Author Topic: Help with Save/Get File List For Batch Plotter  (Read 4797 times)
deegeecees
« on: February 03, 2006, 01:16:20 PM »
I have a batch plot DVB that I slapped together from code fragments that works fairly well, the only thing I'd like to add would be a SAVE LIST, and a IMPORT LISToption. Due to the aggressive nature of the company I work for, I really can't spend the hours researching and developing something on my own here at work, and being a single Father, personal time is hardly an option, hence the call for help. Anybody?
(I'll post the DVB in a little while.)
deegeecees
Re: Help with Save/Get File List For Batch Plotter
« Reply #1 on: February 03, 2006, 01:57:07 PM »
In case anyone is interested, here it is...
BatchPlot
Murphy
« Reply #2 on: February 03, 2006, 02:56:58 PM »
Here's the Write
Public Sub WriteEmAll()
Dim listLeng As Integer
Dim strFileName As String
strFileName = InputBox("What name for this list?", "List Name", CurDir & "\" & Date)
strFileName = strFileName & ".txt"
'write the Text to file
Open strFileName For Append Access Write As #10
For listLeng = 0 To ListBox1.ListCount - 1
    Write #10, ListBox1.List(listLeng, 0)
Next listLeng
Close #10
End Sub
This is my calling routine with the question for the user to either retrieve the info from a text file or do the file dialog.
Sub BatchList()
 Dim objFD As New FILEDIALOG
 Dim strFiles As String
 Dim strTFile As String
 Dim cb As Integer
 On Error GoTo Err_Handler
 If MsgBox("Get drawing list from a saved text file?", vbYesNo, "Get Saved List") = vbYes Then
    objFD.MultiSelect = False
    objFD.Filter = "Text Files" _
    & Chr$(0) & "*.txt" & Chr$(0)
    strFiles = objFD.ShowOpen
    Open strFiles For Input As #1    ' Open file for input.
    Do While Not EOF(1)    ' Loop until end of file.
        Input #1, strTFile
        BatchEmAll.ListBox1.AddItem strTFile
    Loop
    Close #1
 Else
    objFD.MultiSelect = True
    objFD.Filter = "Drawing Files" _
    & Chr$(0) & "*.dwg" & Chr$(0)
    FormatMultiReturn (strFiles)
    For cb = 1 To NameCount - 1
        curName = ExtractedNames(cb)
        BatchEmAll.ListBox1.AddItem curName
    Next cb
    curName = ExtractedNames(0)
 End If
Set objFD = Nothing
BatchEmAll.Show
Exit_Here:
Exit Sub
Err_Handler:
Select Case Err.Number
    Case 9
        Err.Clear
        GoTo Exit_Here
    Case Else
        MsgBox Err.Number & " " & Err.Description
End Select
End Sub
deegeecees
« Reply #3 on: February 03, 2006, 03:13:32 PM »
Thanks Murph! I have questions, will post in a while (under the gun at the moment).
deegeecees
« Reply #4 on: February 03, 2006, 03:49:11 PM »
OK, questions:
1. Would both Subs go in a Module?
2. Will I need to add a button?
(I have limited at best knowledge of VBA)
Murphy
« Reply #5 on: February 03, 2006, 03:55:51 PM »
The Write goes in the Form and I tied mine to a check box that reads "save this list for future use"
The BatchList goes in a module that I use to call up the batch list form. It has the MsgBox to ask the user if they want to get the list from a text file and goes from there.
deegeecees
« Reply #6 on: February 03, 2006, 04:39:54 PM »
Type not defined
What Type Librarys do you have checked?
Murphy
« Reply #7 on: February 03, 2006, 06:23:07 PM »
Whoopsie, forgot that.
