Author Topic: CmdVisLines  (Read 4270 times)
vladimirzm
CmdVisLines
« on: December 20, 2005, 12:48:22 AM »
(setenv "CmdVisLines" "5") ->  nothing happens
(setenv "CmdVisLines" "20") ->  nothing happens
even through vla-put-dockedvisiblelines nothing happens
but (getenv "CmdVisLines") works
and vla-get-dockedvisiblelines works too
How do i re-size the command window?
I need to show some info and I want to make sure that is correctly displayed (5 lines), but just for active command, when the command finishes the command window must restore from previous size.
Serge J. Gianolla
Re: CmdVisLines
« Reply #1 on: December 20, 2005, 03:04:08 AM »
You must be in 2006! Actually I cannot recall, but I think that we can't do it in 2005 too!! It is more of a stretchable floating form nowadays.
Fatty
Re: CmdVisLines
« Reply #2 on: December 20, 2005, 03:11:34 AM »
Maybe because of:
Remarks
This property is obsolete. (Help)
Re: CmdVisLines
« Reply #3 on: December 20, 2005, 08:04:16 AM »
This may help:
VxXetDispCmdLines - Sets or gets the number of command lines
Found here
http://www.menziengineering.ch/
But not sure about 2006?
Jürg Menzi may shed some light on the subject as he is the author.
« Last Edit: December 20, 2005, 08:08:53 AM by CAB »
Fatty
Re: CmdVisLines
« Reply #4 on: December 20, 2005, 08:15:53 AM »
This may help:
Found here
Won't to work fo me (A2005)
(VxXetDispCmdLines 2);nothing happened
(VxXetDispCmdLines 5);nothing happened
(VxXetDispCmdLines 10);nothing happened
(VxXetDispCmdLines 15);nothing happened
(VxXetDispCmdLines 20);nothing happened
Thank you
GDF
Re: CmdVisLines
« Reply #5 on: December 20, 2005, 09:01:15 AM »
In Jurge's VxXetDispCmdLines routine:
; Arguments [Type]:
;   Mde = Mode, Values:
;         - Nil (VxGetDispCmdLines) [SYM]
;         - Number of command lines (VxSetDispCmdLines) [INT
VxGetDispCmdLines TYPO?
VxSetDispCmdLines TYPO?
I tried (VxXetDispCmdLines 5) in 2006 and nothing happened.
Gary
whdjr
Re: CmdVisLines
« Reply #6 on: December 20, 2005, 09:17:25 AM »
Is your commandline locked?
I would think it would not change if it was locked.
whdjr
Re: CmdVisLines
« Reply #7 on: December 20, 2005, 09:22:48 AM »
This is from the ADT2006 Help Files:
DockedVisibleLines Property
Specifies the number of lines of text to display in the command window.
Signature
object.DockedVisibleLines
object
PreferencesDisplay
DockedVisibleLines
Integer; read-write
A positive integer representing the number of text lines to display in the command window.
Remarks
Check out the last line.  I haven't found what controls it yet, though.
vladimirzm
Re: CmdVisLines
« Reply #8 on: December 20, 2005, 09:40:17 AM »
No. It's floating
Yes I'm in R2006 and really nothing happens, anyway
I think i could modify the actual WorkSpace...
Thnxs everybody
Jürg Menzi
  • Oberegg, Switzerland
Re: CmdVisLines
« Reply #9 on: December 20, 2005, 09:42:58 AM »
I wrote this function with 2k0...
Works with 2k0(i) and 2k2. This property seems not supported anymore since 2k4. :pissed:
Have to add a note to the sample.
No workaround known... :-(
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
