Okay, a hypothetical situation:
Let's say I have a line that's set to layer "EXAMPLE" set to color "BYLAYER" and linetype "DASHED". However, I also have an arc set to layer "EXAMPLE" which is color "RED" and linetype "BYLAYER". And, on top of that, I have an ellipse set to layer "EXAMPLE" with color
and linetype set to "BYBLOCK". And, to top all of that off, the layer "EXAMPLE" has a linetype of "HIDDEN".
In the code posted so far, what will happen to those entities? Specifically, what will happen to those set to "BYLAYER" or "BYBLOCK"?
for each layer in this drawing layers collection, if its turned OFF (layeron=false) , make a selection set of ALL, then for each obj in SS, if the obj.Layer = ObjLayer.name (The name of the turned off layer), delete the object, repeat for next obj. Then delete layer from DB
PMFJI, but.....It seems to me this is the absolute slowest way of accomplishing this task and the next (frozen layers).Creating and stepping through a selection set of everything in the drawing for every layer that is off and again for every layer that is frozen.....
I thought the same thing when I looked at the code... partly why I was confused... but I was (and still am) willing to see where this is headed
...I just saw that explanation and felt obliged to comment, especially since it seems like Chuck is trying to learn from this.
* Jeff_M *back to lurk mode*
NO LURKING ALLOWED!
The more the merrier, I always say
