Author Topic: Connection Name  (Read 3329 times)
Andrea
Connection Name
« on: February 16, 2006, 11:26:49 AM »
Hi all..
Is it possible to retreive the connection name vis LISP
like showed in FIELD option ?
Keep smile...
whdjr
Re: Connection Name
« Reply #1 on: February 16, 2006, 11:32:01 AM »
My spanish (I hope this is Spanish) is not good at all.
What is 'connection name'?  Is that like 'loginname'?
Maybe look at environment variables, 'getenv'.
sinc
Re: Connection Name
« Reply #2 on: February 16, 2006, 12:04:01 PM »
Your French must not be very good either.   :-D
But I must admit I can't quite parse the question, either.
Are you trying to access the name of the current plot device from Lisp?
whdjr
Re: Connection Name
« Reply #3 on: February 16, 2006, 01:17:39 PM »
oops   :oops:
Andrea
Re: Connection Name
« Reply #4 on: February 16, 2006, 01:30:14 PM »
OK...
Sorry...I have installed the English version of 2006 only to show you this screen... :laugh:
Note:
The "Andrea Andreetti" is my name....and not my LOGINNAME.
also, can i use the Field expression in lisp ?
Keep smile...
whdjr
Re: Connection Name
« Reply #5 on: February 16, 2006, 01:46:31 PM »
You can use the Field expression in lisp as long as you are supplying the expression for text input ie: mtext, text, attributes,..
Andrea
Re: Connection Name
« Reply #6 on: February 16, 2006, 03:04:40 PM »
thanks...
But if i need to put     %<\AcVar Login \f "%tc4">%
in a variable.. ?
(setq var1 "%<\AcVar Login \f \"%tc4\">%")
!var1 = Andrea Andreetti  ?
Keep smile...
whdjr
Re: Connection Name
« Reply #7 on: February 16, 2006, 04:21:42 PM »
Andrea,
The reason it doesn't work is because of the " in the expression.  The command line is treating it like the end of a string.
vladimirzm
Re: Connection Name
« Reply #8 on: February 17, 2006, 01:46:35 AM »
oops   :oops:
Don't worry whdjr...
the Spanish version...  :-D :-D :-D
vladimirzm
Re: Connection Name
« Reply #9 on: February 17, 2006, 02:18:39 AM »
I forgot to answer  :evil:
Andrea, You can get the current user name via Windows Script Host from Vlisp, exactly through the WScript.Network class:
(defun UserName (/ wsn)
  (setq wsn (vlax-create-object "WScript.Network"))
  (vlax-get-property wsn "UserName")
You could get the computer name and user domain too:
(defun PCdats (/ wsn un cn ud)
  (setq un (vlax-get-property wsn "UserName")
cn (vlax-get-property wsn "ComputerName")
ud (vlax-get-property wsn "UserDomain")
  (alert
    (strcat "User Name:\t" un
    "\nComputer Name:\t"cn
    "\nUser Domain:\t" ud
Andrea
Re: Connection Name
« Reply #10 on: February 17, 2006, 08:48:08 AM »
Vladi....
thanks, but you code is showing me the LOGINNAME....
don't need that...
I need my real name.
I don'T know where AutoCAD take this.
Keep smile...