Put the following code in a Class Module titles FILEDIALOG
Option Explicit
'//The Win32 API Functions///
Private Declare Function GetSaveFileName Lib _
"comdlg32.dll" Alias "GetSaveFileNameA" _
(pOpenfilename As OPENFILENAME) As Long
Private Declare Function GetOpenFileName Lib _
"comdlg32.dll" Alias "GetOpenFileNameA" _
Private Declare Function FindWindow Lib "user32" _
Alias "FindWindowA" (ByVal lpClassName As String, _
ByVal lpWindowName As String) As Long
'//A few of the available Flags///
Private Const OFN_FILEMUSTEXIST = &H1000
Private Const OFN_HIDEREADONLY = &H4
Private Const OFN_ALLOWMULTISELECT = &H200
'This one keeps your dialog from turning into
'A browse by folder dialog if multiselect is true!
'Not sure what I mean? Remove it from the flags
'In the "Show Open" & "Show Save" methods.
Private Const OFN_EXPLORER As Long = &H80000
'//The Structure
Private Type OPENFILENAME
  lStructSize As Long
  hwndOwner As Long
  hInstance As Long
  lpstrFilter As String
  lpstrCustomFilter As String
  nMaxCustFilter As Long
  nFilterIndex As Long
  lpstrFile As String
  nMaxFile As Long
  lpstrFileTitle As String
  nMaxFileTitle As Long
  lpstrInitialDir As String
  lpstrTitle As String
  flags As Long
  nFileOffset As Integer
  nFileExtension As Integer
  lpstrDefExt As String
  lCustData As Long
  lpfnHook As Long
  lpTemplateName As String
End Type
Private lngHwnd As Long
Private strFilter As String
Private strTitle As String
Private strDir As String
Private blnHideReadOnly As Boolean
Private blnAllowMulti As Boolean
Private blnMustExist As Boolean
Private Sub Class_Initialize()
  'Set default values when
  'class is first created
  strDir = CurDir
  strTitle = "Llamas Rule"
  strFilter = "All Files" _
  & Chr$(0) & "*.*" & Chr$(0)
  lngHwnd = FindWindow(vbNullString, Application.Caption)
  'None of the flags are set here!
End Sub
Public Property Let OwnerHwnd(WindowHandle As Long)
  '//FOR YOU TODO//
  'Use the API to validate this handle
  lngHwnd = WindowHandle
  'This value is set at startup to the handle of the
  'AutoCAD Application window, if you want the owner
  'to be a user form you will need to obtain its
  'Handle by using the "FindUserForm" function in
  'This class.
End Property
Public Property Get OwnerHwnd() As Long
  OwnerHwnd = lngHwnd
End Property
Public Property Let Title(Caption As String)
  'don't allow null strings
  If Not Caption = vbNullString Then
    strTitle = Caption
  End If
End Property
Public Property Get Title() As String
  Title = strTitle
End Property
Public Property Let Filter(ByVal FilterString As String)
  'Filters change the type of files that are
  'displayed in the dialog. I have designed this
  'validation to use the same filter format the
  'Common dialog OCX uses:
  '"All Files (*.*)|*.*"
  Dim intPos As Integer
  Do While InStr(FilterString, "|") > 0
    intPos = InStr(FilterString, "|")
    If intPos > 0 Then
      FilterString = Left$(FilterString, intPos - 1) _
      & Chr$(0) & Right$(FilterString, _
      Len(FilterString) - intPos)
    End If
  Loop
  If Right$(FilterString, 2) <> Chr$(0) & Chr$(0) Then
    FilterString = FilterString & Chr$(0)
  End If
  strFilter = FilterString
End Property
Public Property Get Filter() As String
  'Here we reverse the process and return
  'the Filter in the same format the it was
  'entered
  Dim strTemp As String
  strTemp = strFilter
  Do While InStr(strTemp, Chr$(0)) > 0
    intPos = InStr(strTemp, Chr$(0))
    If intPos > 0 Then
