Author Topic: more back ups... really  (Read 7574 times)
uncoolperson
« on: January 25, 2006, 04:19:48 PM »
so for some reason our drafters have issues with saving, really... and it doesn't get caught in time to use the back up files
so here's what i'm trying, the problem is that it keeps saving the backup of the file being closed with the filename of the drawing being opened...sometimes
(vlr-remove-all :VLR-DWG-REACTOR)
(VLR-DWG-REACTOR
  nil
  '((:VLR-BEGINCLOSE . saveacopy))
(DEFUN saveacopy (something somethingelse)
  (IF (NOT
(SETQ opened (OPEN (SETQ tempname (STRCAT (GETVAR "SAVEFILEPATH")
  (MENUCMD
    "M=$(edtime,$(getvar,date),mon-dd-yyyy-h-mmam/pm)"
  (GETVAR "DWGname")
   "r"
      (VLA-SENDCOMMAND
            (VLAX-GET (VLAX-GET-ACAD-OBJECT) "activedocument")
            (STRCAT "filedia " "0 " ".save\r" tempname "\r" "filedia " "1 ")
    (CLOSE opened)
any ideas
again i appologize this isn't the prettiest code...
Re: more back ups... really
« Reply #1 on: January 26, 2006, 12:54:03 AM »
(VLR-DWG-REACTOR
  nil
  (IF (NOT
  (MENUCMD
  (GETVAR "DWGname")
   "r"
      (VLA-SENDCOMMAND
    (CLOSE opened)
any ideas
a couple of things ;
(vlr-remove-all :VLR-DWG-REACTOR) .... What happens if there are other DWG-REACTOR's set in the drawing by other applications ?
(MENUCMD     "M=$(edtime,$(getvar,date),mon-dd-yyyy-h-mmam/pm)"  )
This may be better as yyyy-mm-dd...etc for file sorting.
uncoolperson
« Reply #2 on: January 26, 2006, 10:02:13 AM »
thanks, i really don't know why i didn't think of that... thanks for that catch kerry.
uncoolperson
« Reply #3 on: January 31, 2006, 12:06:10 PM »
so i went diging in the vlisp stuff (wow!) i'm still trying to figure all this mess out.. there's probably an easier way then 4 vlax-get's but by replacing
(GETVAR "DWGname")
with this
(STRCAT (VL-FILENAME-BASE
  (VLAX-GET (VLAX-GET (VLAX-GET (VLAX-GET (VLAX-GET-ACAD-OBJECT) "activedocument")
"views"
      "document"
    "fullname"
".dwg"
things seem to work better.... any better ideas?
pmvliet
« Reply #4 on: January 31, 2006, 12:37:30 PM »
you may also want to set your Autosave to something smaller like 4 minutes as well...
Pieter
Chuck Gabriel
« Reply #5 on: January 31, 2006, 12:49:28 PM »
(GETVAR "DWGname")
with this
"views"
      "document"
    "fullname"
".dwg"
could be shortened to:
(strcat (vl-filename-base
  (vla-get-fullname
".dwg"
uncoolperson
« Reply #6 on: January 31, 2006, 01:02:47 PM »
could be shortened to: ...
Thanks... that sure is prettier
the reason for this is the drafters here have found so many different ways to screw a drawing up beyond anything autosave could fix... and so far have been able to screw things up so that this is only going to help about 1/3 of the time!
