If anyone can help me the folloeing command won't line up the text
(defun C:sel ()
;(setvar "CMDECHO" 0)
;(command "-units" " " "32" "1" "0" "0" "n")
(defun RTD (A)
(/(* a 180.0) PI)
(if (not (tblsearch "style" "GDI-LUCSANS-B"))
(command "-style" "GDI-LUCSANS-B" "lsansd.ttf" "0" "1" "0" "n" "n")
;;; (command "-layer" "m" "_GDI-SECTION LINES" "C" "6" "" "")
(setq SEC (getstring "\nPlease enter your section number.... ]"))
(setq SCALE(getint"\nPlease enter your scale factor....]"))
(setq a1-POINT(getpoint"\nPlease select section line starting point....]"))
(setq b1-POINT(getpoint"\nPlease select section line ending point....]"))
(setq ANG1(RTD(angle A1-POINT B1-POINT)))
(setq TH(* 0.15 SCALE))
(setq LL(* 0.45 SCALE))
(setq LS(* 0.16 SCALE))
(setq a2-point(polar a1-point 90 LL))
(setq a2-point(polar a2-point 90 LS))
(setq b2-point(polar b1-point 90 LL))
(setq b2-point(polar b2-point 270 LS))
;********************** DRAW AREA *****************************************
(setq LINEAL (ssadd))
(command "line" a1-POINT b1-POINT "")
(ssadd (entlast) LINEAL)
(setq set1 (ssadd))
(command "pline" a1-POINT "@0.0,0.2" "w" 0.09 0.0 "@0.0,0.25" "")
(ssadd (entlast) set1)
(setq TXT1 (ssadd))
(command "text" "j" "br" a2-POINT TH "" SEC)
(ssadd (entlast) TXT1)
(command "scale" set1 "" A1-POINT scale)
(command "scale" TXT1 "" A1-POINT scale)
(command "rotate" set1 "" A1-POINT ang1)
(command "rotate" TXT1 "" A1-POINT ang1)
(command "change" TXT1 "" "" "" "" "" 0 "")
;********************** ARROW 2 *****************************************
(setq set2 (ssadd))
(command "pline" b1-POINT "@0.0,0.2" "w" 0.09 0.0 "@0.0,0.25" "")
(ssadd (entlast) set2)
(setq TXT2 (ssadd))
(command "text" "j" "bl" b2-POINT TH "" SEC)
(ssadd (entlast) TXT2)
(command "scale" set2 "" b1-POINT scale)
(command "scale" TXT2 "" b1-POINT scale)
(command "rotate" set2 "" b1-POINT ang1)
(command "rotate" TXT2 "" b1-POINT ang1)
(command "change" TXT2 "" "" "" "" "" 0 "")
(alert "This Lisp program was written by Craig Petersen \n(UPDATED 2/4/05) \n \nIt creates a section ")
