Author Topic: RND  (Read 4818 times)
vladimirzm
RND
« on: December 20, 2005, 01:09:15 AM »
how do i store the the random number (generated through RND) in USERR1
ThisDrawing.SetVariable "USERI1", ((10 * Rnd) + 1) returns error
Jürg Menzi
  • Oberegg, Switzerland
Re: RND
« Reply #1 on: December 20, 2005, 02:14:07 AM »
'rnd' returns a single (real in Lisp), therefore you've to use the USERRx variables as you mentioned in the text.
Your sample works with a USERIx variable and that is not possible...
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
Arizona
Re: RND
« Reply #2 on: December 20, 2005, 06:34:20 AM »
In VBA, variables are defined based on the type of data you plan to store such as:
Dim Num as Integer
would be a variable that would only hold integers. So if I tried to store a string value such as "123" I would get an error.
However once I have defined my variable I can now assign a value to it:
Set Num = ((10 * RND)+1)
You can then use that variable that contains a value.
Note: I did not address whether your math function works or not.
What is the purpose of setting this value to UserI1? (is this really a variable? I'm on 2000i...) or are you simply trying to store a value somewhere?
David Hall
  • Automatic Duh Generator
Re: RND
« Reply #3 on: December 20, 2005, 08:51:26 AM »
This does what you want, but it cold be laid out better
Public Sub TESTRND()
Dim num As Double, e As Double
e = 0.25 ' MUST BE INITIALIZED TO SOMETHING, OR IT REPEATS THE SAME NUMBER
num = (10 * (Rnd(e)) + 1)
ThisDrawing.SetVariable "Userr1", num
End Sub
vladimirzm
Re: RND
« Reply #4 on: December 20, 2005, 10:01:51 AM »
thanks
USERRx or USERIx returns the same thing... error
Dim Num as Integer
Well, actually I'm trying to store from Vlisp. For example:
(defun msgbox (title button msg / useri1 r)
  (setq useri1 (getvar "useri1"))
  (vla-eval
    (vlax-get-acad-object)
    (strcat
      "ThisDrawing.SetVariable \"USERI1\","
      "MsgBox (\""
      msg
      (itoa button)
      title
  (setq r (getvar "useri1"))
  (setvar "useri1" useri1)
  r
This works very well and allow me to show basic interface without DCL... Msgbox returns a value that is stored in USERI1, then i can use this without trouble.
In the same way I supposed
ThisDrawing.SetVariable "USERI1", ((10 * Rnd) + 1)will work
David Hall
Re: RND
« Reply #5 on: December 20, 2005, 10:37:50 AM »
only problem I see, useri1 stores an integer, and rnd (in vba at least) generates a real (double)
Re: RND
« Reply #6 on: December 20, 2005, 10:55:35 AM »
If you place the value of your RND call in a variant you should be able to place it in useri1 without incident, or at very least move the data from a variant to an integer variable then into useri1
Jürg Menzi
Re: RND
« Reply #7 on: December 28, 2005, 07:56:56 AM »
ThisDrawing.SetVariable "USERR1", (CDbl ((10 * Rnd) + 1))
should work...
vladimirzm
Re: RND
« Reply #8 on: January 05, 2006, 05:19:26 AM »
Nice!
Another line to the tricks book!
Thank you!
Re: RND
« Reply #9 on: January 05, 2006, 07:15:20 AM »
I dont believe you have to cast the calc result, just make sure one of the numeric constants is a real
ThisDrawing.SetVariable "USERR1", ((10.0 * Rnd) + 1)or
ThisDrawing.SetVariable "USERR1", ((10 * Rnd) + 1.0)
