Author Topic: Title  (Read 4187 times)
delium55
Title
« on: January 27, 2006, 10:21:37 PM »
I have  a error message with this lisp. The first lie of text is ok, but the underline of text dont work.
I put undercore before command for use with french version.
I use Autocad 2000 and 2004, work in metric with decimal units.
Where is the problem.
Thank for your help.
François.
;Tip1789:  TITLE.LSP       DETAIL TITLE                    (c)2002, Roy Everitt
;;;   Title.lsp
;;;   Permission to use, copy, modify, and distribute this software and its
;;;   documentation for any purpose and without fee is hereby granted.
;;;   THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY.
;;;   ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR PURPOSE AND OF
;;;   MERCHANTABILITY ARE HEREBY DISCLAIMED.
;;;   Copyright© Roy Everitt
;;;   March, 2000
;;;   Note: Older versions of Autocad will not recognize the *error* function. You will
;;;         need to replace the (defun-q *error* (msg) statement with (defun *error* (msg).
;;;   Place a "DETAIL" title callout in the drawing on the designated layer "CALLOUT"
;;;   for drawing callouts... may be modified to user preference. The program uses a
;;;   combination of drawing environment settings for (dimscale & dimtxt) to determine
;;;   the appropriate text sizes to use. The program places an underline below the
;;;   title. It also has the option for a reference Balloon Callout at the left.
;;;   Pre-defined Title and Subtitle lists can also be modified for user preferences.
;;;   The program also generates a custom DCL file (temp.dcl) that is re-written each
;;;   time it is executed. The code may be changed so that temp.dcl is written to, and
;;;   found in any user preferred folder, as long as that folder is in the Support Files
;;;   Search Path.
;;;   Note: By default, it will be written in your Autocad Working Directory, (wherever
;;;         your shortcut or "Start In" Icon is set up to work).
;;;   Example: Look for the code: (setq fd (open "temp.dcl" "w"))
;;;            Change it to: (setq fd (open "c:\\myfolder\\temp.dcl" "w"))
;;;            Look for the code: (close (open "temp.dcl" "w") )
;;;            Change it to: (close (open "c:\\myfolder\\temp.dcl" "w") )
;;;            Look for the code: (if (< (setq *titleid* (load_dialog "temp.dcl")) 0)
;;;            Change it to: (if (< (setq *titleid* (load_dialog "c:\\myfolder\\temp.dcl")) 0)
;;;                          (Where "myfolder" is your designated folder name)
(princ "\Title Maker Program loading...")
(defun
   C:TITLE (/ TITLE_STYLE TITLE_FONT TITLE_LAYER TITLE_COLOR TITLE_LAYER
            OL OS OC CR DLG_CLOSE FD SYMTOS DLG_HEADER DLG_MAIN
            DLG_DIALOG DLG_ITEM DLG_ATT DLG_PROTO DCL_TEMP TITLE
            SUBTITLE NUMBR *TITLEID* TEST GET_INPUT FLAG
;;;;;main dialog control functions;;;;
  (defun CR () (princ "\n" FD))
  (defun DLG_CLOSE () (princ "}" FD) (CR))
  (defun
     DLG_HEADER (AUDIT)
    (princ "dcl_settings : default_dcl_settings {" FD)
    (CR)
    (princ (strcat " audit_level = " (itoa AUDIT) "; }") FD)
    (CR)
  ) ;_ end of defun
  (defun DLG_DIALOG (NAME) (princ (strcat NAME " : dialog {") FD) (CR))
  (defun DLG_ITEM (ITEM) (princ (strcat ": " ITEM "{") FD) (CR))
  (defun DLG_PROTO (type) (princ (strcat type ";") FD) (CR))
  (defun
     DLG_ATT (ATT VAL)
      ((= (type VAL) 'INT)
       (princ (strcat ATT "=" (itoa VAL) ";") FD)
       (CR)
      ((= (type VAL) 'REAL)
       (princ (strcat ATT "=" (rtos VAL) ";") FD)
       (CR)
      ((= (type VAL) 'STR)
       (princ (strcat ATT "=\"" VAL "\";") FD)
       (CR)
      ((= (type VAL) 'SYM)
       (princ (strcat ATT "=" (SYMTOS VAL) ";") FD)
       (CR)
