I have three folders with the same named CTB file in them but changing the folders thru lisp doesn't flow through to the plot until I open the Options Dialog and hit OK.
Here is the code to change the plotstyles path including vla-RefreshPlotDeviceInfo
(defun c:pstf1 ()
(vla-put-PrinterStyleSheetPath
(vla-get-Files (vla-get-preferences (vlax-get-acad-object)))
"f:\\temp\\1"
(vla-RefreshPlotDeviceInfo (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
(PRINT (vla-GET-PrinterStyleSheetPath (vla-get-Files (vla-get-preferences (vlax-get-acad-object)))))
I have tried:
(vla-put-activeprofile
(vla-get-profiles (vla-get-preferences (vlax-get-acad-object)))
(getvar "cprofile")
but no luck.
Any Ideas?
