Author Topic: Can someone post a copy of delnul.lsp  (Read 4417 times)
hudster
« on: February 14, 2004, 09:24:27 AM »
I've accidentally deleted my copy and I can't find it anywhere on the net. :oops:
Cheers
Andy
« Reply #1 on: February 14, 2004, 10:10:03 AM »
What is it supposed to do?
« Reply #2 on: February 14, 2004, 10:34:35 AM »
is it still in your recycle bin?
hudster
« Reply #3 on: February 14, 2004, 01:53:23 PM »
Nah it's gone for good, I've checked and I couldn't get it back.
it's a lisp routine that deletes null objects from a drawing, empty text strings etc.
It was handy for cleaning up Architects layouts we receive.
« Reply #4 on: February 14, 2004, 02:11:17 PM »
Let Google be your friend.
CADALYST  December 1997
Tip1390.LSP: DELNUL.LSP Delete Null Entities (Bill Fane)
Is this the routine ??
;; DelNul.lsp
;; Deletes nul lines of Text, Mtext & Blocks.
;; Modified by JL Thomas 12/02/97
(Defun C:DelNul ( / TXT BLK NB NAMES)
  (if(setq TXT (ssget "X" '((-4 . "<and")(-4 . "<or")
                           (0 . "MTEXT")(0 . "TEXT")
                           (-4 . "or>")(-4 . "<or")
                           (1 . "")(1 . " ")(1 . "  ")(1 . "   ")
                           (1 . "{}")(1 . "{ }")(1 . "{  }")(1 . "{   }")
                           (1 . "{}\P")(1 . "{ }\P")(1 . "{  }\P")(1 . "{   }\P")
                           (-4 . "or>")(-4 . "and>"))))
    (command"_erase"TXT"")
    (princ(strcat"\n  "(itoa(sslength TXT))" nul text strings deleted. "))
  (princ"\n  No nul text strings found. "))
  (setq BLK(tblnext"BLOCK"T)NAMES nil)
  (while BLK
    (if(=(cdr(assoc 0(entget(cdr(assoc -2 BLK)))))"ENDBLK")
      (if(setq NB(ssget "X" (list(assoc 2 BLK))))
      (command"_erase"NB"")
    (setq NAMES(cons(cdr(assoc 2 BLK))NAMES))
  (setq BLK(tblnext"BLOCK"))
  (if NAMES
    (progn(textscr)
    (princ"\n  Nul blocks found and need purging: ")
    (foreach X NAMES(princ"\n    ")(princ X))
  (princ"\n  No nul blocks found. ")
(c:DelNul)
hudster
« Reply #5 on: February 14, 2004, 03:17:35 PM »
Yip thats it.
Strange though, i searched on cadalyst and didn't find anything.
