Author Topic: Attached Drawing Query to include "On" Layers (including XREFs)  (Read 6725 times)
pacohaas
« on: February 23, 2006, 12:30:15 PM »
I hope I'm asking this right as this is my first post here:
Ok, in Autodesk, if you attach a drawing to the current drawing and define a query of attached Drawings, you can do all sorts of things, except what I'd like to do: Bring in all linework on the layers that are "ON" from the attached drawing, including xref'd layers that are ON.  The idea is to have a self-contained version of a specific drawing that wouldn't require the xrefs, something we could send without worrying about sending every XREF as well.  Similar to exporting to DWF, but keeping the dwg format and layers.  I would imagine the layers to keep names like: XREFDRAWING!LAYER(changing the "|" to "!" so it is a valid layer name) so you could still tell where they came from originally.
I don't know if maybe there's some query option that I'm not seeing that could take care of this, but if not, it seems like something that could be done by someone a little more experienced with LISP than myself(and quite possibly already has been done)
Any ideas are appreciated and if I wasn't clear on something just ask, it makes sense in my head, but maybe I didn't convey it properly.  Thanks!
zoltan
Re: Attached Drawing Query to include "On" Layers (including XREFs)
« Reply #1 on: February 23, 2006, 12:37:53 PM »
Autodesk what? AutoCAD?
Are you talking about BINDing the xref? It makes the layer name XREF$0$LAYER.
pacohaas
« Reply #2 on: February 23, 2006, 12:48:45 PM »
yes sorry I am very new to AutoCAD(but not new to programming) and only know a little about the history of Autodesk products.  I use Land Desktop and Land Enabled Map 2005.
I checked out BINDing and it seems to be what I am looking to do.  I will keep poking around, but for now this seems to be the solution I was looking for, thanks!
« Reply #3 on: February 23, 2006, 12:53:43 PM »
Not an answer to your question....but you might want to look into ETRANSMIT. IMO....binding files is the work of the devil. :evil:
zoltan
« Reply #4 on: February 23, 2006, 01:32:54 PM »
I'm going to agree with ronjon on this one!
eTransmit all the way!!
dan19936
« Reply #5 on: February 23, 2006, 02:18:13 PM »
Unless you're exporting to a non-AutoCAD program, such as Sketchup. Binding is the only way to go. Then I delete frozen layers using:
http://www.theswamp.org/forum/index.php?topic=3069.msg38225#msg38225
Dan
pacohaas
« Reply #6 on: February 23, 2006, 03:10:40 PM »
ok, Binding is actually going to be the way to go here as it creates smaller files and what we really want is more of a "snapshot" of a project at a certain time that can be edited independently that will not change when the xrefs are changed for other drawings.  Like I said, similar almost to DWF, but in the DWG format.
Here's where the lisp is going to come in though: Once all xrefs have been BINDed and the new DWG file Saved As, we would like to "optionally" merge all the XXXXX0$0LAYER layers to a single LAYER...........
.....ok, while typing this, i think i answered my own question, using the "Insert" type instead of "Bind" in the BIND xrefs dialog.
« Reply #7 on: February 23, 2006, 03:34:19 PM »
ok, Binding is actually going to be the way to go here as it creates smaller files...
If you bind a drawing, it takes all the other drawing and puts them into one. I have never seen the file size reduced.
Drawing1 = 1 meg
5 reference files each = 1 meg
Bound drawing1 size now = 6 megs
Ron
dan19936
« Reply #8 on: February 23, 2006, 04:34:35 PM »
...what we really want is more of a "snapshot" of a project at a certain time that can be edited independently that will not change when the xrefs are changed for other drawings.
if that's the case, then etransmit to a zip file in an archive folder is the only way to go. there is no sense saving a bound drawing for future editing purposes. if you need to go 'back in time', then either pull from backup or your archives and maintain your normal workflow & file organization
pacohaas
« Reply #9 on: February 23, 2006, 05:23:56 PM »
Drawing1 = 428KB
XREF1 = 1882KB
XREF2 = 149KB
XREF3 = 1452KB
Etransmit size=3991KB (3042KB zipped)
Bound(Bind) Drawing1 = 2721KB
Bound(Insert) Drawing1 = 2698KB
I wasn't just making stuff up, I actually saw a significant(30%) file size decrease.
