Author Topic: Vanilla in contention with Visual  (Read 10161 times)
Re: Vanilla in contention with Visual
« Reply #15 on: February 24, 2006, 02:33:29 PM »
..ok, now its working again. I went to lunch and now its working again. *Argh!*
Command: (setvar "clayer" "0")
"0"
Chuck Gabriel
« Reply #16 on: February 24, 2006, 02:37:22 PM »
Thanks Jeff.  I hadn't considered doing it that way.  Does that approach work consistently?
« Reply #17 on: February 24, 2006, 04:44:21 PM »
As far as I can tell, yes it does Chuck. I have not had any problems surface since I started doing it this way......but, it's just me and one other person at this office and however many folks folks may have used some of my posted routines that require it.
Another workaround, that for some reason I use more than I prefer, is to use the (command "undo" "be")/(command "undo" "e") sequence in place of the ActiveX undo.
Serge J. Gianolla
« Reply #18 on: February 24, 2006, 05:10:58 PM »
"Should" fix it!
(setvar 'CLAYER 0)
« Reply #19 on: February 24, 2006, 05:46:11 PM »
uhmmmm ... that would be a string for the layer , yes Serge ?
 (setvar 'CLAYER "0")
« Reply #20 on: February 24, 2006, 05:51:09 PM »
"Should" fix it!
(setvar 'CLAYER 0)
Warning: Symbols are not compatible with get/setvar with versions of AutoCAD older than 2005 if I recall correctly (can't confirm, I only have AutoCAD 2006 here).
« Reply #21 on: February 24, 2006, 05:55:12 PM »
Test in A2k4
Command: (setvar 'clayer 0)
; error: AutoCAD variable setting rejected: CLAYER 0
Command: (setvar 'clayer "0")
"0"
Command: (setq tmpLay "0")
"0"
Command: (setvar 'clayer tmplay)
"0"
Command: (setq tmpLay 0)
0
« Reply #22 on: February 24, 2006, 06:10:53 PM »
For what its worth, I use (setvar "CLAYER" variableValue) in all my error traps ...
Similar to Jeff, I use this as a Library routine called from the program initialisation to save the current VARS and set the new values ;
;;; change sysvar value and save its previous value
(defun kb:savesysvar (vars_list)
  (foreach dotpair vars_list
    (setq KG:sysvarlist (cons (list (car dotpair) (getvar (car dotpair)))
                                 KG:sysvarlist
    (if (cadr dotpair)
      (setvar (car dotpair) (cadr dotpair))
Called like this ... with the Values I expect set for the routine
;;------- SAVE Current System Variables to global KG:sysvarlist
;;------- and SET as Listed
(kb:savesysvar '(("CMDECHO" 0)
                  ("EXPERT" 5)
                  ("UCSICON" 3)
                  ("BLIPMODE" 0)
                  ("SNAPANG" 0)
                  ("SNAPMODE" 0)
                  ("OSMODE" 0)
                  ("SNAPANG" 0)
                  ("PICKADD" 1)
                  ("PICKBOX" 5)
                  ("SORTENTS" 1)
                  ("CLAYER")
example value of current Global Variable KG:sysvarlist saved by by kb:savesysvar
(("CLAYER" "0")
 ("SORTENTS" 127)
 ("PICKBOX" 5)
 ("PICKADD" 1)
 ("SNAPANG" 0.0)
 ("OSMODE" 0)
 ("SNAPMODE" 0)
 ("SNAPANG" 0.0)
 ("BLIPMODE" 0)
 ("UCSICON" 3)
 ("EXPERT" 0)
 ("CMDECHO" 1)
Then call this from the clean-up or error trap ..
;;----- Reset System Variables from global list ----------------
(foreach dotpair KG:sysvarlist (setvar (car dotpair) (cadr dotpair)))
This has worked without fault for more years than I care to say .. :-)
Serge J. Gianolla
« Reply #23 on: February 24, 2006, 06:13:39 PM »
Well spotted Kerry, I copied the line below from some of my code
(setvar 'BLIPMODE 0)
and changed Only blipmode :-) :oops:
« Reply #24 on: February 24, 2006, 06:43:25 PM »
Ok, Ive tested and tested some more. Ive tested till my brains hurt. I do see that it works like you say guys. Then so the question is: why do i / or how did i come to start to use the command method for restoring the layer prop? I will have to try and look arround this wekend if i get time.
BTW, (Funny) I ended up going off on a tangent, like i often do, while i was writing some code to test some ideas with. I actualy think i came up with a somewhat usefull routine if anyone wants it? (Or am i still a bit goofy from all the parens?)
(defun my-getpoint ( pt str / a getpt )
    ;; a general getpoint function for a test I am running.
    ;; Se7en
    ;; 02.24.06
    ;; Just a getpoint function that uses grread so that I can tell
    ;; if the user right clicks.
    ;; I am going to STOP the right click for now, I want to add the
    ;; ability to do somethign when the user right clicks later.
    (if (eq pt 'nil)
      (set 'getpt (getpoint str))
      (set 'getpt (getpoint pt str)))
    (setq a (grread getpt 2))
    (if (and a (not (eq (car a) 12)))
      (cadr a)
      (my-getpoint pt str)) )
Later, im going home now.
« Reply #25 on: February 24, 2006, 07:05:16 PM »
Chuck,
< snip >
[li]Is wholesale conversion to ActiveX still considered the best way to deal with the issue?  [/li]
[li]Has anybody ever discovered an actual root cause for the problem?  [/li]
[li]Can any of you advise me on a better way to handle this? [/li]
  • dont know, to be honest I can't recall having the problem.
  • not to my knowledge.
  • sorry, no.
I'll check the database on the weekend though.
LE
« Reply #26 on: February 24, 2006, 07:12:07 PM »
Is wholesale conversion to ActiveX still considered the best way to deal with the issue?  Has anybody ever discovered an actual root cause for the problem?  Can any of you advise me on a better way to handle this?
I saw this problem on pre-AutoCAD 2004
Anyways, I have all my routines done with basically pure VisualLISP...
Glenn R
« Reply #27 on: February 24, 2006, 08:19:42 PM »
Chuck,
It probably has something to do with COM document locking/lisp locking and Document Execution Context versus Application Execution Context...at a guess.
Also, CLAYER is a per document setting.......
Cheers,
Glenn.
Chuck Gabriel
« Reply #28 on: February 24, 2006, 10:28:38 PM »
Thank you all for your input.  In the absence of the knowledge of the actual cause of the problem, it's great to at least have a couple of different approaches to working around it.
« Reply #29 on: February 25, 2006, 07:02:26 AM »
Test in A2k4 ...
Thanks Tim. AutoCAD 2002 anyone?
