Author Topic: AU 2005 code - Part 3 "Creating Custom Palettes"  (Read 3828 times)
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« on: December 28, 2005, 02:31:03 PM »
This example requires a user control.  As written it actually requires two.  I actually reused the control from the Options Dialog example and created a new one.  However, multiple tabs can host different instances of the same user control.
using System;
using Autodesk.AutoCAD.Windows;
namespace AU2005.AcadApi
//Pages 8 & 9
public class ToolPalettesExample
private static PaletteSet au2005PaletteSet;
[CommandMethod("ShowPalette")]
public static void CreatePaletteSet()
if (au2005PaletteSet == null)
//Create a new palette set at a size of 300x500
au2005PaletteSet = new PaletteSet ("AU 2005 Palette Set Demo");
au2005PaletteSet.MinimumSize = new System.Drawing.Size(300,500);
//Add two palettes to the palette set
//The handout only shows adding a single tab
au2005PaletteSet.Add("Demo Palette", new AU2005.AcadApi.Au2005UserControl());
au2005PaletteSet.Add("Demo Palette 2", new AU2005.AcadApi.Au2005UserControl2());
au2005PaletteSet.Visible = true;
public static PaletteSet CustomPaletteSet
get
return au2005PaletteSet;
[CommandMethod("DockLeft")]
public static void DockLeft()
if (CustomPaletteSet != null)
CustomPaletteSet.Dock = DockSides.Left;
[CommandMethod("Undock")]
public static void UnDock()
CustomPaletteSet.Dock = DockSides.None;
Bobby C. Jones
