Author Topic: ? About ghosting and ins point  (Read 4576 times)
TimSpangler
  • CAD Naked!!
« on: December 29, 2005, 10:14:15 AM »
I am playing aroung with grread, grdraw, grvecs, to become more familiar and to hopefully learn something new.  THis is my first time attempting drawing to the drawing area.  I am triing to draw a simple square to the drawing area using grread to get the cursor position and ghost the image to the cursor as i drag around the drawing area.  Now how do I select an insertion point and have the square follow the cursor?  I want the square to rotate around the the insertion point till I pick the last point?
Any code examples that I can study will be greatly appreciated.
TIA
ACA 2015 - Windows 7 Pro
I've reached the age where the happy hour is a nap. (°ż°)
uncoolperson
Re: ? About ghosting and ins point
« Reply #2 on: December 29, 2005, 10:56:13 AM »
(DEFUN c:testbox (/ pt1)
  (drawabox (SETQ pt1 (GETPOINT)) (GETCORNER pt1) 5)
(DEFUN drawabox (point1 point2 clr / todraw yval xdist ydist)
  (SETQ todraw nil)
  (SETQ xdist (ABS (- (CAR point1) (CAR point2))))
  (SETQ ydist (ABS (- (CADR point1) (CADR point2))))
  (SETQ yval 0.025)
  (WHILE (< yval ydist)
    (SETQ todraw (APPEND todraw
(LIST clr
       (plus point1 (LIST 0 yval 0))
       (plus point1 (LIST xdist yval 0))
    (SETQ yval (+ yval 0.025))
  (SETQ xval 0.025)
  (WHILE (< xval xdist)
(LIST clr
       (plus point1 (LIST xval 0 0))
       (plus point1 (LIST xval ydist 0))
    (SETQ xval (+ xval 0.025))
  (GRVECS todraw)
(DEFUN movingbox (dimx dimy xoff yoff clr / endpt thepoint)
  (WHILE (= 5 (CAR (SETQ endpt (GRREAD T 5 1))))
    (REDRAW)
    (drawabox (SETQ thepoint (plus (LIST xoff yoff 0) (CADR endpt)))
      (plus thepoint (LIST dimx dimy 0))
      clr
  (CADR endpt)
here's my box fun, you could probably find some rotation matrix stuff somewhere on here, or google it..
GDF
« Reply #3 on: December 29, 2005, 11:31:29 AM »
Need your PLUS finction.
Gary
GDF
« Reply #4 on: December 29, 2005, 11:35:25 AM »
Heres one:
(defun c:test  ()
  (setq time T)
  (while time
    (setq drag (grread t 1 1))
    (cond ((= (car drag) 5) ;<- moving cursor
           (setq ghostpt (cadr drag))
           (setq pt1 (polar ghostpt 0.0 5.0))
           (setq pt2 (polar ghostpt (* pi 1.5) 5.0))
           (setq pt3 (polar pt2 0.0 5.0))
           ;;(setq pt4 (polar ghostpt (* pi 1.5) 5.0))
           (redraw) ; draw vectors
           (grvecs (list 7 ghostpt pt1   7 pt1 pt3   7 pt3 pt2   7 pt2 ghostpt))
          ((= (car drag) 3) ;<- picked point
           (redraw) ; draw what you preview
           (command "._line" ghostpt pt1 pt3 pt2 "_C")
           (setq time nil)))))
Gary
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« Reply #5 on: December 29, 2005, 12:10:59 PM »
... you could probably find some rotation matrix stuff somewhere on here, or google it..
This is some code that I was working on for an article on the site a couple of years ago and ended up dropping it before it was complete.  It's in terrible shape and nearly impossible to follow, but *maybe* you can glean something useful out of it  :|
I left off just before I got to the part of having the ghosted objects follow the cursor.  From a high level perspective, what you'll have to do is capture the cursor position, compare it to the previous position, and transform the objects from the old to the new position.  I have yet to do this in LISP, but I have done it in .NET.  You can see that code over in the .NET list, http://www.theswamp.org/forum/index.php?topic=8195.0 and http://www.theswamp.org/forum/index.php?topic=8198.0
This is the main function
Type "DrawShape" to start the command.
