Author Topic: Attributes in Block Change Layer?  (Read 9338 times)
V-Man
  • I exist therefore I am! Finally Retired!
« on: January 20, 2006, 08:55:14 PM »
Ok,
I have many blocks, so I need a automated routine to search the drawing for a particular block, once found I need to get all of the attributes in the block layer to change to a different layer. How do I go around doing this?
AutoCAD 9 - 2023, AutoCADMap 2008 - 2010, Revit 2012 - 2022, Autocad Civil 3D 2023
V-Man
Re: Attributes in Block Change Layer?
« Reply #1 on: January 20, 2006, 09:38:18 PM »
Still stuck. I have tried this code but it does not seem to work..
(defun c:alcc ()
(setq attl(getstring "\nEnter new attribute layer: "))
(command "attedit" "y" "*" "*" "*" "c" pause pause)
(while
(= 1 (logand (getvar "cmdactive") 1))
(command "l" attl "n")
);;; end while
« Reply #2 on: January 20, 2006, 09:53:37 PM »
Hi Don,
Give this a whirl......
(defun c:att2layr (/ layr ss atts idx)
  (if (and (setq layr (getstring "\nLayer for attributes: "))
   (setq ss (ssget '((0 . "INSERT")(66 . 1))))
      (setq idx -1)
      (while (setq ent (ssname ss (setq idx (1+ idx))))
(setq atts (vlax-invoke (vlax-ename->vla-object ent) 'getattributes))
(foreach att atts
  (vla-put-layer att layr)
  ;;Note that there is no error trapping included in this example!
  ;;At the bare minimum, a check should be made for the existence of the destination layer.
V-Man
« Reply #3 on: January 21, 2006, 12:53:26 AM »
Great, Question, after running your code I explode the block and manually select on an attribute and when I do that it still says it's the old layer. Basically, I am trying to put all of the attributes of my block on a specific layer so that I may PURGE out the unwanted layers.
Crank
« Reply #4 on: January 21, 2006, 02:48:41 AM »
That's because the block defenition hasn't changed.
If you want to get rid of a layer without losing objects you can better use the LAYTRANS command, or use LYDELMRG.LSP from the express tools.
V-Man
« Reply #5 on: January 21, 2006, 10:28:38 AM »
Neither of these options will work. I have tried them with no success.  LayTrans will not work because the target layer that I want the attributes to be on already exist in the block itself. As for LayDel,  it will not work at all. I guess I need the block Definition to change so that I may purge out the unwanted layers.
Crank
« Reply #6 on: January 21, 2006, 11:36:03 AM »
It doesn't matter if the layer already exists.
If you want to use lisp, try this LayMerge routine.
It is a modified version of the LYDELMRG.LSP that came with Acad2004.
(laymerge "merge" "SourceLayer" DestLayer")
V-Man
« Reply #7 on: January 21, 2006, 11:44:05 AM »
Thanks Crank, that did work. Much appreciated...
TY
« Reply #8 on: January 21, 2006, 12:25:16 PM »
Ooops too late. :?
I just threw this together, but try it.
The block selection code needs work.
Exclude all but one or add code to step through the ss.
My code changes the block definition & jeff's changes all the Inserts.
(defun c:att2layr (/ layr ss atts idx bname blk)
    ((or (not (setq layr (getstring t "\nLayer for attributes: ")))
         (not (tblsearch "LAYER" layr))
     (prompt "\nERROR in layer name.")
    ((not (and
            (not (prompt "\nSelect the block to change."))
            (setq ss (ssget '((0 . "INSERT") (66 . 1))))
            (setq ent (ssname ss 0))
            (< (sslength ss) 2) ; only one pick allowed
     (prompt "\nERROR in block selection.")
    (t
     (setq ent (tblobjname "BLOCK" (setq bname (cdr (assoc 2 (entget ent)))))
           blk ent
     (setq entl (entget ent))
     (while (and ent
                 (/= "SEQEND" (cdr (assoc 0 (setq entl (entget ent)))))
       (if (= (cdr (assoc 0 entl)) "ATTDEF")
         (entmod (subst (cons 8 layr) (assoc 8 entl) entl))
       (setq ent (entnext ent))
     (entupd blk)
     ;;  Change the Inserts, by Jeff
     (setq ss (ssget "x" (list '(0 . "INSERT") '(66 . 1) (cons 2 bname))))
     (setq idx -1)
       (foreach att atts
CADaver
« Reply #9 on: January 21, 2006, 09:55:46 PM »
ummm...  refedit the block then attsync ??
« Reply #10 on: January 21, 2006, 10:13:15 PM »
In ACAD 2000 the refedit won't let you at the attributes to change the layer.
Or did I miss something?
Good to see ya Randy. :-)
CADaver
« Reply #11 on: January 21, 2006, 10:23:43 PM »
R2002 you get a dialog box that you check the "Display attributes definitions for editting" box and attributes become refeditable.  once complete use attsync to force all block instances to the new block definition.
« Reply #12 on: January 22, 2006, 01:07:49 AM »
Well that's just too easy. :-)
Peter Jamtgaard
« Reply #13 on: January 22, 2006, 05:36:17 PM »
It is pretty easy with lisp too
The syntax is (blockattlay "MyblockName" "NewAttributeLayer")
Peter
(defun BlockAttLay (strBlockName strLayerName / intCount entSelection objSelection ssSelections )
 (setq ssSelections (ssget "X" (list (cons 2 strBlockName))))
 (repeat (setq intCount (sslength ssSelections))
  (setq intCount     (1- intCount)
        entSelection (ssname ssSelections intCount)
        objSelection (vlax-ename->vla-object entSelection)
  (compoundObject objSelection strLayerName)
 (setq objBlock (vla-item
                 (vla-get-blocks
                  (vla-get-activedocument
                   (vlax-get-acad-object)
                 strBlockName
 (vlax-for objItem objBlock
  (if (= (vla-get-objectname objItem) "AcDbAttributeDefinition")
   (vla-put-layer objItem strLayerName)
(defun CompoundObject (objItem strLayerName / entItem2)
 (if (wcmatch (setq strObjectName (vla-get-objectname objItem))
     "AcDbBlockReference,AcDbMInsertBlock"
  (if (= (vla-get-hasattributes objItem) :vlax-true)
    (setq entItem2 (vlax-vla-object->ename objItem))
    (while (/= (cdr (assoc 0 (entget entItem2))) "SEQEND")
     (setq objItem2 (vlax-ename->vla-object entItem2))
     (vla-put-layer objItem2 strLayerName)
     (setq entItem2 (entnext entItem2))
gatorcadd
« Reply #14 on: January 22, 2006, 11:00:13 PM »
uh, wont battman do the same thing?  not the winged character...
i thought battman had a global editor in it.
