Author Topic: Managed Or Unmanaged  (Read 4083 times)
« on: January 17, 2006, 08:37:00 PM »
Is Managed Code Slower Than Unmanaged Code?
I thought this was interesting enough to link to :
http://www.grimes.demon.co.uk/dotnet/man_unman.htm
LE
Re: Managed Or Unmanaged
« Reply #1 on: January 17, 2006, 10:46:00 PM »
Here is a link to a similar topic I started here:
http://discussion.autodesk.com/thread.jspa?threadID=446934
To bad I do not know how to write the unmanaged part for my application, that can be an excellent example, to test speed and performance.... maybe in about two or three months I would have something.... I hope.
