Author Topic: Appropiate form to get arguments from a resbuf ?  (Read 9754 times)
LE
« on: December 22, 2005, 11:15:56 PM »
I am doing some new functions and while writing I seen several approaches from some sample code styles, and want it to find out a much cleaner/better "way" "form" if is possible.
Here is one of the new functions I am working:
//call in autolisp: (getweeknumber 2005 12 22)
static int ads_getweeknumber(void)
struct resbuf *rb=acedGetArgs();
int year,month,day;
if (!rb ||
rb->restype != RTSHORT ||
!rb->rbnext ||
rb->rbnext->restype != RTSHORT ||
!rb->rbnext->rbnext ||
rb->rbnext->rbnext->restype != RTSHORT ||
rb->rbnext->rbnext->rbnext
acutPrintf("\nInvalid: function expects three integer arguments!\n" );
return RSERR;
else {
// get the first argument
year=rb->resval.rint;
// get the second argument
rb=rb->rbnext;
month=rb->resval.rint;
// get the third argument
rb=rb->rbnext;
day=rb->resval.rint;
// is not required
////acutRelRb(rb);
CWeek date;
date.setDate(year,month,day); //(2005,12,22);
int nWeeknumber=date.getWeeknumber();
// return to autolisp the week number or nil
acedRetInt(nWeeknumber);
//int nWeekday=date.getWeekday();
}//else
return (RSRSLT) ;
Or...
int year,month,day;
if (rb->restype != RTSHORT){
acutPrintf("\n1st. argument invalid.");
return RSERR;
rb=rb->rbnext;
if (rb==NULL || rb->restype != RTSHORT){
acutPrintf("\n2nd. argument invalid.");
return RSERR;
rb=rb->rbnext;
acutPrintf("\n3rd. argument invalid.");
return RSERR;
// is not required
//acutRelRb(rb);
CWeek date;
return (RSRSLT) ;
Or... something like the following [I did not including any error handler, it is just prototype]
int year,month,day;
if (rb && (rb->restype==RTSHORT)){
rb=rb->rbnext;
rb=rb->rbnext;
rb=rb->rbnext;
// is not required
//acutRelRb(rb);
CWeek date;
return (RSRSLT) ;
Thanks.
MickD
  • (x-in)->[process]->(y-out)
Re: Appropiate form to get arguments from a resbuf ?
« Reply #1 on: December 23, 2005, 01:42:22 AM »
Hi Luis, I've done something similar in C#, I used a hastable to store each rb node using each number of the the 'for' loop as the 'key' and storing the value in that keys' value. I reckon you could do the same with a std::map object or similar. If you know the order of your rb's you can retrieve them as you need using something like string str = myMap[4];//the fifth element in the map is a string value.
Another way may be to see what type the object is while in a loop and add it to an array of its type then access it using the array index.
Either way I think the best way would be to extract the resbuf into a container that takes different types and access that container later saving all the if statements.
I have to do something similar myself so I'll see if I can set something up and post it if you or someone else dosen't come up with something in the mean time.
Forth is like the Tao: it is a Way, and is realized when followed.
Its fragility is its strength; its simplicity is its direction - Michael Ham
"First, solve the problem. Then, write the code." John Johnson
LE
« Reply #2 on: December 23, 2005, 11:30:17 AM »
Thanks Mick;
On the mean time, I am using the first style on the function I posted on the top.
Yes, I do not like all the IF's calls too.....
I have seen the use of switch, but if we have three times the same type, then for what I know of C++ I still cannot figure out how to set each variable in each case.....
ie:
switch (rb->restype) {
case RTREAL : {
double Num=rb->resval.rreal ;
break;
case RTSTR : {
strcpy(Str, rb->resval.rstring);
break;
case RTSHORT : {
// here is on how [if possible] to set up not just one variable,
// like in the case of this functions all the arguments are short type
short iNum=rb->resval.rint;
break;
}// end of switch
I like the idea of put it into a container.... but they are already in the dynamic linked list [resbuf].... I wonder how the masters come up with this...
BTW, in gbpoly I used the second style, but in there are a lot of IF's calls, everything works, no problems, I am just looking for better ways.
Thanks.
« Last Edit: December 23, 2005, 12:25:11 PM by LE »
LE
« Reply #3 on: December 23, 2005, 01:01:50 PM »
For those interested on this new GetWeekNumber function that can be use to extend the capabilities of autolisp, the compiled version is already in the "download" [freeones] section of my web site.
http://www.geometricad.com
LE
« Reply #4 on: December 23, 2005, 03:33:47 PM »
Base on my research I can only see that no more than 11 topics are related with the use of acedGetArgs, means that C++ programmers do not care of exporting functions into autolisp, since everything can be done within.
