Author Topic: you say you're pretty good at numbers....hehehehe  (Read 10774 times)
Ron Heigh
« Reply #15 on: February 07, 2004, 09:47:40 AM »
On a different note:
If you use a math software like MathCAD, you can input the formula and define the variables.
It will then allow you assign values to some and tell you what the remaining variable needs to be to satisfy the equation.
If you can derive the Lisp equivalent, look here.
http://www.mathcad.com/products/
« Reply #16 on: February 07, 2004, 12:53:01 PM »
When all else fails use a Sledge Hammer. :shock:
(defun Rnd_to_Sqr(Dia ; dia of round duct
                  A   ;; side A of square duct
                  / loop fuzz B)
  ;;  Returns Side B of square duct
  (setq B A  ; B is target
        fuzz 0.001
        loop T)
  (while loop
    (setq Dia2 (* 1.3
                  (exp
                      (log
                          (expt (* A B) 5) (expt (+ A B) 2)
                     8)
      (if(equal Dia2 Dia fuzz)
       (setq loop nil); done
       (setq B (* B (/ Dia Dia2)))
  B
(defun c:test()
  (setq SideA 12.0
        dia 13.118
        SideB (Rnd_to_Sqr dia SideA)
Water Bear
Bravo!!
« Reply #17 on: February 07, 2004, 02:27:16 PM »
CAB ..I wouldn't believe it if I hadn't seen it with my own eyes! Idon't quite understand HOW u made it work..but it works! :D  Bravo! and thank you
DParcon
« Reply #18 on: February 07, 2004, 06:17:11 PM »
Water Bear,
  Here's your conversion formulas:
     To get A, B & D known: A = (0.836812758 x D X D) / B
     To get B, A & D known: B = (0.836812758 x D X D) / A
  Above formulas were derived from round to square formula:
     Round to Square (A=B): A = 0.914774703 x D
  You can also use an iteration loop in lisp based on the
  original formula (as posted by CAB).
  Have fun.
  Don
Water Bear
« Reply #19 on: February 07, 2004, 08:44:45 PM »
Thanx Don ..those sure make it easy
I compared various examples using a Trane ductulator with CAB's hammer, and he is VERY accurate...
thanx again, and welcome to the club. :wink:
« Reply #20 on: February 07, 2004, 09:11:37 PM »
Revised the routine to make sure A is a real, else it won't work.
Don you formula only works if sides are 12x12?
                  / loop fuzz B)
  (if (= (type a) 'INT);; make sure A is a REAL
    (setq A (* A 1.0))
        fuzz 0.001
        loop T)
  (while loop
    (setq Dia2 (* 1.3
                  (exp
                      (log
                     8)
  B
Water Bear
« Reply #21 on: February 08, 2004, 12:06:35 AM »
I've tried Don's but I get inconsistent results. Case in point:
25 inch round to something by 12
(0.836812758 x 25 X 25) / 12 = 43.58399
Trane ductulator indictates it should be 49
If I use CAB's hammer I get  48.8559 :roll: close enough for me!
That's almost a 260 sq in difference.
Water Bear
« Reply #22 on: February 08, 2004, 11:38:08 AM »
However,in all fairness to Don, using his original equation I get:
0.914774703 x 25.0 = 22.869367575
compared using ASHRAE formula:
(* 1.3 (exp(/(log (/ (expt (* 22.869367575 22.869367575) 5) (expt (+ 22.869367575 22.869367575) 2)))8)))
the answer comes up 25.0!
And plugging into CABs'hammer:
(Rnd_to_Sqr 25.0 22.869367575) you get 22.8694  :P
Q.E.D.
DParcon
« Reply #23 on: February 08, 2004, 12:47:38 PM »
WaterBear,
  In the formulas I've posted, the round to square is the
  accurate one since it was derived from the ASHRAE formula.
  Since you're the one in need of a shorcut, you can verify
  the accuracy of the formula for all cases. I repeat, I can
  vouch for the accuracy on round to square cases only. The
  formulas for the rectangular duct was derived using an equal
  area method using the area of the square duct equivalent of
  the round duct. I've not tested the conversion formulas and
  the accuracy might be questionable. Sorry for the confusion,
  as I was hoping that you'll be able to see through the formulas.
Water Bear
« Reply #24 on: February 08, 2004, 01:28:38 PM »
Don't get me wrong I fully appreciate your taking time out to assist in this puzzle...
Everyone has a different angle of attack for a given problem, which is why I come here.
Just for the record, I ended up using a combination of BOTH methods!
Thanx again.... :D
daron
« Reply #25 on: February 09, 2004, 09:52:59 AM »
I am not that good at math. Stig, is my algebra go to.
DEVITG
round to rectangle duct
« Reply #26 on: February 09, 2004, 05:58:52 PM »
After searching and asking a lot about it I got this answer from the EFUNDA.
I had post on the lily pond at this link , it is a xls file that allow to calc the b side given the diameter and the a side.
It explain it self and give the credit to ACRODUSTER1 , a fellowmember of EFUNDA .
http://theswamp.org/lilly.pond/devitg/red2rect.xls
efunda could be found at
http://www.efunda.com/forum/forum.cfm
SMadsen
« Reply #27 on: April 14, 2004, 03:14:27 PM »
Quote from: Daron
Daron, that kinda made me feel obliged to answer!  *GRRRRrrr*
But, I could only get as far as D^4/1.3^4 = (A^2.5 * B^2.5)/(A + B) ... soooo, I went to a math guy and he cracked it! Only took him a few month :)
Here's his formula written for AutoLISP:
(defun testit (s1 s2)
  (* 1.3 (/ (expt (* s1 s2) 0.625)(expt (+ s1 s2) 0.25)))
(defun C:EQDUCT (/ a b d di x1 x2 y)
  (setq di (getreal "\nEnter diameter of round duct: ")
        b (getreal "\nEnter side in rectangular duct: ")
  (setq d (/ (expt di 4.0) (expt 1.3 4.0)) ;;2.8561)
        y  (sqrt b)
        x1 (* (expt (/ (* 2 d) (* 5 (expt y 5.0))) (/ 1.0 3.0)) 2.0)
        x2 (- x1
              (/ (- (* (expt y 5.0) (expt x1 5.0))
                    (* d (expt x1 2.0))
                    (* d (expt y 2.0))
                 (- (* 5.0 (expt y 5.0) (expt x1 4.0))
                    (* 2.0 d x1)
  (setq a (expt x2 2.0))
  (mapcar 'princ (list "\nMissing side = "
                       (fix a)
                       "\nTest: Input diameter: " di
                       "\n      Calculated diam.: " (setq d (testit a b))
There is a built-in deviation of 4-5% but it can be controlled by putting it into a loop like (while (< (/ (abs (- x2 x1))(abs x2)) n) ... ) where n is the allowed accuracy.