    ) ;_ end of cond
  ) ;_ end of defun
  (defun
     SYMTOS (SYM / FD)
    (setq FD (open "symtos.txt" "w"))
    (princ SYM FD)
    (close FD)
    (setq
      FD  (open "symtos.txt" "r")
      SYM (strcase (read-line FD) t)
    ) ;_ end of setq
    (close FD)
    SYM
  ) ;_ end of defun
  (defun
     DCL_TEMP (/ FD)
    (setq FD (open "J:\\ESTB\\temp.dcl" "w"))    ;;;Ligne à modifier si requis
    (DLG_HEADER 0)
;;;define main dialog;;;
    (DLG_DIALOG "dlg_main")
    (DLG_ATT "label" "Programme-Titre de détail....par Roy Everitt")
    (DLG_ITEM "row")
    (DLG_ITEM "boxed_row")
    (DLG_ATT "label" "Nombre:")
    (DLG_ITEM "edit_box")
    (DLG_ATT "alignment" 'LEFT)
    (DLG_ATT "fixed_width" 'TRUE)
    (DLG_ATT "key" "numbr")
    (DLG_ATT "edit_width" 4)
    (DLG_ATT "edit_limit" 4)
    (DLG_CLOSE)
    (DLG_CLOSE)
    (DLG_ITEM "column")
    (DLG_ATT "key" "title")
    (DLG_ATT "label" "TITRE:")
    (DLG_ATT "edit_width" 30)
    (DLG_CLOSE)
    (DLG_ITEM "popup_list")
    (DLG_ATT "label" "Prédéfini:")
    (DLG_ATT "key" "title_def")
    (DLG_CLOSE)
    (DLG_ATT "label" "SOUS-TITRE:")
    (DLG_ATT "key" "subtitle")
    (DLG_CLOSE)
    (DLG_ATT "key" "sub_def")
    (DLG_CLOSE)
    (DLG_CLOSE)
    (DLG_CLOSE)
    (DLG_PROTO "spacer_1")
    (DLG_ITEM "button")
    (DLG_ATT "key" "loc")
    (DLG_ATT "label" "Localiser l'emplacement du Titre sur le dessin")
    (DLG_ATT "height" 2)
    (DLG_ATT "alignment" 'CENTERED)
    (DLG_CLOSE)
    (DLG_PROTO "cancel_button")
    (DLG_CLOSE)
    (close FD)
    "temp.dcl"
  ) ;_ end of defun
  (defun
     LOAD_TITLE (VALUE)
    (setq NEW_VALUE (atoi VALUE))
    (set_tile "title" (nth NEW_VALUE TITLE-LIST))
    (setq TITLE (nth NEW_VALUE TITLE-LIST))
  ) ;_ end of defun
  (defun
     LOAD_SUB (VALUE)
    (set_tile "subtitle" (nth NEW_VALUE SUB-LIST))
    (setq SUBTITLE (nth NEW_VALUE SUB-LIST))
  ) ;_ end of defun
  (defun
     DRAW_TITLE (/ N W S E DS OSM OCC PT1 SIZE TITLE_TXT TB LL UR
                 TITLE_LGTH PT2 SUBT_TXT SUBT_LGTH RAD PT3 PT4 PT5 TEST
    (command "_style" "romans" "romans.shx" "" "" "" "" "" "")
    (setq
      N (* 0.5 pi)
      W pi
      S (* 1.5 pi)
      E 0
    ) ;_ end of setq
    (setq
      OL  (getvar "clayer")
      OS  (getvar "textstyle")
      OC  (getvar "cmdecho")
      DS  (getvar "dimscale")
      OSM (getvar "osmode")
      OCC (getvar "cecolor")
    ) ;_ end of setq
    (setvar "cmdecho" 0)
    (setq PT1 (getpoint "\nDéterminé le point central du TITRE: "))
    (setvar "osmode" 0)
    (setq SIZE (* 1.5 (getvar "dimscale") (getvar "dimtxt")))
    (if (= (tblsearch "layer" "CALLOUT") NIL)
      (command
        "_layer" "_make" "CALLOUT" "_color" "_red" "" "_set" "CALLOUT" ""
       ) ;_ end of command
 ;_ end of command
    ) ;_ end of if
    (setvar "clayer" "CALLOUT")
    (command "_text" "j" "c" PT1 SIZE "0" TITLE)
    (setq
      TITLE_TXT
       (entget (entlast))
      TB (textbox TITLE_TXT)
      LL (car TB)
      UR (cadr TB)
      TITLE_LGTH
       (+ (/ (distance LL UR) 2) (/ SIZE 2))
    ) ;_ end of setq
    (setq PT2 (polar PT1 S (/ SIZE 2)))
    (command
      "_text"
      "j"
      "tc"
      (polar PT2 S (/ SIZE 2))
      (* 0.666 SIZE)
      "0"
      SUBTITLE
    ) ;_ end of command
    (setq
      SUBT_TXT
       (entget (entlast))
      TB (textbox SUBT_TXT)
      LL (car TB)
      UR (cadr TB)
      SUBT_LGTH
    ) ;_ end of setq
    (if (< SUBT_LGTH TITLE_LGTH)
      (setq LGTH TITLE_LGTH)
      (setq LGTH SUBT_LGTH)
    ) ;_ end of if
    (setq
      RAD (* 0.3333 DS)
      PT3 (polar PT2 E LGTH)
      PT4 (polar PT2 W LGTH)
      PT5 (polar PT4 W RAD)
    ) ;_ end of setq
    (command "_line" PT3 PT4 "")
    (if (/= NUMBR NIL)
        (command "_circle" PT5 RAD)
