Author Topic: Join lots of small lines  (Read 9419 times)
hudster
« on: February 02, 2006, 10:30:15 AM »
Does anyone have a lisp which will look for lines which are end to end and on the same layer in a drawing and combine them?
I have an architects drawing made up of lots of very small lines and i'd like to combine them.
Cheers
David Hall
  • Automatic Duh Generator
Re: Join lots of small lines
« Reply #1 on: February 02, 2006, 10:37:21 AM »
overkill?
hudster
« Reply #2 on: February 02, 2006, 10:39:05 AM »
I tried that, doesn't do it for this one.
M-dub
« Reply #3 on: February 02, 2006, 10:52:47 AM »
I thought I had one, but it might be at my other office...
In the meantime,
http://www.theswamp.org/forum/index.php?topic=6093.0
GDF
« Reply #4 on: February 02, 2006, 04:37:56 PM »
(defun c:GLUE (/ flist slist f1pt f2pt s1pt s2pt)
  ;;(ARCH:F_S-VAR)
  (setq
    flist (entget (setq flin (car (entsel "\n* Pick first Line *"))))
  (setq
    slist (entget (setq slin (car (entsel "\n* Pick second Line *"))))
  (setq f1pt (cdr (assoc 10 flist)))
  (setq f2pt (cdr (assoc 11 flist)))
  (setq s1pt (cdr (assoc 10 slist)))
  (setq s2pt (cdr (assoc 11 slist)))
  (command "LAYER" "S" (cdr (assoc 8 flist)) "")
  (command "ERASE" flin "")
  (command "ERASE" slin "")
  (setq dis1 (distance f1pt s1pt))
  (setq dis2 (distance f2pt s1pt))
  (setq dis3 (distance f1pt s2pt))
  (setq dis4 (distance f2pt s2pt))
  (setq maxm (max dis1 dis2 dis3 dis4))
    ((= dis1 maxm) (command "LINE" f1pt s1pt ""))
    ((= dis2 maxm) (command "LINE" f2pt s1pt ""))
    ((= dis3 maxm) (command "LINE" f1pt s2pt ""))
    ((= dis4 maxm) (command "LINE" f2pt s2pt ""))
    (T nil)
  ;;(ARCH:F_R-VAR)
hyposmurf
« Reply #5 on: February 03, 2006, 05:18:24 PM »
Heres another:
; This routine joins two lines, two arcs, two 3dfaces, or two text items
; together. If arcs are selected, they must share a common center point and radius.
;  For lines there is no such restriction. Two lines of different angles can be
; joined. The program loops to allow several pairs of objects to be joined.
; When gluing text together, the text value of the second selected text
; item is added on to the first. A space is inserted between text items.
;;**********Required Functions*******************
;replaces needing to use (cdr (assoc type number) functions
(defun dxf ( CODE ELIST / A)
   (SETQ A (CDR (ASSOC CODE ELIST)))
   (IF (NOT A)
      (IF (OR (= CODE 38) (= CODE 39)) (SETQ A 0.0)
   )A
; Function that finds the max point between 2 point lists.
; Used to join 3dfaces. Subsequent calls can pass a test point not to match
(defun glue1 (pt1 pt2 dist testpt / n o retpt)
   (foreach n pt1
      (foreach o pt2
         (if (> (distance n o) dist)
               (if (and testpt (not (equal (distance o testpt) 0.0 0.001)))
                  (setq retpt o dist (distance n o))
               (if (null testpt)
   retpt
; Main program
(defun c:glue  ( / ent1 ent2 temp lpt1 lpt2 lpt3 lpt4 endpt endpt1 midpt midpt1 pt1 pt2 pt3 pt4
                               elist1 elist2 ang1 ang2 es)
(prompt "\nGlue arcs, lines, text, 3dfaces together...")
(while (/= "Done" (setq es (entsel "\nPick first entity")))
   (setq ent1 (car es))
   (eval '(if ent1 (redraw ent1)))
   (redraw ent1 3)
   (while (not (setq ent2 (car (entsel "\nPick second entity" ))))
      (prompt "\nTry again.")
