Author Topic: Xref 2 Block  (Read 19265 times)
Re: Xref 2 Block
« Reply #45 on: January 23, 2006, 02:15:57 PM »
Thanks Tim
; error: no function definition: OBJMATRIX
Gary
What I fixed was soemthing I saw in a code by Joe Burke.  When he got the answer (matrix) from the function "ObjMatrix" he turned it into a variant, and then passed the variant to (vla-transformedby.... , and that seemed to work here also.  Make sure you have the lisps that he provided loaded, or it will error.
GDF
Re: Xref 2 Block
« Reply #46 on: January 23, 2006, 02:24:52 PM »
Thanks Tim
I found the function from the previous post.
WORKS GREAT.
Thank You....and my coworker thanks you.
Gary
Re: Xref 2 Block
« Reply #47 on: January 23, 2006, 02:29:03 PM »
So you didn't have any problems after running it?  Your CAD didn't crash?
That is cool.  My setup here is a little weird, but that is how the company wants it.  Glad it works for you.
You're welcome, and so is Frank.
GDF
Re: Xref 2 Block
« Reply #48 on: January 23, 2006, 02:44:09 PM »
Works great in 2006, with no problems. I will add a warning and instruction message to display before the routine is run.
WOW this is great. We will be using this all of the time now. Thank you.
Gary
GDF
Re: Xref 2 Block
« Reply #49 on: January 23, 2006, 02:48:36 PM »
Sorry, I forgot to thank Joe Burke for his help.
Gary <with a big smile on my face>.
Joe Burke
Re: Xref 2 Block
« Reply #50 on: January 24, 2006, 04:12:40 AM »
Hey Joe,
  Thanks for the Matrix codes.  I have been working one some (trying to understand them) and I came up with the same rotation calculations that you did, and they both don't seem to work correctly.  Maybe I'm using them wrong I don't know.  What I'm doing here is:
I get all the objects from the selected xref.
I copy them into the current drawing, into a new block definition.
I then apply the functions you provided to the xref selected.
I then apply the returned matrix to each object.
I then insert the block, hoping that it matches what is on the screen now
but the rotation is wrong, but the scaling is right.
What am I doing wrong?
Thanks in advance.
Hi Tim,
I'm replying to the above and your later message after you found the solution.
I don't understand. Are you saying you did not get an error when the vlax-tmatirx function was not included? Just that the result was incorrect? if so, that is strange. I would expect TransformBy to choke without the conversion vlax-tmatrix does.
Were you doing this: (vlax-invoke obj 'TransformBy <raw matrix>)? I haven't tried it. I guess there's a chance TransformBy, called that way, might accept that.
Joe Burke
Re: Xref 2 Block
« Reply #51 on: January 24, 2006, 04:13:52 AM »
Gary,
My pleasure.
Re: Xref 2 Block
« Reply #52 on: January 24, 2006, 11:03:30 AM »
I got no error when (vlax-invoke obj 'TransformBy <matrix list <of list>>).  It would rotate, but it would rotate the wrong way.  Not sure why that happened, but switching to (vla-TransformBy obj (vlax-tmatrix <matrix list <of list>>)) worked.
Thanks again for the codes Joe.
