Author Topic: set layer to no plot  (Read 5806 times)
Amsterdammed
« on: February 07, 2006, 11:06:28 AM »
Hello everybody,
Is there a way to set a layer on no plot with entmod?
Thanks in advance,
Bernd
Re: set layer to no plot
« Reply #1 on: February 07, 2006, 11:34:19 AM »
Yes....here is a small lisp function I posted to the Adesk newsgroup a few weeks ago to toggle the noplot status of the given layer:
;;usage (noplotlay "0")
(defun noplotlay (layname / lay entlist assoc290)
  (if (setq lay (tblobjname "LAYER" layname))
      (setq entlist (entget lay)
     assoc290 (assoc 290 entlist)
      (entmod (subst (cons 290 (- 1 (cdr assoc290))) assoc290 entlist))
Amsterdammed
« Reply #2 on: February 07, 2006, 12:15:11 PM »
Jeff,
Not only that you solved my problem, I also learned a lot about the whole table thing. I was looking with tblsearch and did not find anything. Now I see…  :roll:
Thanks a lot
Bernd
CADmium
« Reply #3 on: February 08, 2006, 01:42:16 AM »
to set /unset Bits it's better to use the boole / logand / logior functions. Only -1 can produce an error when GC 290 = 0 ..
(defun DT:LAYER-PUT-PLOTTABLE-GC (LAYER PLOTABLE? / DATA)
  (if (not LAYER) (setq LAYER (getvar "CLAYER")))
  (and(setq DATA (tblobjname "LAYER" LAYER))
      (setq DATA (entget DATA))
      (if(not(member PLOTABLE? '(nil 0 "no")))
        (entmod(subst(cons 290 (boole 7(cdr(assoc 290 DATA))1))(assoc 290 DATA)DATA))
        (entmod(subst(cons 290 (boole 2(cdr(assoc 290 DATA))1))(assoc 290 DATA)DATA))
usage:
(DT:LAYER-PUT-PLOTTABLE-GC "0" nil)
"Bei 99% aller Probleme ist die umfassende Beschreibung des Problems bereits mehr als die Hälfte der Lösung desselben."
« Reply #4 on: February 08, 2006, 02:08:19 AM »
CADmium,
Personal preference  < and probably also more conventional >  :
PLOTABLE? would be T or nil
and the test would become
(if PLOTABLE?
   (bla lba ..
   ;else
   (bla bla
CADmium
« Reply #5 on: February 08, 2006, 04:22:30 AM »
CADmium,
(if PLOTABLE?
   (bla lba ..
   ;else
   (bla bla
.. how you like it .. i think , this changes are not a problem .. maybe , the member-function is confusing
« Reply #6 on: February 08, 2006, 04:24:21 AM »
hehehehe
nope, not at all :-)
« Reply #7 on: February 08, 2006, 09:39:11 AM »
I don't follow.....if I want a pure toggle, turn on/off plotting no matter what it is currently set to I see no need for using boole.
(- 1 0) = 1
(- 1 1) = 0
Very simple so that those trying to learn can understand it. And although I recall having used boole in the past, relooking at the help for it I found myself confused in it's use until I sat down and toyed with it.
CADmium
« Reply #8 on: February 08, 2006, 10:43:05 AM »
@Jeff_M :sorry i read it as (- (cdr assoc290) -1) <dream>   , but boole is the better way ... universally .. for instance when you also want to manipulate the Freeze-Bit or the Locked Bit of a layer ( both GC 70)
for toogle a bool - 0 or 1 - ...  I also  use  (- 1 Bool)
« Reply #9 on: February 08, 2006, 11:53:09 AM »
usage:
Another way to phrase it.
(defun dt:layer-put-plottable-gc (layer plotable? / data n)
  (or layer (setq layer (getvar "CLAYER")))
  (setq n (if (or plotable? (member plotable? '(1 "yes" "YES")) 7 2)))
  (and (setq data (tblobjname "LAYER" layer))
       (setq data (entget data))
       (entmod (subst (cons 290 (boole n (cdr (assoc 290 data)) 1)) (assoc 290 data) data))
« Reply #10 on: February 08, 2006, 12:08:16 PM »
This
'(1 "yes" "YES") should be expanded to this
'(1 "yes" "YES" "Y" "Yes" "OK" Yep" "Youbetcha" "Alrightythen" "UhHuh")which brings me to my point.....if you are going to do something like this, then I agree with Kerry
Quote from: Kerry Brown
Alan, this makes no sense to me:
(or plotable? (member plotable? '(1 "yes" "YES")))if plotable is nil it will fail the first test which means it will also fail the second test, if it's not nil then it will never make it to the second test (and you have a misplaced ")")
« Reply #11 on: February 08, 2006, 12:33:31 PM »
OK, I screwed that up.:)
Let me try again with a simpler version.
I did test this one. :oops:
;;  layer must be string layer name or nil for current
;;  plotable?  must be nil or not nil
(defun dt:layer-put-plottable-gc (layer plotable? / data)
       (entmod (subst (cons 290 (if plotable? 1 0)) (assoc 290 data) data))
zoltan
« Reply #12 on: February 15, 2006, 10:15:49 AM »
I think he meant to do this:
(and plotable? (member plotable? '(T 1 "yes" "YES")))
but I agree with CAB:
who cares what the original value was.  We are setting it explicitly anyway.
Amsterdammed
« Reply #13 on: February 16, 2006, 08:45:45 AM »
Gentlemen,
I asked a simple Question......
t-bear
« Reply #14 on: February 16, 2006, 01:25:56 PM »
.......and got 3,427,633 simple solutions.............LOL
The neat part??  MOST of them even work!!  What a place!