   (setq elist1 (entget ent1) elist2 (entget ent2) pt1 nil pt2 nil pt3 nil pt4 nil)
      ;*************** BOTH ARCS **********************************
      ((and ent1 ent2 (not (equal ent1 ent2)) (= (dxf 0 elist1) "ARC")
      (= (dxf 0 elist2) "ARC"))
      (setq pt1 (dxf 10 elist1)
         arclay (dxf 8 elist1); GET LAYER FROM FIRST ARC
         pt3 (dxf 10 elist2)
      (if (equal (distance pt1 pt3) 0.0 0.001)
         (progn; SAME CENTER POINT
            (setq lpt1 (polar pt1 (dxf 50 elist1) (dxf 40 elist1))
               lpt2 (polar pt1 (dxf 51 elist1) (dxf 40 elist1))
               lpt3 (polar pt3 (dxf 50 elist2) (dxf 40 elist2))
               lpt4 (polar pt3 (dxf 51 elist2) (dxf 40 elist2))
               thick (dxf 39 elist1)
           (if (< (distance lpt1 lpt4) (distance lpt2 lpt3))
               (command "_.arc" lpt3 lpt1 lpt2)
               (command "_.arc" lpt1 lpt2 lpt4)
            (command "_.erase" ent1 ent2 ""); ERASE BOTH EXISTING ARCS
            (command "_.chprop" (entlast) "" "_la" arclay "_t" thick "")
            (eval '(if ent1 (redraw ent1)) zz#t)
            (prompt "\nArcs must have same center point")
   ;*************** BOTH LINES **********************************
      (= (dxf 0 elist1) "LINE")
   (= (dxf 0 elist2) "LINE"))
   (setq lpt1 (dxf 10 elist1)
      lpt3 (dxf 10 elist2)
      lpt4 (dxf 11 elist2)
   (command "_.erase" ent2 "")
   (setvar "orthomode" 0)
   (if (> (distance lpt1  lpt3) (distance lpt1 lpt4))
      (command "_.change" ent1 "" (trans lpt3 0 1))
      (command "_.change" ent1 "" (trans lpt4 0 1))
   ;*************** BOTH 3DFACES ********************************
   (= (dxf 0 elist1) "3DFACE")
(= (dxf 0 elist2) "3DFACE"))
; create point list of each ent
(setq pt1 (cons (dxf 10 elist1) pt1)
   pt1 (cons (dxf 11 elist1) pt1)
   pt1 (cons (dxf 12 elist1) pt1)
   pt1 (cons (dxf 13 elist1) pt1)
   pt2 (cons (dxf 10 elist2) pt2)
   pt2 (cons (dxf 11 elist2) pt2)
   pt2 (cons (dxf 12 elist2) pt2)
   pt2 (cons (dxf 13 elist2) pt2)
; eval point lists
(if (and pt1 pt2)
      ; find max points
      (setq lpt1 (pp_glue1 pt1 pt2 0 nil)
         lpt2 (glue1 pt1 pt2 0 lpt1)
         lpt3 (glue1 pt2 pt1 0 nil)
         lpt4 (glue1 pt2 pt1 0 lpt3)
      ; erase existing faces
      ; create new face
      (if (inters lpt1 lpt4 lpt3 lpt2)
         (entmake
            (list (assoc 0 elist1) (assoc 8 elist1) (append '(10) lpt1)
               (append '(11) lpt3) (append '(12) lpt4) (append '(13) lpt2)
         (entmake
            (list (assoc 0 elist1)(assoc 8 elist1)(append '(10) lpt1)
               (append '(11) lpt4)(append '(12) lpt3)(append '(13) lpt2)
);added 10-02-98
;*************** BOTH TEXT **********************************
   (= (dxf 0 elist1) "TEXT")
   (= (dxf 0 elist2) "TEXT"))
   (setq text1 (strcat (dxf 1 elist1) " " (dxf 1 elist2))
             elist1 (subst (cons 1 text1) (assoc 1 elist1) elist1)
   (entdel ent2)
   (entmod elist1)
;*************** SAME ENTITY *******************************
((equal ent1 ent2)
(prompt  "\nDon't pick the same entity twice!")
;*************** MISMATCH **********************************
((and ent1 ent2)
(prompt "\nThe 2 entities must be the same type.")
); end cond
); end while
); end defun
Does the Architects drawing look like its been hand drawn,sketch effect and loads of broken lines?If so Ive met their realtives
« Reply #6 on: February 04, 2006, 12:20:58 AM »
Gary,
Looking at your code, what happens when two lines share an end point but are not parallel?
hyposmurf
« Reply #7 on: February 04, 2006, 05:05:46 AM »
This was some code I'd found online and had stored away but had never felt the need to use.Youre correct it seems to run into problems.I looks like for instance two non parellel lines it deletes one of the lines and keep the other!Not a good result.Thanks for pointing that out.
« Reply #8 on: February 04, 2006, 10:22:11 AM »
I just threw this together with minimal testing.
See what you think. It mods the line picked first so the properties
of that line are preserved. Layer & Linetype
I'll get to the original question of doing all lines in the drawing at
one time later if I have time.