@dan19936: actually I think binding does make sense for us. Typically this would be used if we wanted a preliminary map really quick that would be based off our initial topography or whatever.  If linework was later added to the xrefs, we would still want to see what we had submitted, OR if we got it back from a client a few days later and they just wanted to see a few small changes(not all our new linework or new topo), we could just go back to the Bound drawing and make those changes and give them a print.
Most cases I would agree with you, and I think we will actually just be using PDFs for most cases, but like I said before it makes smaller files than an etransmit so we can use the binding(insert or not) to create an editable "snapshot".
sorry guys for posting this here, as it turned out to not be a lisp deal at all....I have a lot of Autocad to learn.
« Last Edit: February 23, 2006, 05:32:29 PM by pacohaas »
« Reply #10 on: February 23, 2006, 05:41:32 PM »
I'm still not seeing the 30% decrease.....are you taking into acount all the fonts, colortables, shapefiles...etc. that etransmit grabs as well?
My most recent test:
   base-bound.dwg                        6561 KB    2/23/2006 03:37:08 PM      a
   base-xref.dwg                         1075 KB    2/23/2006 03:36:48 PM      a
   xr1.dwg                               1073 KB    2/23/2006 03:37:50 PM      a
   xr2.dwg                               1074 KB    2/23/2006 03:37:48 PM      a
   xr3.dwg                               1074 KB    2/23/2006 03:37:46 PM      a
   xr4.dwg                               1073 KB    2/23/2006 03:37:42 PM      a
   xr5.dwg                               1074 KB    2/23/2006 03:37:38 PM      a
  Total 0 folder(s); 7 file(s)
  Total files size: 13 MB; 13007 KB; 13319220 Bytes
pacohaas
« Reply #11 on: February 23, 2006, 06:23:00 PM »
nope, that would have made the etransmit even bigger
Here's another set I have:
Drawing1: 405KB
XREF1: 73KB
XREF2: 82KB
XREF3: 121KB
Total:  678KB(zipped etransmit: 557KB)
Bound(Insert): 590KB
I'm sure that Binding, like compression, has a lot to do with the content being Bound.  If you have a different raster image in each of your XREF's you aren't going to see any decrease in filesize by binding them, but if all you have is linework, some on the same layers in each xref, then when you merge them all into one drawing with merged(insert) layers(which is why the Insert version was less than the Bind version in my previous trial), you're going to see a size drop simply because the total number of layers is less.  Compression is a very interesting topic to me, so I'm glad I brought this up if only to touch on this aspect of our problem.
« Reply #12 on: February 23, 2006, 06:34:55 PM »
Here is the latest with a zipped etransmit:
   base-bound.dwg                        6562 KB    2/23/2006 04:32:20 PM      a
   base-insert.dwg                       6553 KB    2/23/2006 04:32:16 PM      a
   base-xref - etransmit.zip             5904 KB    2/23/2006 04:32:48 PM      a
   base-xref.dwg                         1054 KB    2/23/2006 04:32:36 PM      a
   xr1.dwg                               1073 KB    2/23/2006 04:32:10 PM      a
   xr2.dwg                               1074 KB    2/23/2006 04:32:06 PM      a
   xr3.dwg                               1073 KB    2/23/2006 04:32:04 PM      a
   xr4.dwg                               1074 KB    2/23/2006 04:32:00 PM      a
   xr5.dwg                               1073 KB    2/23/2006 04:31:58 PM      a
  Total 0 folder(s); 9 file(s)
  Total files size: 25 MB; 25445 KB; 26055867 Bytes
pacohaas
« Reply #13 on: February 23, 2006, 07:05:36 PM »
you never said, do your xrefs have some complex data in them somehow? some raster images or something?  Try a set that just has linework.
dan19936
« Reply #14 on: February 23, 2006, 07:19:04 PM »
...OR if we got it back from a client a few days later and they just wanted to see a few small changes(not all our new linework or new topo), we could just go back to the Bound drawing and make those changes and give them a print.
if you make changes to an old version, do you make the same changes to the current file?
sounds like you know what you're doing, I just like CAD guidelines that are very simple to explain to all the staff