OK, I will keep using something like this:
if (!rb ||
!rb->rbnext ||
Something I learned from Owen Wengerd [from www.manusoft.com]
Of course if a better approach is found, then I would like to hear....
Have fun.
LE
« Reply #5 on: December 24, 2005, 01:53:43 PM »
In case someone has noticed:
There are three rules about resbuf's or result buffers:
1. Check if is not NULL
2. Check for restype
3. Release dynamically allocated resbuf when done
In this function case, since we are using: acedGetArgs() it is the only case [and the only global objectarx function] that we do not have to release the returned linked list.
Glenn R
  • What idiot child of married cousins wrote this?!
« Reply #6 on: December 28, 2005, 07:28:29 PM »
Louis,
For what it's worth, here's how I was doing it a couple of years ago when I got a bee in my bonnet about writing 'native' Lisp API's:
// This is command 'TCGSVPFREEZE, by Glenn Ryan [8/11/2003], , TCGSoftware
// Description: Freezes or thaws a layer in a particular viewport
// Usage: (tcgs-vp-freeze <Viewport Ename> <Layer name> <T or nil>)
// Returns: T if successful, nil otherwise.
typedef AcDbObjectPointer<AcDbViewport> AcDbViewportPointer;
int TCGSVPFreeze()
#ifdef OARXWIZDEBUG
acutPrintf ("\nOARXWIZDEBUG - TCGSVPFreeze() called.");
#endif // OARXWIZDEBUG
// TODO: Implement the command
resbuf *pArg =acedGetArgs () ;
CString layerName;
bool frzLayer = false;
Acad::ErrorStatus es = Acad::eOk;
AcDbObjectId viewportId = AcDbObjectId::kNull;
if (!pArg)
return RTERROR;
// get the entity name
if (pArg && (pArg->restype == RTENAME)) {
// convert ename to objectid
es = acdbGetObjectId(viewportId, pArg->resval.rlname);
if (es != Acad::eOk) {
acutPrintf("\nerror: Unable to convert entityname to objectId - %s.", acadErrorStatusText(es));
return RSERR;
pArg = pArg->rbnext;
} else if (pArg && (pArg->restype == RTLONG)) {
viewportId.setFromOldId(pArg->resval.rlong);
} else {
acutPrintf("\nerror: Invalid first argument: expects an entity name or vla objectId.\n");
return RSERR;
// get the string for the layer
if (pArg && (pArg->restype == RTSTR)) {
layerName = pArg->resval.rstring;
} else {
acutPrintf("\nerror: Invalid second argument: expects a valid layer name string.\n");
return RSERR;
// get True of False value
// T will freeze layer, nil will thaw it
if (pArg && (pArg->restype == RTT)) {
frzLayer = true;
} else if (pArg && (pArg->restype == RTNIL)) {
frzLayer = false;
} else {
acutPrintf("\nerror: Invalid third argument: expects T or nil.\n");
return RSERR;
if (pArg) {
acutPrintf("\nerror: Invalid number of arguments: usage (tcgs-vp-freeze <Entityname> <Layer name> <T or nil>.\n");
return RSERR;
// check we can find the layer in the layer table
AcDbDatabase* pCurDb = 0;
pCurDb = acdbHostApplicationServices()->workingDatabase();
if (!pCurDb) {
acutPrintf("\nerror: Unable to get pointer to current database.\n");
return RSERR;
AcDbObjectId layerTblId = AcDbObjectId::kNull;
// get the object id of the layer table
layerTblId = pCurDb->layerTableId();
// check we got a valid object id
if (layerTblId.isNull()) {
acutPrintf("\nerror: Unable to get objectId of layer table.\n");
return RSERR;
// try and open the layer table for read
AcDbLayerTablePointer pLayerTbl(layerTblId, AcDb::kForRead);
es = pLayerTbl.openStatus();
acutPrintf("\nerror: Unable to open layer table for read - %s.", acadErrorStatusText(es));
return RSERR;
AcDbObjectId layTblRcdId = AcDbObjectId::kNull;
// check if layer table has layer
if (!pLayerTbl->has(layerName)) {
acutPrintf("\nerror: No matching layer name found.\n");
return RSERR;
} else {
//got layer so grabs it's objectid
es = pLayerTbl->getAt(layerName, layTblRcdId);
acutPrintf("\nerror: Unable to objectId of layer - %s.", acadErrorStatusText(es));
return RSERR;
// check if we got a viewport entityname
AcDbViewportPointer pViewport(viewportId, AcDb::kForWrite);
es = pViewport.openStatus();
if (es == Acad::ErrorStatus::eNotThatKindOfClass) {
acutPrintf("\nerror: Invalid entityname - must be a viewport.\n");
return RSERR;
acutPrintf("\nerror: Unable to open viewport for write - %s.",acadErrorStatusText(es));
return RSERR;
// toss layer tabel record objectid into array
AcDbObjectIdArray idArr;
idArr.append(layTblRcdId);
if (frzLayer) { // freeze the layer
es = pViewport->freezeLayersInViewport(idArr);
acedRetNil();
return RSERR;
acedRetT();
} else { // want to thaw the layer
es = pViewport->thawLayersInViewport(idArr);
acedRetNil();
return RSERR;
acedRetT();
return (RSRSLT) ;
Cheers,
Glenn.
