Author Topic: Show and Tell ..  (Read 26275 times)
Re: Show and Tell ..
« Reply #15 on: March 07, 2006, 04:45:43 PM »
Hi Kerry,
That's what I thought.  But it doesn' show up in my IDE (v3.0).
But when I downloaded LE's grid example for another section of the Swamp,  the Grid control shows up on the Form and the program runs fine,   but the Grid still isn't in the toolbox.
Maybe I'm missing something.
ahhhhhhh ..
 the ARX will RUN  an odc from any edition of the IDE. The Grid Control is ONLY in the Enterprise Version IDE.
SomeCallMeDave
« Reply #16 on: March 07, 2006, 04:57:32 PM »
Thanks Kerry.   That is a bit of a bummer.
I guess I can use MS DataGrid.  Unless you can recommend a nice 3rd party grid control.
« Reply #17 on: March 07, 2006, 05:04:18 PM »
Must admit I haven't done much playing with 3rd Party Controls in ODCL Dave.
Perhaps an upgrade is worth considering, WHEN the 2007 ARX is released.
Tramber
« Reply #18 on: March 13, 2006, 02:07:23 PM »
An extract of my work under objectdcl :
Serge J. Gianolla
« Reply #19 on: March 13, 2006, 08:29:03 PM »
Pas mal Albert/Robert
Mais faut etre plus precis dans la boite de dialogue pour l'usager. Est ce que c'est du bois ... d'arbre? :lmao:
« Reply #20 on: March 13, 2006, 08:33:48 PM »
It looks like circular stairs to me Serge ... but my French relies on 'BabelFish' :-) , so I may have missed a lot  in the translation.
Serge J. Gianolla
« Reply #21 on: March 13, 2006, 11:42:10 PM »
Hi Kerry,
Was meant to be humoristic, but I am afraid that it cannot really be translated. This is why we shall always need interpreters as opposed to translators.
This is my contribution to ODCL. DwgSetUp is a floating form using tabs, an ActiveX for layers by Cyrille Fauvel @ Autodesk, a treelist... things that are still not in Proteus DCL.
SunCalc has a round angle slider [on the other tab]
« Reply #22 on: March 13, 2006, 11:48:10 PM »
The DwgSetUp looks really interesting Serge.
Serge J. Gianolla
« Reply #23 on: March 14, 2006, 12:02:24 AM »
Thanks Sir ... Kerry 8-)
Forgot to mention SSteel, a floating/Docking form where user can look at the preview, orbit, zoom, pan! Yessir!
« Last Edit: March 14, 2006, 03:22:16 AM by Serge J. Gianolla »
« Reply #24 on: March 14, 2006, 12:30:37 AM »
Looks sortof related to this : :-)
Serge J. Gianolla
« Reply #25 on: March 14, 2006, 12:40:52 AM »
There ya go. Great minds  :angel: think alike :lmao:
Tramber
« Reply #26 on: March 14, 2006, 03:30:40 AM »
It is a succes, I wanted that my posted image tells about itself !
I'm fully satisfied with ODCL but I must there is one thing that ever discouraged me : the BLOCKVIEW almost never updates my 3D blocks as well as it does with 2Ds.
Apart from this, it is only happiness. And I can see that this thread is still to get bigger.
Serge J. Gianolla
« Reply #27 on: March 14, 2006, 03:38:09 AM »
Weird! Because if you look at SSteel when in 3D tab, the viewer shows a beam in this case with no sweat.
Marrant, parce que sur l'onglet en 3D de SSteel tu peux voir qu'il n'y a pas de probleme - dans ce cas la c'est une poutre mais ca pourrait etre n'importe quoi d'autre.
Tramber
« Reply #28 on: March 14, 2006, 07:30:07 AM »
Et pourtant elle tourne !
It happens so often in my case that I started a new thread. As my intention is not to pollute this one with problems.
So there you can see an other image.
jmaeding
« Reply #29 on: March 28, 2006, 11:00:00 AM »
Here are some dialogs from my LDT replacement program.  Note the 3D contours in the backround drawn without a surface!
James Maeding
