Author Topic: pelton wheel  (Read 11834 times)
pelton wheel
« on: January 05, 2006, 02:08:04 PM »
Does anyone know where I might obtain a 3d solid model of a pelton wheel ... if you don't know what one is, then you probably don't know where I can get one ...
deegeecees
Re: pelton wheel
« Reply #1 on: January 05, 2006, 02:19:50 PM »
I could make one for you, just give me some specs.
Re: pelton wheel
« Reply #2 on: January 05, 2006, 02:40:42 PM »
The only specs I really care about is that it needs to be 3" in diameter ... the number and size of buckets should be appropriate for the diameter.
deegeecees
Re: pelton wheel
« Reply #3 on: January 05, 2006, 02:52:28 PM »
Will this be for graphic representation only? Reason: I'm not going to spend too much time on it, just something rudimentary. Is this copacetic?
Re: pelton wheel
« Reply #4 on: January 05, 2006, 03:03:52 PM »
Actually it will be used to model a minature version for a science project ... I could not find anything anywhere that would allow me to actually dimension and build the thing. .. so I guess the answer is that it doesn't need to be too elaborate, if I knew the size in relation to the diameter (i.e. number of buckets, spacing of buckets, thickness of material) then I would model one myself ...
paulmcz
Re: pelton wheel
« Reply #5 on: January 05, 2006, 03:12:06 PM »
I only have 2D real thing in outlines. 162+ inch in diameter, 22 buckets. Do you want it?
Troy Williams
Re: pelton wheel
« Reply #6 on: January 05, 2006, 03:13:13 PM »
Are these links of any help:
http://en.wikipedia.org/wiki/Pelton_wheel
http://home.clear.net.nz/pages/coote/pelton.html  <-this one has some dimensions
deegeecees
Re: pelton wheel
« Reply #7 on: January 05, 2006, 03:50:29 PM »
Yeah, troy I Googled it too. Keith, I'd be learning just the same as you, so unless you really absolutely need me to do this, I'd rather focus the rest of my attention today here at work on actual "billable" work. I was under the impression that you weren't familiar with 3D and I just wanted to lend a hand. Trying to keep my resolution.
Re: pelton wheel
« Reply #8 on: January 05, 2006, 04:15:26 PM »
Paul, if it is something that will give me a clear understanding of the relational sizes or the different components that would be great ...
paulmcz
Re: pelton wheel
« Reply #9 on: January 05, 2006, 04:32:02 PM »
Keith, check your "rr" mail.