Up to date Code in Gary's post
« Last Edit: February 05, 2006, 05:03:41 PM by CAB »
GDF
« Reply #9 on: February 04, 2006, 10:40:46 AM »
Allen
Thanks for the question, it has made me cleanup some old code I still had layiny around. It still amazes me how many routines I have floating around.
I thinks it's almost spring cleaning time. I think I will use your routine to replace my two.
Sorry I sent the wrong code, here is the one I use:
;;author unknown
(defun c:GU  (/ hdrlst ent ent1 ent2 val1 val2 valn params1 1pt10 1pt11 params2 2pt10 2pt11
              dist1 dist2 dist3 dist4 distlist maxdist pts pt10 pt11 params1 hdrlst)
  (setq clayer nil)
  (setq hdrlst (list (cons "limcheck" (getvar "limcheck"))
                     (cons "osmode" (getvar "osmode"))))
  (setvar "cmdecho" 0)
  (setvar "limcheck" 0)
  (setvar "osmode" 0)
  (setq ent1 (entsel "\n* Select first line *"))
  (if (eq (cdr (assoc 0 (entget (car ENT1)))) "TEXT")
    (progn (setq ent (entget (car ent1)))
           (setq ent2 (entget (car (entsel "\n* Select second Text *"))))
           (setq val1 (cdr (assoc 1 ent)))
           (setq val2 (cdr (assoc 1 ent2)))
           (setq valn (strcat val1 " " val2))
           (setq ent (subst (cons 1 valn) (assoc 1 ent) ent))
           (entmod ent)
           (entdel (cdr (assoc -1 ent2)))
           (princ))
    (progn (while ent1
             (redraw (setq ent1 (car ent1)) 3)
             (while (or (null (setq ent2 (entsel "\n* Select second line *")))
                        (if ent2
                          (equal (car ent2) ent1))))
             (redraw (setq ent2 (car ent2)) 3)
             (while (or (/= "LINE" (cdr (assoc 0 (entget ent1))))
                        (/= "LINE" (cdr (assoc 0 (entget ent2)))))
               (redraw ent1)
               (redraw ent2)
               (prompt "\n* The entities selected are not LINE entities *")
               (while (null (setq ent1 (entsel "\n* Select first line *"))))
               (while (null (setq ent2 (entsel "\n* Select second line *"))))
               (redraw (setq ent2 (car ent2)) 3))
             (setq params1 (entget ent1))
             (setq 1pt10 (cdr (setq old10 (assoc 10 params1))))
             (setq 1pt11 (cdr (setq old11 (assoc 11 params1))))
             (setq params2 (entget ent2))
             (setq 2pt10 (cdr (assoc 10 params2)))
             (setq 2pt11 (cdr (assoc 11 params2)))
             (setq dist1 (distance 1pt10 2pt10))
             (setq dist2 (distance 1pt10 2pt11))
             (setq dist3 (distance 1pt11 2pt10))
             (setq dist4 (distance 1pt11 2pt11))
             (setq distlist
                    (list (list dist1 1pt10 2pt10)
                          (list dist2 1pt10 2pt11)
                          (list dist3 1pt11 2pt10)
                          (list dist4 1pt11 2pt11)))
             (setq maxdist (max dist1 dist2 dist3 dist4))
             (setq pts (cdr (assoc maxdist distlist)))
             (setq pt10 (car pts))
             (setq pt11 (cadr pts))
             (setq params1 (subst (cons 10 pt10) old10 params1))
             (setq params1 (subst (cons 11 pt11) old11 params1))
             (entdel ent2)
             (entmod params1)
             (entupd ent1)
           (foreach cnt hdrlst (setvar (car cnt) (cdr cnt)))
           (princ)))
  (princ))
Here is one for arcs:
;;; Author: Mark E. Leaf
(defun c:GUA (/ E1_DATA    E1_OBJ_TYPE  E1_CEN_PT
     E1_RADIUS E1_SA    E1_EA      E1_NAME  E2_DATA
     E2_OBJ_TYPE    E2_CEN_PT  E2_RADIUS  E2_SA
     E2_EA E2_NAME    E1_1ST_PT  E1_2ND_PT  E2_1ST_PT
     E2_2ND_PT D1    D2       D3  D4
     D5
  (setvar "osmode" 0)
  (setvar "ErrNo" 0)
  (while (and (not (setq E1_DATA (entsel "\n* Select First Arc *")))
     (/= 52 (getvar "ErrNo"))
    (E1_DATA
     (setq E1_DATA (entget (car E1_DATA)))
     (setq E1_OBJ_TYPE (cdr (assoc 0 E1_DATA)))
;looking for "ARC" object type
     (while (and (/= E1_OBJ_TYPE "ARC") (/= 52 (getvar "ErrNo")))
       (alert "\nNo ARC Object Selected, Try Again!")
