Author Topic: AU 2005 code - Part 1 "Adding tabs to the Options Dialog"  (Read 15465 times)
LE
Re: AU 2005 code - Part 1 "Adding tabs to the Options Dialog"
« Reply #15 on: January 17, 2006, 01:30:09 PM »
I'm using SharpDevelop 2 with .NET 2 and I can open VS2003 sln files.
Strange... the version I downloaded the other day... on the same link you gave me... is 1.1.... ok, I know why...
LE
« Reply #16 on: January 17, 2006, 02:52:06 PM »
Now, that I see this new IDE for SharpDevelop, man is seems that MFC is much simpler.... all just for the dialog boxes... hmmmm..... OK, I need to read a lot... I am now out of scope here... I open one SLN and cannot even being able to view the forms.... no no no....  :lol:
On the mean time, has anyone here have been able to run a unmanaged ARX code, with C#... or better a sample of using both?
TR
« Reply #17 on: January 17, 2006, 02:54:28 PM »
If you open a sln that has a control referenced from an unavailable assembly you will not be able to view the form.
LE
« Reply #18 on: January 17, 2006, 02:56:34 PM »
Now in Spanish please....  :roll:
TR
« Reply #19 on: January 17, 2006, 03:00:52 PM »
Si usted se abre un sln que tiene un control referido de una asamblea inasequible usted no podrá visión la forma.
- note: Babelfish doesn't work well.
