Set it up on one. Create a profile for it. Export the profile and load it on another machine as a test. If everybody's machine looks the same, you can load this profile up on everybody's machine, but if each person has a different flavor for how autocad looks, you might want to create and export profiles for each and then... That might be too much for 50 machines. Go with the first idea, then if they want to change the look back, they can do it manually. I wonder if there's a way to do it programmatically? The arg file is built like a registry file. You could have everybody's profile exported, then change each one programmatically, by copying the registry section on yours and replacing the section in each of the other profiles.
