Author Topic: Manipulate Lists  (Read 2934 times)
GDF
Manipulate Lists
« on: February 07, 2006, 02:55:12 PM »
Sorry, I have to ask. Can someone show me how to manipulate dotted pair list.
("MyRoomInformation" (1000 . "ROOM NAME") (1000 . "Living Room") (1000 . "ROOM
NUMBER") (1000 . "123") (1000 . "AREA") (1040 . 55.2294))
I want the following:
Room Name "Living Room"
Room Number "123"
Area 55.2294
Gary
Re: Manipulate Lists
« Reply #1 on: February 07, 2006, 03:09:02 PM »
One way.
(setq MyList '("MyRoomInformation" (1000 . "ROOM NAME") (1000 . "Living Room") (1000 . "ROOM NUMBER") (1000 . "123") (1000 . "AREA") (1040 . 55.2294)))
(foreach Item (cdr MyList)
 (setq tmp (vl-princ-to-string (cdr Item)))
 (if tmpStr
   (prompt (strcat "\n " tmpStr " " tmp))
   (setq tmpStr nil)
  (setq tmpStr tmp)
GDF
« Reply #2 on: February 07, 2006, 03:22:32 PM »
Thanks Tim
I find it hard to do the simplest things.
using your code I get:
 123 ROOM NAME
 Living Room ROOM NUMBER
 123 AREA"55.2294"
So how would you do the list like in my previous example?
ROOM NAME Living Room
ROOM NUMBER "123"
area "55.2294"
Gary
« Reply #3 on: February 07, 2006, 03:27:03 PM »
Another way.... (I did add ":" after each description)
(while (setq lst (cdr lst))
  (princ (strcat "\n" (cdar lst) ":  "
(cond ((= (type (setq x (cdadr lst))) 'INT)
(itoa x))
       ((= (type x) 'REAL)
(rtos x))
       ((= (type x) 'STR)
(strcat "\"" x "\""))
Edited to relocate the line feed
GDF
« Reply #4 on: February 07, 2006, 03:34:18 PM »
Thanks Jeff
ROOM NAME:  "Living Room"
ROOM NUMBER:  "123"
AREA:  4'-7 59/256"
That is what I wanted.
Now I just need to save these examples and not lose them.
Gary
Fatty
« Reply #5 on: February 07, 2006, 04:26:41 PM »
Here is another one
(defun readxd (lst)
  (if (cadr (cdr lst))
    (cons (list (cdar (cdr lst))
(vl-princ-to-string (cdadr (cdr lst))))
  (readxd (cddr lst)))))
GDF
« Reply #6 on: February 07, 2006, 04:38:24 PM »
Fatty
(defun C:XDL1 (/ BMENT BMSEL ELST FOROBJ)
 (setq BMSEL (entsel "\n* Select Object to Get It's Xdata *"))
 (if BMSEL
   (setq BMENT (car BMSEL))
   (vlax-for FOROBJ (vla-get-registeredapplications
                     (vla-get-database
                      (vla-get-activedocument
                       (vlax-get-acad-object)
    (setq ELST (entget BMENT (list (vla-get-name FOROBJ))))
    (if (assoc -3 ELST)
     (print (cadr (assoc -3 ELST)))  (print (cadar (assoc -3 ELST)))
 (prin1)
I get the following using Tim Willeys (c:RoomInfo):
(("ROOM NAME" "Living Room") ("ROOM NUMBER" "123") ("AREA" "55.2294"))
When I use:
(readxd '("MyRoomInformation"
               (1000 . "123")
               (1000 . "AREA")
               (1040 . 55.2294)))
« Reply #7 on: February 07, 2006, 04:48:24 PM »
You can add more stuff to that routine Gary.  Just have it prompt for my questions if that isn't enough for you.  That is one I will be working on when I have time.  Glad someone found a use for it.
« Reply #8 on: February 07, 2006, 07:52:51 PM »
They are!  :-)
« Reply #9 on: February 07, 2006, 08:01:05 PM »
Tim, Mark has a team of people who, every night, save threads that Mark has pre-nominated.
You have no worries, 'cause this is one of those threads ..
 :lmao:
