Author Topic: Top Daug Contest  (Read 9183 times)
whdjr
Top Daug Contest
« on: December 20, 2005, 01:46:23 PM »
Here is a link to the Top Daug contest if you guys want to try it out.
Post your scores after you take the test.
And DON'T CHEAT!
whdjr
Re: Top Daug Contest
« Reply #1 on: December 20, 2005, 01:47:23 PM »
I only had time to answer 25 of 45 and I only got 16 of 25 right.   :x
I suck!
Lin-Z
« Reply #2 on: December 20, 2005, 01:57:58 PM »
Started on: Tuesday, 20 December 2005, 01:49 PM
Completed on: Tuesday, 20 December 2005, 01:57 PM
Time taken: 7 mins 35 secs
Raw score: 26/45 (58 %)
Grade: 26 out of a maximum of 45
David Hall
  • Automatic Duh Generator
« Reply #3 on: December 20, 2005, 01:59:46 PM »
Time taken:   8 mins 12 secs
Raw score:   33/45 (73 %)
Grade:   33 out of a maximum of 45
« Reply #4 on: December 20, 2005, 03:52:34 PM »
Started on:   Tuesday, 20 December 2005, 03:39 PM
Completed on:   Tuesday, 20 December 2005, 03:49 PM
Time taken:   10 mins 7 secs
Raw score:   29/45 (64 %)
Grade:   29 out of a maximum of 45
uncoolperson
« Reply #5 on: December 20, 2005, 04:19:57 PM »
Started on: Tuesday, 20 December 2005, 04:07 PM
Completed on: Tuesday, 20 December 2005, 04:17 PM
Time taken: 10 mins 3 secs
Raw score: 25/45 (56 %)
Grade: 25 out of a maximum of 45
it didn't record my last click... which was correct, should be 26/45
which still sucks
Kate M
« Reply #6 on: December 20, 2005, 05:07:35 PM »
I took it at AU -- got 32/45 in something like 5 minutes..
And FYI, the highest score at AU was 36; the lowest in the top 10 was 33. So don't feel bad about a score in the 20's!
pmvliet
« Reply #7 on: December 21, 2005, 02:04:05 PM »
Kate beat me again!
I had a 31 at AU.... I challenged people in my office to take it and if they got higher then me I'd take them to lunch.
No one wants to even take it....
Pieter
nivuahc
« Reply #8 on: December 21, 2005, 02:43:38 PM »
Started on:   Wednesday, 21 December 2005, 02:28 PM
Completed on:   Wednesday, 21 December 2005, 02:38 PM
Time taken:   10 mins 2 secs
Raw score:   32/45 (71 %)
Grade:   32 out of a maximum of 45
nivuahc
« Reply #9 on: December 21, 2005, 03:04:17 PM »
I have issues with this one:
To draw a line a length of 8 feet, 4 5/8 inches in the 12 o’clock direction from the last point selected, enter:
Greg B
  • Tell me a Joke!
« Reply #10 on: December 21, 2005, 03:09:09 PM »
Oh that's easy...
Select Point
Enter 8.4.5.8 <enter>
Enter 90 <enter>
Ta-Da
David Hall
« Reply #11 on: December 21, 2005, 03:10:45 PM »
Me to.  seems like there is something missing there
M-dub
« Reply #12 on: December 21, 2005, 03:18:29 PM »
Oh that's easy...
Select Point
Enter 90 <enter>
Ta-Da
Thanks Mr. DataCAD!  :evil:
nivuahc
« Reply #13 on: December 21, 2005, 03:30:06 PM »
That's just the thing, none of the available choices had anything about the angle so I chose "none of the above". According to the test, this is the right answer:
@8'4-5/8
I won't even get into the issue of what units need to be set in order for that to even be close but let's test that theory in AutoCAD 2002
Command: l
Specify first point:
Specify next point or [Undo]: @8'4-5/8
Point or option keyword required.
Specify next point or [Undo]: *Cancel*
How about 2006?
Command: l
LINE Specify first point:
whdjr
« Reply #14 on: December 21, 2005, 03:31:21 PM »
I had issues with that one too.  It doesn't include direction in the answer when it was part of the question.
