Author Topic: AU 2005 code - Part 4 "Single entity selection"  (Read 4784 times)
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« on: December 28, 2005, 02:35:38 PM »
using System;
namespace AU2005.AcadApi
//Page 10
public class GetEntityExample
[CommandMethod("GetCircle")]
public void GetEntity ()
Editor currentEditor = Application.DocumentManager.MdiActiveDocument.Editor;
//Create a new entity selection options object and
//restrict it to selecting circles only
PromptEntityOptions entitySelectionOpts = new PromptEntityOptions("\nSelect Circle: ");
entitySelectionOpts.SetRejectMessage("\nOnly Circles may be selected.");
entitySelectionOpts.AddAllowedClass (typeof (Circle), true);
//Start the selection process
PromptEntityResult entitySelectionResult = currentEditor.GetEntity(entitySelectionOpts);
//If a circle was successfully selected, diplay its radius
if (entitySelectionResult.Status == PromptStatus.OK)
DisplayCircleRadius(entitySelectionResult.ObjectId);
private void DisplayCircleRadius(ObjectId circleId)
using (Transaction trans = currentEditor.Document.TransactionManager.StartTransaction())
Circle selectedCircle = (Circle) trans.GetObject(circleId, OpenMode.ForRead);
Application.ShowAlertDialog ("Radius: " + selectedCircle.Radius.ToString());
Bobby C. Jones