       (setvar "ErrNo" 0)
       (while
(E1_DATA
 (setq E1_DATA (entget (car E1_DATA))) ;data base
;entity object type "ARC"
) ;end_E1_DATA nested
       ) ;end_cond
     ) ;end_while
     (if (= E1_OBJ_TYPE "ARC") ;if object "ARC" cont
(setq E1_CEN_PT (cdr (assoc 10 E1_DATA)))
(setq E1_RADIUS (cdr (assoc 40 E1_DATA)))
(setq E1_SA (cdr (assoc 50 E1_DATA))) ;arc start angle
(setq E1_EA (cdr (assoc 51 E1_DATA))) ;arc end angle
(setq E1_NAME (cdr (assoc -1 E1_DATA))) ;entity name to entupd
       ) ;end_progn
     ) ;end_if
     (princ
       "\n* Base Arc Object Selected...select another Arc to add to it *"
       ((/= 52 (getvar "ErrNo")) ;if enter is hit exit
(setvar "ErrNo" 0)
(while (and (not (setq E2_DATA (entsel "\nSelect Second Arc")))
 (E2_DATA
  (setq E2_DATA (entget (car E2_DATA))) ;database
  (setq E2_OBJ_TYPE (cdr (assoc 0 E2_DATA)))
  (setq E2_NAME (cdr (assoc -1 E2_DATA)))
;entity name to delete
  (while (and (/= E2_OBJ_TYPE "ARC") (/= 52 (getvar "ErrNo")))
    (setvar "ErrNo" 0)
    (while
      (and
(not (setq E2_DATA (entsel "\n* Select Second Arc *")))
      (E2_DATA
(setq E2_DATA (entget (car E2_DATA))) ;data base
      ) ;end_E2_DATA nested
    ) ;end_cond
  ) ;end_while
    ((equal E1_NAME E2_NAME) ;if 1st entity is select again
     (alert "\nOriginal Entity Selected, Start again!")
     (setvar "ErrNo" 52)
    ((/= E1_NAME E2_NAME) ;if 1st entity is select again
     (if (= E2_OBJ_TYPE "ARC") ;if object "ARC" cont
 (setq E2_CEN_PT (cdr (assoc 10 E2_DATA))
E2_RADIUS (cdr (assoc 40 E2_DATA))
E2_SA  (cdr (assoc 50 E2_DATA))
;arc start angle
E2_EA  (cdr (assoc 51 E2_DATA))
;arc end angle
E1_1ST_PT (polar E1_CEN_PT E1_SA E1_RADIUS)
;find startpoint of arc 1
E1_2ND_PT (polar E1_CEN_PT E1_EA E1_RADIUS)
;find endpoint of arc 1
E2_1ST_PT (polar E2_CEN_PT E2_SA E2_RADIUS)
;find startpoint of arcs 2
E2_2ND_PT (polar E2_CEN_PT E2_EA E2_RADIUS)
;find endpoint of arcs 2
D1  (distance E1_1ST_PT E2_1ST_PT)
;find dist from points of arc
D2  (distance E1_1ST_PT E2_2ND_PT)
D3  (distance E1_2ND_PT E2_1ST_PT)
D4  (distance E1_2ND_PT E2_2ND_PT)
D5  (min D1 D2 D3 D4)
 ) ;setq D5 to smallest dist
 (cond ;find shortest distance and find new start and end angles.
   ((= D1 D5)
    (setq NEW_SA E1_EA
  NEW_EA E2_EA
   ((= D2 D5)
    (setq NEW_SA E2_SA
  NEW_EA E1_EA
   ((= D3 D5)
    (setq NEW_SA E1_SA
  NEW_EA E2_EA
   ((= D4 D5)
    (setq NEW_SA E1_SA
  NEW_EA E2_SA
 ) ;end_cond
 (setq E1_DATA (subst (cons 50 NEW_SA)
      (assoc 50 E1_DATA)
      E1_DATA
 (setq E1_DATA (subst (cons 51 NEW_EA)
      (assoc 51 E1_DATA)
      E1_DATA
 (entdel E2_NAME)
 (entmod E1_DATA)
 (entupd E1_NAME)
) ;end_progn
     ) ;end_if
    ) ;end_(/= E1_NAME E2_NAME)
  ) ;end_cond (equal E1_NAME E2_NAME)
 ) ;end_E2_DATA
) ;end_E2_cond
       ) ;(/= 52 (getvar "ErrNo")
     ) ;end_cond (/= 52 (getvar "ErrNo")
    ) ;end_E1_DATA
  ) ;end_E1_cond
) ;end
Gary
GDF
« Reply #10 on: February 04, 2006, 10:49:51 AM »
Sorry hyposmurf, I see that it was your code, and not Allens....I mean CAB's.
