Author Topic: AU 2005 code - Part 8 "Database events"  (Read 12450 times)
Re: AU 2005 code - Part 8 "Database events"
« Reply #15 on: January 01, 2006, 11:20:10 PM »
Yes, Glenn .. that code works a treat for me.
ta
kwb
kdub in one timeline.
--> Donate to theSwamp<-
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« Reply #16 on: January 03, 2006, 05:17:45 PM »
Bobby,
Thanks for the handler examples.
Do you have any notes prepared to accompany the code. I can imagine that event handling will be something that gets a lot of attention in the future. There are a couple of concepts tied up in the code that may require explanation for the casual reader.
Kerry,
I didn't prepare any notes for the class.  This example was to be a filler, just in case I needed it.
Bobby C. Jones
