Serge,
That mapcar function works great
realy neat...I didn't get it the first goround.
Yes I had the double pipe to see what it would return I to see if it would crash the
routines, it did not & returned as expected an empty string.
Stig,
Wow, just down loaded the sys var routine and i'll check it out. The dialog box
is well laid out , looks great. I'll dive ito the code today. I've downloaded from you site
several times in the past, but as I grow in lisp terms I need to revisit there as you pointed out.
I have left you url & the swamp several times (@ autodesk) when people ask how to get started lisping.
XML? You know I should have kept reading that thread but being time crunched & see no
immmediate need I put it on the back burner & obviously forgot about it
Just what I need more homework...
I'll be back.......CAB