So do you want me to credit your code to hyposmurf, or use you real name, wich is?
Sorry, I'm for using real names and not code or nicknames.
Gary (and this is my real name) and yes I babble alot somethimes.
« Reply #11 on: February 04, 2006, 11:45:04 AM »
Gary,
My code was derived from taking the first routine you posted apart & building it my way. :)
And the routine hyposmurf posted suffers the same problem with non-parallel lines.
Alan
« Last Edit: February 04, 2006, 11:48:14 AM by CAB »
LE
« Reply #12 on: February 04, 2006, 11:53:16 AM »
And how about design one to do it globally, instead of going in pair selections of lines ?
GDF
« Reply #13 on: February 04, 2006, 01:08:33 PM »
Allen, I see that now, kool.
Luis, I'm all for that.
GDF
« Reply #14 on: February 04, 2006, 01:13:05 PM »
Would it be better to make subfunctions local?
;;;Alan Butler 02/05/06
(defun c:glue  (/ flist slist f1pt f2pt s1pt s2pt flin slin fuzz p1 p2 p3 p4 overlap parallel)
  ;; determine if p1 & p4 are in the same direction
  (defun overlap (p1 p2 p3 p4) (equal (angle p2 p1) (angle p3 p4) 1.001))
  ;;  test for parallel   CAB 10/18/05
  (defun parallel  (ln1 ln2 / ang1 ang2 pfuzz)
    (if (= (type ln1) 'ename)
      (setq ln1 (entget ln1)
            ln2 (entget ln2)))
    (setq ang1 (angle (cdr (assoc 10 ln1)) (cdr (assoc 11 ln1))))
    (setq ang2 (angle (cdr (assoc 10 ln2)) (cdr (assoc 11 ln2))))
    (setq pfuzz 0.001)
    (or (equal ang1 ang2 pfuzz)
        ;;  Check for lines drawn in opposite directions
        (equal (min ang1 ang2) (- (max ang1 ang2) pi) pfuzz)))
  ;;  ***  Start of Routine  ***
  (if (and (setq flin (car (entsel "\n* Pick first Line *")))
    (progn (setq fuzz 0.01) ; alowable line endpoint gap
           (setq flist (entget flin))
           (setq slist (entget slin))
           (if (parallel flist slist)
             (progn (setq f1pt (cdr (assoc 10 flist)))
                    ;;  find end point match
                    (cond ((< (distance f1pt s1pt) fuzz)
                           (setq p1 f2pt ; start of new line
                                 p2 f1pt ; intersect of old lines
                                 p3 s1pt ; intersect of old lines
                                 p4 s2pt ; end of new line
                          ((< (distance f2pt s1pt) fuzz)
                           (setq p1 f1pt  p2 f2pt  p3 s1pt  p4 s2pt))
                          ((< (distance f1pt s2pt) fuzz)
                           (setq p1 f2pt  p2 f1pt  p3 s2pt  p4 s1pt))
                          ((< (distance f2pt s2pt) fuzz)
                           (setq p1 f1pt  p2 f2pt  p3 s2pt  p4 s1pt))
                          ((prompt "\n* Error, Lines not end to end *")))
                    (if p1
                      (if (not (overlap p1 p2 p3 p4))
                            ((equal p1 (cdr (assoc 11 flist)))
                             (setq flist (subst (cons 10 p4) (assoc 10 flist) flist)))
                            ((equal p4 (cdr (assoc 10 flist)))
                             (setq flist (subst (cons 11 p1) (assoc 11 flist) flist)))
                            ((setq flist (subst (cons 10 p1) (assoc 10 flist) flist)
                                   flist (subst (cons 11 p4) (assoc 11 flist) flist)))
                               (entmod flist) ; keeps the same properties of the first line
                               (entdel slin) ; second line is discarded
                        (prompt "\n* Error, Lines overlap, not end to end *"))))
             (prompt "\n* Error, Lines are not parallel * ")))
    (prompt "\n* Missed the pick *"))
  (princ))
(prompt "\nGlue Lines Loaded, Enter Glue to run.")
[edit: One More Time. Bug Fix 8:34pm  :)]
« Last Edit: February 05, 2006, 08:37:51 PM by CAB »
