Author Topic: ARX  (Read 3614 times)
ConfuzedOne
ARX
« on: February 14, 2006, 11:02:53 AM »
OK I just jumped into the swamp and am interested in learning about Object ARX however I am not even sure where to start programming?  What software do I need and how can I get it?
John Kaul (Se7en)
Re: ARX
« Reply #1 on: February 14, 2006, 11:08:20 AM »
Well, welcome then. I hope you like our humble forum.
What programing languages do you know? C++?
“Common sense is not so common.” ~Voltaire
--> Donate to TheSwamp.org <--
LE
Re: ARX
« Reply #2 on: February 14, 2006, 11:24:34 AM »
Welcome...
Here is the basic info about objectARX:
www.objectarx.com
Re: ARX
« Reply #3 on: February 14, 2006, 11:24:59 AM »
This place is where someone told me to start.  I think I saw it from Luis first.  Hope it helps, and welcome to the swamp.  Lots of good people here willing to help.
LE
Re: ARX
« Reply #4 on: February 14, 2006, 11:31:37 AM »
Hey.... I was just about to give that link..... thanks Tim.
Yep, that site from the M A S T E R Fernado Malard is excellent!!!
Re: ARX
« Reply #5 on: February 14, 2006, 11:37:04 AM »
I have it saved in my bookmarks incase I have the chance to get into Arx programming.   :-D
Re: ARX
« Reply #6 on: February 14, 2006, 11:39:26 AM »
Yes John, thats the question to start with :-)
--> Donate to theSwamp<--
ConfuzedOne
Re: ARX
« Reply #7 on: February 14, 2006, 11:41:20 AM »
I have been doing Lisp for about a year now.  I taught myself from the help files so mu knowledge is limited but I can do a lot with what little knowledge I have.  I use the idea that as I learn one new thing I can use it all over the place to mostly help speed up my drafting.
Re: ARX
« Reply #8 on: February 14, 2006, 11:46:57 AM »
You're going to get differing advice, so I'll go first :-)
Continue with your VLisp ..
Learn the ACAD Object Model
Download These ..
http://msdn.microsoft.com/vstudio/express/default.aspx
.. and play for 12 months or so ..
then Start here  http://www.objectarx.com/
LE
Re: ARX
« Reply #9 on: February 14, 2006, 12:08:03 PM »
Agree with...
LE
Re: ARX
« Reply #10 on: February 14, 2006, 02:44:14 PM »
I will recommend ... to get into this no matter what....
Have fun.
jjs
Re: ARX
« Reply #11 on: March 05, 2007, 06:38:58 PM »
so does the express version of C++ work with objectARX straight out of the box?
Chuck Gabriel
Re: ARX
« Reply #12 on: March 05, 2007, 07:00:31 PM »
Hi JJ.
Sorry but the answer is no.  Some of the ARX libraries link use MFC, and the express version of C++ doesn't include the MFC libraries.
John Kaul (Se7en)
Re: ARX
« Reply #13 on: March 05, 2007, 08:09:48 PM »
I realize this is a stupid question but i have to ask: dev bloodshed?
« Last Edit: March 05, 2007, 08:10:51 PM by Se7en »
MickD
  • (x-in)->[process]->(y-out)
Re: ARX
« Reply #14 on: March 05, 2007, 08:28:20 PM »
I think the problem with other non-MS ide's is that the required MFC libraries to link against are not available, they are a proprietary item that ships with VS only.
Lao Tzu: “To attain knowledge, add things
every day; to obtain wisdom, remove things every day.”