(defun c:drawShape (/ basePt    rotation  grInput   grRetVal  sFac
                    dragPnt   vector    matrix    pMatrix   Color
                    pColor    ptLst     shape     *error*
  (defun *error* (msg)
    (if (not
          (member
            Msg
            '("console break"
              "Function cancelled"
              "quit / exit abort"
        (princ (strcat "\nError #" (itoa (getvar "ERRNO")) ": " Msg)
        (setvar "ERRNO" 0)
    ;;erase last vectors
    (if pMatrix
      (grDrClosedShape pColor ptLst pMatrix)
  (initget "Rectangle1 rEctangle2")
  (setq shape  (getkword "\nShape to draw [Rectangle1/rEctangle2] <Rectangle1>")
        shape
                 ((equal shape "rEctangle2") 'rectangle2)
                 (t 'rectangle1)
        basePt (getpoint "\nSelect point: ")
  (if basePt
      (setq sFac    (/ (car (getvar "SCREENSIZE")) 1000)
            vector  (mapcar '- basePt)
            ptLst   ((eval shape) basePt)
            grInput 5
      ;;Loop while user moves mouse
      (while (= grInput 5)
        ;;get data from GRREAD
        (setq grRetVal (grread t 5 0)
              grInput  (car grRetVal)
              dragPnt  (cadr grRetVal)
              rotation (angle basePt dragPnt)
              color    300
              ;;Build Transformation matrix from data
              matrix   (bldTformMatrix
                         (list
                           (TranslateMatrix basePt)
                           (ScaleMatrix (/ (distance basePt dragpnt) sFac))
                           (TranslateMatrix Vector)
                           (RotateZMatrix rotation)
        ;;erase previous vectors
        (if pMatrix
        ;;Draw vectors
        (grDrClosedShape Color ptLst Matrix)
        ;;Save current grvecs information
        (setq pMatrix matrix
              pColor  Color
      (command "_.pline")
      (foreach pt (transPts ptLst Matrix)
        (command pt)
      (command "_C")
This helper function will grdraw a closed shape
;;;Draw closed shape with GRVECS
;;;(grDrClosedShape 7 '((1 1) (2 1) (2 2) (1 2)) myMatrix)
(defun grDrClosedShape (color ptLst matrix)
  (grvecs
    (append
      (list color)
      (cdr
        (apply
          'append
          (mapcar
            '(lambda (pt)
               (list pt pt)
            ptlst
      (list (car ptLst))
    matrix
These functions define a couple of closed rectangles.  You can create others and pass them to the grDrClosedShape() function.  They do not have to be rectangles.
;;;Define the shape of the vectors to draw
;;;via a list of points as they relate to a supplied
;;;base point.  This is a rectangle with the
;;;base point being the lower left corner.
(defun Rectangle1 (pt / x y xVect yVect)
  (mapcar '(lambda (val var) (set var (/ val 1000.0)))
          '(xVect yVect)
  (setq x (car pt)
        y (cadr pt)
  (list
    pt                                  ;LL
    (list (+ x xVect) y)                ;LR
    (list (+ x xVect) (+ y yVect))      ;UR
    (list x (+ y yVect))                ;UL
;;;This is a rectangle with the base point being the
;;;center of the rectangle.
(defun Rectangle2 (pt / x y hxVect hyVect)
          '(xVect yVect)
  (setq x      (car pt)
        y      (cadr pt)
        hxVect (* 0.5 xVect)
        hyVect (* 0.5 yVect)
  (list
    (list (- x hxVect) (- y hyVect))    ;LL
    (list (+ x hxVect) (- y hyVect))    ;LR
    (list (+ x hxVect) (+ y hyVect))    ;UR
    (list (- x hxVect) (+ y hyVect))    ;UL
These are the Matrix helper functions
;;;Special thanks to Vladimir Nesterovsky
;;;for these four matrix manipulation routines
;;;a dot product of the two vectors, u & v
(defun dotprod (u v)
  (apply '+ (mapcar '* u v))
;;;transpose a matrix
;;;code by doug Wilson
(defun transpose (m)
  (apply 'mapcar (cons 'list m))
;;;Apply a transformation matrix to a vector
(defun mxv (m v)
  (mapcar '(lambda (row) (dotprod row v))
          m
;;;Multiply two matrices
(defun mxm (m q)
  (setq q (transpose q))
  (mapcar '(lambda (row) (mxv q row))
          m
;;;Scale matrix
;;;We add error handling to this matrix to
;;;ensure that we never have a zero scale factor.
;;;It accepts a single scale factor for the
;;;X, Y, & Z or a list of factors in the order
;;;of '(X Y Z).