        (command "_text" "j" "m" PT5 (* 0.15 DS) "0" NUMBR)
      ) ;_ end of progn
    ) ;_ end of if
    (setvar "dimscale" DS)
    (setvar "cecolor" OCC)
    (setvar "osmode" OSM)
    (setvar "clayer" OL)
    (setvar "cmdecho" 1)
  ) ;_ end of defun
  (defun
     GET_INPUT ()
    (if (< (strlen (setq TITLE (get_tile "title"))) 1)
        (setq FLAG t)
        (alert
          "\nAucune identification de TITRE n'est présente...\nSVP inscrire un TITRE!\n\n"
        ) ;_ end of alert
        (mode_tile "title" 2)
      ) ;_ end of progn
      (setq TEST "ok")
    ) ;_ end of if
    (if FLAG
      NIL
      t
    ) ;_ end of if
  ) ;_ end of defun
  (defun
     DLG_MAIN (/ XIT)
    (close (open "J:\\ESTB\\temp.dcl" "w"))   ;;;Ligne à modifier si requis
    (if (not (new_dialog "dlg_main" *TITLEID*))
      (exit)
    ) ;_ end of if
    (TILES_DLG_TITLE)
    (ACTIONS_DLG_TITLE)
    (setq XIT (start_dialog))
;;; Dialog Removed
;;; xit = Value passed from done_dialog
;;;    (defined in actions_dlg_title)
    (princ "" FD)
    (close FD)
  ) ;_ end of defun
  (defun TILES_DLG_TITLE () (mode_tile "title" 2))
  (defun
     ACTIONS_DLG_TITLE (/ FLAG)
    (action_tile "title" "(setq title $value)")
    (action_tile "subtitle" "(setq subtitle $value)")
    (action_tile "numbr" "(setq numbr $value)")
    (setq
      TITLE-LIST
       '("" "COUPE" "COUPE-A" "COUPE A-A" "COUPE-B" "COUPE B-B" "COUPE-C" "COUPE C-C"
         "COUPE-D" "COUPE D-D" "COUPE DE MUR" "COUPE DE MUR-TYPE" "COUPE TRANSVERSALE"
         "COUPE TRANSVERSALE A-A" "COUPE TRANSVERSALE B-B" "COUPE LONGITUDINALE"
         "COUPE LONGITUDINALE A-A" "COUPE LONGITUDINALE B-B" "DÉTAIL TYPE" "ÉLÉVATION TYPE"
         "ÉLÉVATION AXE -A-" "VUE EN PLAN" "VUE EN ÉLÉVATION" "VUE ISOMÉTRIQUE"
    ) ;_ end of setq
    (start_list "title_def")
    (mapcar 'add_list TITLE-LIST)
    (end_list)
    (action_tile "title_def" "(load_title $value)")
    (setq
      SUB-LIST
       '(" " "ECHELLE: AUCUNE" "ECHELLE: PLEINE GRANDEUR 1=1" "ECHELLE: DEMI-GRANDEUR 1/2"
         "ECHELLE: 3\"=1'-0\""   "ECHELLE: 1-1/2\"=1'-0\"" "ECHELLE: 1\"=1'-0\""
         "ECHELLE: 3/4\"=1'-0\"" "ECHELLE: 1/2\"=1'-0\""   "ECHELLE: 3/8\"=1'-0\""
         "ECHELLE: 1/4\"=1'-0\"" "ECHELLE: 1/8\"=1'-0\""   "ECHELLE: 1/16\"=1'-0\""
         "ECHELLE: 1=5" "ÉCHELLE: 1=10" "ÉCHELLE: 1=20" "ÉCHELLE:1=25" "ÉCHELLE: 1=50"
         " ÉCHELLE: 1=75" "ÉCHELLE: 1=100" "ÉCHELLE: 1=200" "ÉCHELLE: 1=250" "ÉHELLE: 1=500"
    ) ;_ end of setq
    (start_list "sub_def")
    (mapcar 'add_list SUB-LIST)
    (end_list)
    (action_tile "sub_def" "(load_sub $value)")
    (action_tile "loc" "(if (setq flag (get_input))(done_dialog 1) )")
;;; 'Cancel' button
    (action_tile "cancel" "(setq test nil)(done_dialog 0)")
  ) ;_ end of defun
;;; define error routine ;;;
  (setq TITLE_ERR *ERROR*)
  (defun-q
    *ERROR*
    (MSG)
    (princ MSG)
    (setq *ERROR* TITLE_ERR)
    (if OL
    ) ;_ end of if
    (if OS
      (setvar "textstyle" OS)
    ) ;_ end of if
    (if OC
      (setvar "cmdecho" OC)
    ) ;_ end of if
    (if OCC
    ) ;_ end of if
    (if OSM
    ) ;_ end of if
    (if DS
    ) ;_ end of if
    (princ "" FD)
    (close FD)
  ) ;_ end of defun-q
;;; perform creation of dialog, load dialog & set global handle (*titleid*) ;;;
  (if (not *TITLEID*)
;;; first time thru
      (DCL_TEMP)
      (if (< (setq *TITLEID* (load_dialog "J:\\ESTB\\temp.dcl")) 0)      ;;;Ligne à modifier si requis
        (*ERROR* "dialog load error")
      ) ;_ end of if
    ) ;_ end of progn
  ) ;_ end of if
  (DLG_MAIN)
  (if (= TEST "ok")
    (DRAW_TITLE)
  ) ;_ end of if
;;;   restore error handler and exit   ;;;
  (terpri)
  (*ERROR* "Title Maker Program finished...")
