Author Topic: switching plot style paths  (Read 11614 times)
danny
« on: January 19, 2006, 08:38:08 PM »
I'm am using lisp to switch between client and company plot style paths.  the lisp will switch the support path correctly but requires shutting down AutoCAD for it to work properly.
Is there a way to add or change a support path/ plot style path w/o shutting down and reopenning ACAD.
Mahalo for your help
-danny
Chuck Gabriel
Re: switching plot style paths
« Reply #1 on: January 19, 2006, 10:07:42 PM »
Are you modifying the registry directly, or are you working with the preferences object?
danny
« Reply #2 on: January 19, 2006, 10:52:04 PM »
options
file
Printer Support File Path
Plot Style Table Search Path
(setenv "PrinterStyleSheetDir" "M:\\_Cad Support\\AutoCAD 2004\\Client_CTB")
path is changed correctly but ctb wont work unless ACAD is shutdown and reopened.
pmvliet
« Reply #3 on: January 19, 2006, 11:01:35 PM »
Danny,
That works for me w/o having to get out of AutoCad.
Pieter
Chuck Gabriel
« Reply #4 on: January 20, 2006, 07:55:02 AM »
(setq prefs (vla-get-preferences (vlax-get-acad-object))
      filePrefs (vla-get-files prefs)
(vla-put-printerstylesheetpath filePrefs "c:/plot styles")
danny
« Reply #5 on: January 20, 2006, 02:40:05 PM »
chuck,
the code you provided works to the point of doing the plot.
example:
if I'm currently in a drawing and have my plot style path browsing to "m:/plot styles"
then I use your code,
I will now be browsing to "c:/plot styles" :-)
but when I do a plot, the ctb's will show up as color in preview and when printing. :-(
AutoCAD isn't reading the ctb correctly and takes exiting ACAD and reentering to work.
pmvliet,
when you used the code, did the plot preview show up correctly as well as the print?
« Reply #6 on: January 20, 2006, 08:24:15 PM »
Danny,
Using Chuck's code, try adding
(vla-refreshplotdeviceinfo
  (vla-get-activelayout
   (vla-get-activedocument
     (vlax-get-acad-object))))
Quote from: AcadHelp
Updates the plot, canonical media, and plot style table information to reflect the current system state.
edited to fix my inadvertent "test" line, props to Tim W for finding it....
« Last Edit: January 27, 2006, 07:29:37 PM by Jeff_M »
danny
« Reply #7 on: January 27, 2006, 06:30:17 PM »
jeff,
got a error message
"no function definition: VLAX-GET-ACAD-DOCUMENT"
this is the code I used
(defun c:AHLCTBD ()
(setq prefs(vla-get-preferences (vlax-get-acad-object))
      filePrefs(vla-get-files prefs))
(vla-put-printerstylesheetpath filePrefs "M:\\_Cad Support\\AHL_CTB")
     (vlax-get-acad-document))))
(alert "Notice:\nYou are now using AHL standard CTB's")
« Reply #8 on: January 27, 2006, 06:46:29 PM »
Edit
Change it to
(vlax-get-Acad-Object)
instead of
(vlax-get-Acad-Document)
« Reply #9 on: January 27, 2006, 07:26:55 PM »
Oops!  :oops: Tim caught the "test" I put in there...... :roll:
« Reply #10 on: January 27, 2006, 07:36:14 PM »
Almost got by me.  I put the standard reply to that type of error
Add (vl-load-com), that should fix it.
Then I saw that it didn't look right.
Nice test Jeff.   :evil:
danny
« Reply #11 on: January 30, 2006, 03:40:00 PM »
thanks guys,
The search path is changed correctly but I'm still having to close and reopen ACAD for the ctb's to work correctly.
It must be something ACAD is doing @ startup.
deegeecees
« Reply #12 on: January 30, 2006, 03:43:59 PM »
<guess> convertpstyles </guess>
« Reply #13 on: January 30, 2006, 03:55:04 PM »
thanks guys,
I have heard this happening when you change things in the registry.  I haven't heard of a fix/workaround yet. :cry:  I will keep my ears (eyes) open for any suck fix/workaround.
danny
« Reply #14 on: January 30, 2006, 04:12:38 PM »
(vl-registry-read)????