Me
LE
« Reply #7 on: December 28, 2005, 09:09:51 PM »
Thank you Glenn;
Nice code sample!
[I see that everyday very few are staying into C++ and less on ObjectARX]
Glenn R
« Reply #8 on: December 28, 2005, 09:51:03 PM »
You're welcome Louis. One other point: If the resbuf chain you're chasing is longer than a few elements,
I would use a while loop with an embedded switch statement.
Merry Xmas and a Happy New Year,
Glenn.
Me
LE
« Reply #9 on: December 28, 2005, 10:03:54 PM »
Thank you;
The same to you and your family.
MickD
« Reply #10 on: January 03, 2006, 10:14:42 PM »
Had a bit of time to play around so how about something like this? I didn't test it as it didn't compile without error (which header did you include for CWeek Luis?) but it gives you the general idea.
int iArray[3];
int year,month,day;
if (!rb)
acutPrintf("\nError: failed to get resbuf!\n" );
return RSERR;
for(int i = 0; i < 3; i++)
if(rb->restype != RTSHORT)
acutPrintf("\nInvalid parameter, failed on iteration %d!\n",i );
return RSERR;
iArray[i] = rb->resval.rint;
rb = rb->rbnext;//ready for next loop
year = iArray[0];
month = iArray[1];
day = iArray[2];
CWeek date;
return (RSRSLT) ;
WARNING: not tested, issued for discussion only :-)
LE
« Reply #11 on: January 03, 2006, 10:49:26 PM »
Let me tested, looks good, I think this thread is going the same direction as the one of "code right"..... I will say.....  :-)
The CWeek is a calendar class.
Thanks.
« Reply #12 on: January 03, 2006, 11:07:55 PM »
Seeing it's become a discussion .. :-)
Wouldn't the result be determined by the local environment ie
ISO
US
etc ..
http://msdn2.microsoft.com/en-us/library/system.globalization.calendar.getweekofyear.aspx
the rules :
http://msdn2.microsoft.com/en-us/library/system.globalization.calendarweekrule.aspx
or, is that all handled by this call < from Micks >.
and does that mean there is NO definitive answer, because "It Depends" on the computer settings. ? ?
« Last Edit: January 03, 2006, 11:11:21 PM by Kerry Brown »
--> Donate to theSwamp<--
MickD
« Reply #13 on: January 03, 2006, 11:46:40 PM »
I think that would be the case, also not the setDate parameters ;)
MickD
« Reply #14 on: January 04, 2006, 12:14:47 AM »
.... I think this thread is going the same direction as the one of "code right"..... I will say..... :-)
if we want to go that way we probably should do something like this -
class MyWeek
public://constructor/destructor/functions
MyWeek(struct resbuf * rb)
//init our class in constructor
_rb = rb;
setUpVars();
~MyWeek() {/*clean up if required*/};
int WeekNumber();
private://member variables
struct resbuf * _rb;
CWeek _date;
int _year,_month,_day,_weekNumber;
int iArray[3];
private://functions
void setUpVars();
};//end class definition
void MyWeek::setUpVars()
if (!_rb)
if(_rb->restype != RTSHORT)
acutPrintf("\nInvalid parameter, failed on iteration %i!\n",i );
iArray[i] = _rb->resval.rint;
_rb = _rb->rbnext;//ready for next loop
_year = iArray[0];
_month = iArray[1];
_day = iArray[2];
_date.setDate(_year,_month,_day); //(2005,12,22);
_weeknumber = _date.getWeeknumber();
int MyWeek::WeekNumber()
return _weekNumber;
Then simply use it like this -
MyWeek date(rb);
acedRetInt(date.WeekNumber());
return (RSRSLT) ;
A bit of overkill though  :lol:
« Last Edit: January 04, 2006, 12:18:12 AM by MickD »
