Author Topic: Division Precision  (Read 2440 times)
Division Precision
« on: January 19, 2006, 02:12:40 PM »
Why is this rounding the answer down instead of putting the correct decimal place?
  (setq ss1 (ssget '((0 . "LWPOLYLINE") (8 . "0280-shrub-lateral"))))
  (setq ss1 (sslength ss1))
  (alert (rtos(/ ss1 30)2 2))
For example sslength of ss1 = 88. The number returned after being divided by 30 is 2.00 rather than 2.93?
Thanks,
Ron
Re: Division Precision
« Reply #1 on: January 19, 2006, 02:24:33 PM »
If you divide by an intergers, then the returned value will be an interger, so changing one of the numbers to a real will return a real.
Change
(/ ss1 30)
to
(/ ss1 30.0)
And you should get what you want.
« Reply #2 on: January 19, 2006, 02:33:57 PM »
Thanks :). It's all those little things that kill me! :realmad:
« Reply #3 on: January 19, 2006, 02:51:38 PM »
You're welcome.  I hate learning those the hard way also.
