Author Topic: Just for fun. Make a dialog box of all editable properties per object.  (Read 23726 times)
Re: Just for fun. Make a dialog box of all editable properties per object.
« Reply #30 on: December 28, 2005, 10:38:18 PM »
Tim,
I like this version better.
« Reply #31 on: December 28, 2005, 10:41:01 PM »
Tim, Do you use DosLib ?
Have a look at the dos_proplist
« Reply #32 on: December 28, 2005, 10:42:53 PM »
.. You may have to use something like ObjectDCL to get the fully interactive result you want though, I think.
« Reply #33 on: December 29, 2005, 02:35:12 AM »
I try not to use outside programs.  I have it installed at work, but I havn't used it.  The company I work for has code writes, or hired coders that use it.  I have no idea what all DosLib can do.
Tim,
Thanks CAB.  I think it functions a lot better also.  I hope Michael doesn't mind me posting the code.  It kind of looks like his routine now.
GDF
« Reply #34 on: December 29, 2005, 09:51:46 AM »
Way to go Tim. I like this newer version better to.
Also have you looked at:
;;;    LSPDATA.lsp- Express Tool data for lsp command
;;;    Copyright © 1999 by Autodesk, Inc.
Gary
« Reply #35 on: December 29, 2005, 11:17:12 AM »
Gary
Thanks Gary, and I never knew about that one either.  I guess I know enough to be dangerous, but not enough still.
I saw a post that MP did that shows how to get to the help files, and I was going to add that to my code also, but then it would work a LOT like his code, so i would rather get his blessing before I do that.  I have it working here.  I think it can be a big help if people don't know what information (type) to enter for new values.
Thanks again all who have helped, and tested it. :-)
GDF
« Reply #36 on: December 30, 2005, 02:41:36 PM »
Just could not keep my hands off it...hope you don't mind. Made minor dcl changes.
Thanks for sharing your routine.
Gary
« Reply #37 on: December 30, 2005, 03:01:52 PM »
Gary
:lmao:
Some how I knew that if you were going to use it, you would change it somehow.  It's all good as long as you find it useful.  Have fun with it, and may you have a Happy New Years.
