Author Topic: Bringing up text window  (Read 3126 times)
caddesk2000
« on: February 14, 2006, 10:33:31 AM »
I am very new to AutoLISP.  This is a simple line I'm using to view values of different group codes.  Question:  What function can I use to bring up my text window so I can view an objects entire list instead of just what appears on the three lines of my command line?  I tried inserting (textscr) before closing and it brings up my text screen ok, but the program basically bombs, not showing me any of my information.  Does anyone have a suggestion?
(defun c:inf ()
(entget (car (entsel))
TIA,
Sam Cutbirth
Re: Bringing up text window
« Reply #1 on: February 14, 2006, 10:39:58 AM »
From within VLisp :
(vl-cmdf "textscr")
at the command Line TEXTSCR
added :
or within ALisp (command "TEXTSCR")
« Reply #2 on: February 14, 2006, 11:11:26 AM »
I think it is just
(textscr)
and that will pop up the text window and then
(graphscr)
to bring it back down.
« Reply #3 on: February 14, 2006, 11:25:24 AM »
Yes Tim, that too :-)   ... It was not seeing the woods for the trees situation..
This will display what you want ..
(defun c:inf (/ ent) (setq ent (entget (car (entsel)))) (textscr) ent)
Have a search .. MP has posted a version that formats the output so it is eminently readable ..
« Reply #4 on: February 14, 2006, 11:30:14 AM »
I hate when that happens.
Here is an old one that I still use.
(defun c:Elist()
(setq ent (entget(car(entsel"Select entity: "))))
(setq ct 0)
(textpage)
(princ "\nEntget of entity selected: ")
(repeat (length ent)
 (print (nth ct ent))
 (setq ct(1+ ct))
« Last Edit: February 14, 2006, 11:32:45 AM by CAB »
« Reply #6 on: February 14, 2006, 11:35:25 AM »
Just fixed your links Kerry, not sure why they wern't working.
This one has been around.
(defun c:dump (/ ent obj)
  (while (setq ent (entsel "\nSelect entity to get object data: "))
    (setq obj (vlax-ename->vla-object (car ent)))
    (vlax-dump-object obj t)
    (vlax-release-object obj)
« Reply #7 on: February 14, 2006, 11:39:02 AM »
Here is one I use when programming.  Just supply the variable of an object.
(defun Dump (VlaObject)
(vlax-dump-object VlaObject t)
caddesk2000
« Reply #8 on: February 15, 2006, 07:37:02 AM »
Thank you all for your replies.  Have a great day.
Sam Cutbirth