;;;(ScaleMatrix 3.5)
;;;(ScaleMatrix '(3 2 1))
(defun ScaleMatrix (Scale / ScaleX ScaleY ScaleZ)
  (mapcar
    '(lambda (var scl)
       (if (zerop scl)
         (set var 1)
         (set var scl)
    '(ScaleX ScaleY ScaleZ)
    (if (listp scale)
      Scale
      (list Scale Scale Scale)
  (list (list ScaleX 0 0 0)
        (list 0 ScaleY 0 0)
        (list 0 0 ScaleZ 0)
        (list 0 0 0 1)
;;;Rotate about Z axis
;;;Rotation to be supplied in radians
;;;(RotateZMatrix (* pi 3.33))
(defun RotateZMatrix (Rot)
  (list (list (cos Rot) (- (sin Rot)) 0 0)
        (list (sin Rot) (cos Rot) 0 0)
        (list 0 0 1 0)
        (list 0 0 0 1)
;;;Translate Matrix
;;;Vector is a list of values
;;;in the order of '(X Y Z) to
;;;move a point
;;;(TranslateMatrix '(3 4 0))
(defun TranslateMatrix (Vector)
  (list (list 1 0 0 (car Vector))
        (list 0 1 0 (cadr Vector))
        (list 0 0 1 (caddr Vector))
        (list 0 0 0 1)
;;;Apply a 3d Transformation matrix
;;;to a list of points.  Points can
;;;be 2d or 3d points.
;;;(TransPts '((1 1 0) (2 3 0) (1 3 0)) (ScaleMatrix 2))
(defun TransPts (ptLst Matrix)
  (mapcar
    '(lambda (pt / ptDim)
       (setq ptDim (length pt)
             pt
                   (if (= ptDim 3)
                     (reverse (cons 1 (reverse pt)))
                     (reverse (cons 1 (cons 0 (reverse pt))))
       (reverse
         (apply
           (if (= ptDim 3)
             'cdr
             'cddr
           (list
             (reverse
               (mxv Matrix pt)
    ptLst
;;;Combines multiple Matrices into a single matrix
;;;(bldTformMatrix (list (ScaleMatrix 2) (TranslateMatrix '(2 2 0))))
(defun bldTformMatrix (matrixLst / TformMatrix)
  (foreach matrix matrixLst
    (setq TformMatrix
           (if TformMatrix
             (mxm TformMatrix matrix)
             matrix
Here is another example using some of the same helper functions.  This one allows you to create a selection set by defining a rectangular area that you can scale and rotate by moving the cursor.
Type "CS" at the command line to start it.
;;;Crazy Select!
(defun c:cs ()
  (ax:cs rectangle1)
(defun ax:cs (shape     /         basePt    rotation  grInput
              grRetVal  sFac      dragPnt   vector    matrix
              pMatrix   sMethod   Color     pColor    ptLst
              ss        *error*
    (if (not
          (member
            Msg
            '("console break"
              "quit / exit abort"
        (princ (strcat "\nError #" (itoa (getvar "ERRNO")) ": " Msg))
        (setvar "ERRNO" 0)
    (if pMatrix
  (if (setq basePt (getpoint "\nSelect point: "))
            ptLst   (shape basePt)
            grInput 5
        (setq grRetVal (grread t 5 1)
              sMethod  (cond
                         ((< (* 0.5 pi) rotation (* 1.5 pi))
                          "_CP"
                         (t "_WP")
              color    (if (equal sMethod "_WP") 300 -300)
                         (list
        (if pMatrix
        ;;Draw vectors
              pColor  Color
      ;;Transform points according to last matrix
      (setq ss (ssget sMethod (transPts ptLst Matrix)))
Bobby C. Jones
TimSpangler
  • CAD Naked!!
« Reply #7 on: December 29, 2005, 01:08:36 PM »
Thanks guys,
That sure gves me alot of things to digest.  With everything that was posted I am sure I can learn something from all of this.
CAB,  I have been checking out MP Ghosting routines to great extent, that is kinda what put me on this track of wanting to learn to draw to the drawing area.
Bobby,  I like what you posted,  It is actually more than what I was looking for,  It scales and rotates :-o  It will take me some time to digest it.  If I have any question regarding this I'll be sure to post them in this thread.
Gary,  Thanks for your take, that is where I am right now, I have a shape but now I want to rotate or scale it before it is stuck to the drawing area.
Uncoolperson,  I believe you need to post your (Plus) function.
Thanks guys
« Reply #8 on: December 29, 2005, 01:35:00 PM »
Bobby,
Thanks for the routines. Very interesting.
I noted that in ACAD2000 there is a problem. I altered the color to 4 ILO 300
but still the rectangle is offset from the first pick point
The offset appears to be +1772 units on the x-axis.
all is fine in ACAD2004.
uncoolperson
« Reply #9 on: December 29, 2005, 01:39:28 PM »
i keep on doing that
(DEFUN plus (v1 v2) (MAPCAR (FUNCTION +) v1 v2))
(it's not mine... i stole it)
GDF
« Reply #10 on: January 01, 2006, 11:26:24 AM »
Try this one.....and have fun.
Uses:
GRCLEAR
GRREAD
Gary
