When the new AutoCAD 2007 release comes out what new features would you like to see?Few things I'd like to see:
Better object selection methods.Like the match properties command button, but one used to match all similar objects to add to your selection.Would be neat to be able to adjust what properties can be added to your selection set via a pop up,like by colour,by block,lines,text etc.Similar idea to the QSELECT command but have it working within in a command for a selection set.You can create your own groups and filters but its not a speedy way of doing things,plus you dont always know you need to select simlar objects until the need arises.
Either do something usefull with the comm centre or just get rid of it.
An improved spell checker one that can bring me to the text in my drawing should I desire,its often hard to know what some words relate to.
Improved intergration with PDF products
Improved translation of drawings from Microstation.More at Microstations end I know but the behaviour of some ex microstation drawings often raises a few eyebrows.
Being able to record macros as you can in Microsoft Word etc
A neater enhanced attribute editor.
Cant think of any more at the moment.I'm on 2004 so its possible some of these have been incorporated in 2005/6
