Author Topic: Show and Tell ..  (Read 26316 times)
Re: Show and Tell ..
« Reply #30 on: March 28, 2006, 11:23:13 AM »
Very nicely done James -- easy to see that took some thoughtful time, effort and committment to design and code thru to fruition.
I noticed that this is your first post to the swamp, so a hearty "welcome aboard". There are many very talented folks that hang their hat here to share their friendship and expertise. Perhaps your hat will appear on the rack regularly too.
Cheers.
Michael.
jmaeding
« Reply #31 on: March 28, 2006, 06:12:51 PM »
Thanks, I have done about five "major" progs using ODCL, so you know this forum is now at the top of my list.
The one thing I take prode in with ODCL is that I know how to make it work with MS Flexgrids.  You cannot select multiple cells with the ODCL grid, but you can with a flexgrid.  Its a bit tricky, because you cannot programmatically select multiple cells, there is a workaround to that.  But the user can select multiple...
Those dialogs you saw are the result of 6 years of development, where I add stuff slowly but surely.  Once I wrote my own "geometry" routines for finding station offsets of points along an alignment, I did not need land to do those calcs.  Now I don't need LDT for anything, but I still make my prog work with it since many users want to stick with LDT.
I'll be around...
James Maeding
« Reply #32 on: March 28, 2006, 07:23:46 PM »
Hey, James, glad you found us over here! Although I don't use ODCL I still occasionaly check it out. I do frequent most other forums here, though.
Jeff
jbuzbee
« Reply #33 on: April 05, 2006, 12:44:24 PM »
All of you ADT2006 users know that when dragging and dropping an xref from the PN doesn't fire a command: meaning the event can't be trapped and the xref goes on whatever layer is current <gasp>.  I know they fixed this for 2007 - I just know it! :-P
So until then, I wrote this little floater that shows the same info as the constructs tab.  Drag and drop to xref - oh, and xrefs go on layer XREF.
Being a user and not a programmer I seem to like very small, compact forms - they take up less screen space!
Here's another small form for adding text to a dimension:
jb
James Buzbee
Windows 8
Andrea
« Reply #34 on: April 08, 2006, 09:43:40 AM »
Hey Guys...
very cool stuff !!!
i'm impressed...
hope that the ObjectDCL.arx is coming for 2007... :-o
Keep smile...
BazzaCAD
« Reply #35 on: May 24, 2006, 04:15:24 PM »
Here are a few of mine.
Custom Open/New dialog boxes based on our office projects MySQL database.
Also, show who has the dwg opened & there phone extension in the tree, before you try to open the dwg...
BazzaCAD
« Reply #36 on: May 24, 2006, 04:19:45 PM »
Some other common tools.
« Reply #37 on: May 24, 2006, 04:59:22 PM »
You do good work. :-)
Welcome to the swamp.
« Reply #38 on: May 24, 2006, 05:04:00 PM »
Looks great Barry.
Good to have you visit, welcome.
« Reply #39 on: May 24, 2006, 05:05:28 PM »
Wow, lots of talent show cased in this thread; kudos to all.
