Author Topic: iCodeLibrary.NET  (Read 4411 times)
iCodeLibrary.NET
« on: January 27, 2006, 09:54:59 PM »
iCodeLibrary.NET is an application for C++, C#, Java, Visual Basic and other language developers..
The application allows you to store snippets of code in a hierarchical structure in a local database viewed in a treeview.
Code can be searched, exported to HTML, or XML for importing into other copies of the iCodeLibrary.NET.
http://www.imetasoft.com/iCodeLibrary/
Pretty good for starters ...
.. and it's Free ....
kdub in one timeline.
--> Donate to theSwamp<-
Re: iCodeLibrary.NET
« Reply #1 on: January 27, 2006, 10:09:02 PM »
USER TIP :
The current version can't backup the DataBase .. SO .. go into the C:\Program Files\iMetaSoft\iCodeLibrary.NET\DB folder  and make your own copy of the iCodeLibrary.mdb as required.
... and include that folder in your backup list < for whichever backup regime you use >
kwb
« Last Edit: January 27, 2006, 10:12:09 PM by Kerry Brown »
Troy Williams
« Reply #2 on: January 28, 2006, 08:25:44 AM »
That looks like a nice find. I am goint to try that out.
« Reply #3 on: January 28, 2006, 07:01:14 PM »
Yes, It seems OK Troy.
I was going to have a try at writing one, but I have too many unread books on my shelf.   ;-)
« Reply #4 on: January 28, 2006, 07:09:48 PM »
.. oh, and it works with Lisp code too, so ................