      strTemp = Left$(strTemp, intPos - 1) _
      & "|" & Right$(strTemp, _
      Len(strTemp) - intPos)
    End If
  Loop
  If Right$(strTemp, 1) = "|" Then
    strTemp = Left$(strTemp, Len(strTemp) - 1)
  End If
  Filter = strTemp
End Property
Public Property Let InitialDir(strFolder As String)
'Sets the directory the dialog displays when called
  If Len(Dir(strFolder)) > 0 Then
    strDir = strFolder
  Else
    Err.Raise 514, "FileDialog", "Invalid Initial Directory"
  End If
End Property
Public Property Let HideReadOnly(blnVal As Boolean)
  blnHideReadOnly = blnVal
End Property
Public Property Let MultiSelect(blnVal As Boolean)
'allow users to select more than one file using
'The Shift or CTRL keys during selection
  blnAllowMulti = blnVal
End Property
Public Property Let FileMustExist(blnVal As Boolean)
  blnMustExist = blnVal
End Property
' Display and use the File open dialog
Public Function ShowOpen() As String
  Dim udtStruct As OPENFILENAME
  udtStruct.lStructSize = Len(udtStruct)
  'Use our private variable
  udtStruct.hwndOwner = lngHwnd
  udtStruct.lpstrFilter = strFilter
  udtStruct.lpstrFile = Space$(254)
  udtStruct.nMaxFile = 255
  udtStruct.lpstrFileTitle = Space$(254)
  udtStruct.nMaxFileTitle = 255
  udtStruct.lpstrInitialDir = strDir
  udtStruct.lpstrTitle = strTitle
  'Ok, here we test our booleans to
  'set the flag
  If blnHideReadOnly And blnAllowMulti And blnMustExist Then
    udtStruct.flags = OFN_HIDEREADONLY Or _
    OFN_ALLOWMULTISELECT Or OFN_EXPLORER Or OFN_FILEMUSTEXIST
  ElseIf blnHideReadOnly And blnAllowMulti Then
    udtStruct.flags = OFN_ALLOWMULTISELECT _
    Or OFN_EXPLORER Or OFN_HIDEREADONLY
  ElseIf blnHideReadOnly And blnMustExist Then
    udtStruct.flags = OFN_HIDEREADONLY Or OFN_FILEMUSTEXIST
  ElseIf blnAllowMulti And blnMustExist Then
    udtStruct.flags = OFN_ALLOWMULTISELECT Or _
  ElseIf blnHideReadOnly Then
  ElseIf blnAllowMulti Then
    Or OFN_EXPLORER
  ElseIf blnMustExist Then
    udtStruct.flags = OFN_FILEMUSTEXIST
  End If
  If GetOpenFileName(udtStruct) Then
    strTemp = (Trim(udtStruct.lpstrFile))
    ShowOpen = Mid(strTemp, 1, Len(strTemp) - 1)
  End If
End Function
' Display and use the File Save dialog
Public Function ShowSave() As String
  End If
  If GetSaveFileName(udtStruct) Then
    ShowSave = Mid(strTemp, 1, Len(strTemp) - 1)
  End If
End Function
Berend
« Reply #8 on: February 14, 2006, 10:59:32 AM »
@Murphy,
just some unasked hint you can discard
If you have some spare time to invest, you could look at the
Scripting Runtimelibrary (look in your references it will be there)
and especially the filesystem object.
on the fly..:
Dim Fs as Scripting.Filesystemobject
Set Fs = New Scripting.filesystemobject
Opening these dialogs moving copying files or directory's is way easier that way.
ChuckHardin
« Reply #9 on: February 17, 2006, 10:21:32 AM »
I would suggest staying away from the Scripting object.
Use APIs instead. It will take a little longer to learn but
you will have a lower overhead on your project.
Murph has a wonderful FileDialog Class there as a matter
of fact I Use the exact same one.
Murphy
« Reply #10 on: February 17, 2006, 01:38:52 PM »
Works every time for me.
I got it from the same place Chuck did.
We used to be on that board together years ago.
ChuckHardin
« Reply #11 on: February 17, 2006, 02:07:52 PM »
here is a good place to start for API stuff
http://www.mentalis.org/index2.shtml
You can even download a pretty good API Viewer