) ;_ end of defun
(princ "loaded")
(terpri)
(princ "\n->defined command...title")
Re: Title
« Reply #1 on: January 27, 2006, 10:47:40 PM »
This is part of the problem ;
  (defun DCL_TEMP (/ FD)
    (DLG_HEADER 0)
The expectation made is that the folder exists .. does it ?
The FD <FilePointer> variable is local to this function
.. yet the   DLG_HEADER routine tries to use the variable .. naughty !
Re: Title
« Reply #2 on: January 27, 2006, 10:53:50 PM »
delium55 ,
Do you know how to "Step-Through" code in the VL-IDE ?
delium55
Re: Title
« Reply #3 on: January 28, 2006, 08:49:53 AM »
Good morning Kenny,
The folder J:\\estb exist and the files temp.dcl and symtos.txt are in the same folder.
I dont know how to "Step-Through" code in the VL-IDE .
Thank again for the help.
François.
Re: Title
« Reply #4 on: January 28, 2006, 09:17:56 AM »
François,
I just copied the code you posted, changed all of the "J:\\ESTB\\temp.dcl" to "temp.dcl", and it worked fine....even though I have no idea what the text says since I know absolutely no French. ;-) I'm attaching a small picture...is this not what you expect?
Re: Title
« Reply #5 on: January 28, 2006, 09:27:46 AM »
Kerry, this variable appears to be used correctly, the confusion comes from the author re-using the same name for a variable in multiple places. Search the code for (setq FD and you will find that it is, indeed, set correctly for use where it's needed.
delium55
Re: Title
« Reply #6 on: January 28, 2006, 12:51:53 PM »
I DONT KNOW WHY ThIS NOT WORK CORRECTLY HERE.
MORE tHANK.
fRANÇOIS.
Re: Title
« Reply #7 on: January 28, 2006, 02:29:01 PM »
What is the error message ?
Jeff, yep, the use of the 'HD' variable like that threw me off the scent ...
This may help ..
Re: Title
« Reply #8 on: January 28, 2006, 03:01:10 PM »
After changing the Folder address for the files to C:\\.... the application works for me as written .. in AC2006.
Re: Title
« Reply #9 on: January 28, 2006, 03:03:08 PM »
François,
I think that you will need to edit ALL occurances of commands AND the keywords with an underscore. For instance:
;;should be
(command "_text" "_j" "_c" PT1 SIZE "0" TITLE)
Re: Title
« Reply #10 on: January 28, 2006, 03:09:54 PM »
.. also, the detail Balloon and it's TEXT size will need controlling in relation to the TITLE Text size.
Re: Title
« Reply #11 on: January 29, 2006, 12:00:27 AM »
Good morning Kenny,
......................   François.
and that's Kerry ..
but I've been called worse ... :-)
delium55
Re: Title
« Reply #12 on: January 29, 2006, 09:53:51 AM »
Good morning again Kerry,
Excuse for the error of typing in your name in the last reply.
I have do a new test and i have that;
Pick point for title, that work ok,
and at the command line i have this; option choice incorrect, fonction cancelled, enter option
(align, fix,center,middle,right,mc,ml,mr,etc.)
François.
Re: Title
« Reply #13 on: January 29, 2006, 03:34:57 PM »
Thats with the Text command, justification,  yes ?
Did you Change ALL commands to have an underscore prefix as per Jeff's post #9 ?
