Author Topic: Attribute change  (Read 21240 times)
Biscuits
Re: Attribute change
« Reply #15 on: January 03, 2006, 05:56:41 PM »
Cab your awsome! Just what I was Looking for! Works perfect! Many thanks!
And many thanks to all who have tried to help!!!!!!!!!
The Swamp Rocks!!!!!!!!
deegeecees
« Reply #16 on: January 03, 2006, 05:59:27 PM »
By the way, what is that Avatar yer using?
Its Lil' Ozzie, my first 3DStudio creation.
deegeecees
« Reply #17 on: January 03, 2006, 06:02:30 PM »
Yes, CAB you truly do rock! I'm gonna have to give you a C- on your notation though...
<MP>Adusting score card</MP>
« Reply #18 on: January 03, 2006, 06:06:11 PM »
Nice one CAB.  I was wondering how you would get the attribute if it was nested.  I see that you have to go through the blocks collection, and edit it there.  Nice to know.
« Reply #19 on: January 03, 2006, 06:28:45 PM »
Alan, I'd only advise 2 things.......(ssget "x") obtains the desired objects on ALL tabs, so when you step through the Blocks collection in place of the Model_Space check I would omit those that have the IsLayout = true. Otherwise you are stepping through those blocks twice.
Second, you could replace this:
(and (setq obj (vlax-ename->vla-object ent))
               (= (vla-get-objectname obj) "AcDbBlockReference")
               (= (vla-get-hasattributes obj) :vlax-true)
with
by filtering your SS like so:
(setq ss (ssget "_X" '((0 . "INSERT")(66 . 1)))
The 66 . 1 will filter for attributed blocks so no att check is needed.
just my 2 cents.....
« Last Edit: January 03, 2006, 06:33:05 PM by Jeff_M »
« Reply #20 on: January 03, 2006, 06:31:31 PM »
Editted : ^ ^ What he said ^ ^
Jeff types too quickly for me ..
Nice job Alan.
« Reply #21 on: January 03, 2006, 06:44:34 PM »
What notation :-D
« Reply #22 on: January 03, 2006, 07:00:11 PM »
OK, thanks for the info Jeff.
I'm starting to understand a little more on the block collections
Here is the revised code.
;;=======================[ cUpdate.lsp ]=======================
;;; Author: Copyright© 2006 Charles Alan Butler
;;; Version:  1.1 Jan. 03, 2006
;;; Purpose: To update attributes in a drawing, nested blocks & xref
;;;          Ignores locked or Frozen layers
;;; Sub_Routines: -None
;;; Requirements: -None
;;; Returns: -None
(defun c:cupdate (/ ss ent obj att blks newtext taglist)
  (setq newtext "2006 C-n-R CORPORATION"
        taglist '("COPYRIGHT" "COPYRIGHTYEAR"))
  (or *doc* (setq *doc* (vla-get-activedocument (vlax-get-acad-object))))
  (if (< 0 (vla-get-count (setq blks (vla-get-blocks *doc*))))
      (vlax-for blk blks
        (vlax-for ent blk
          (if (and (vlax-property-available-p ent 'hasattributes)
                   (= (vla-get-hasattributes ent) :vlax-true)
              (foreach att (vlax-invoke ent 'getattributes)
                (if (member (vla-get-tagstring att) taglist)
                  (vla-put-textstring att newtext)
      (vla-regen *doc* acactiveviewport)
(prompt "\nCopyright Update Loaded, Enter cupdate to run.")
« Last Edit: January 03, 2006, 07:09:33 PM by CAB »
LE
« Reply #23 on: January 03, 2006, 07:12:56 PM »
Are almost ALL the blocks in the collection in need to be updated?
Why not making a normal selection set with SSGET and the filter, and then just use the active selection set ?
« Reply #24 on: January 03, 2006, 07:16:40 PM »
Well the attribute in question could be in a block
or in a block within a block
or in a block within an xref
So i had a problem with the block within an xref. That is getting to it with ssget.
ssget finds the xref but not the nested block with the attribute.
LE
« Reply #25 on: January 03, 2006, 07:23:07 PM »
I see it now , sorry...
« Reply #26 on: January 03, 2006, 07:38:29 PM »
No problem Luis.
Thanks all, I can't take all the credit.
I borrowed code from Jeff's c:txt2std routine
and some from Kerry's routines. :)
« Reply #27 on: January 03, 2006, 07:51:49 PM »
I'm having a hard time understanding this part......If it's in an Xref you can't permanently change that  unless you edit the Xref drawing..... and even if you could, I would still use the (ssget) to get the Model/Paper space inserts w/attributes, then loop through the blocks collection examining only those non-Layout blocks. If you want to change the Xref, ObjectDBX will need to be added.......
Or am I missing something obvious..... ?
« Reply #28 on: January 03, 2006, 08:09:55 PM »
I doubt you are missing anything. I didn't check the xref to see if the change was in that drawing.
I could not get the ssget to pick up the nested block. The test I did rejected the block as not having attributes.
I'll have to get back to this tomorrow when I can dig a little deeper to understand the non-layout issue.
Thanks Jeff
« Reply #29 on: January 03, 2006, 10:03:07 PM »
OK, Jeff.
If I do it this way with (if (= (vla-get-islayout blk) :vlax-false)
the plain blocks with attributes are overlooked as they are within the
model space block.
The nested block with attributes within a block and the xref are updated.
So without the exclusion the routine looks into each model & PS block to get
each insert with attributes.
What is the concern doing it this way? Too slow in a large drawing?
      (vlax-for blk blks
         (if (= (vla-get-islayout blk) :vlax-false) ; exclude model & PS blockobjects   <-----<<<<< Oops , had this in the wrong spot
       (vlax-for ent blk
Edit: move the if statement.
« Last Edit: January 03, 2006, 10:46:19 PM by CAB »
