No, but you might want to place inside the same call of (arxload ... ...)
