Author Topic: AU 2005 code - Part 6 "Doin' the Jig"  (Read 4659 times)
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« on: December 28, 2005, 02:53:00 PM »
or dynamic graphics, or ghosting, or whatever you want to call it.  This example will "ghost" a circle around your crosshair.
To create a custom Jig you must subclass from one of the available Jig classes.  Depending on the class that you derrive from there will be a number of methods that you must override.  This class is derrived from the DrawJig class and the Sampler and WorldDraw methods are overriden.
using System;
using Autodesk.AutoCAD.GraphicsInterface;
namespace AU2005.AcadApi
//Pages 12 & 13
//New class derrived from the DrawJig class
public class JigExample : DrawJig
#region private member fields
private Point3d previousCursorPosition;
private Point3d currentCursorPosition;
private Entity entityToDrag;
#endregion
[CommandMethod("StartJig")]
public void StartJig()
//Initialize cursor position
//Use the geometry library to create a new 3d point object
previousCursorPosition = new Point3d (0,0,0);
entityToDrag = new Circle(new Point3d(0,0,0), new Vector3d (0,0,1), 6);
Application.DocumentManager.MdiActiveDocument.Editor.Drag(this);
//You must override this method
protected override SamplerStatus Sampler(JigPrompts prompts)
//Get the current cursor position
PromptPointResult userFeedback = prompts.AcquirePoint();
currentCursorPosition = userFeedback.Value;
if (CursorHasMoved())
//Get the vector of the move
Vector3d displacementVector = currentCursorPosition.GetVectorTo(previousCursorPosition);
//Transform the circle to the new location
entityToDrag.TransformBy(Matrix3d.Displacement(displacementVector));
//Save the cursor position
previousCursorPosition = currentCursorPosition;
return SamplerStatus.OK;
else
return SamplerStatus.NoChange;
protected override bool WorldDraw(WorldDraw draw)
draw.Geometry.Draw(entityToDrag);
return true;
private bool CursorHasMoved ()
return !(currentCursorPosition == previousCursorPosition);
Bobby C. Jones
