Here is the code I used to simulate a menu, like hendie mentioned ..
This code is for the labels ... you need to just follow the example here to make your own
Private Sub Label1_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
Dim Menu As clsPopupMenu
Dim MenuLine As Long
'identify the label we are hovering over
Label1.SpecialEffect = fmSpecialEffectSunken
'create our menu class reference
Set Menu = New clsPopupMenu
'send the info to the class item
'Note that the left of the control is 133% of the left position
'of the VBA form, plus the left position of the label and
'the top of the control is 133% of the top of the userform
'plus the height of the label, plus the top of the label
'plus the height of the top of the window caption bar
' 133% = 0.75 when doing division
MenuLine = Menu.NewMenu((UserForm2.Left + Label1.Left) / 0.75, _
(UserForm2.Top + Label1.Top + Label1.Height + 20) / 0.75, _
"File", "Edit", "-", "Close") 'This line contains your menu items, note "-" is a separator
'get the result from the user clicking the control
'the case numbers correspond to the location in the parameters sent to
'the NewMenu class. Remember, the first 2 elements are always
'the position to create our control (X and Y)
Select Case MenuLine
'Case 1 'Our X position, do nothing
'Case 2 'Our Y position, do nothing
Case 3 'File
'add "to do" code here
MsgBox "User Clicked File"
Case 4 'Edit
MsgBox "User Clicked Edit"
'Case 5 'A separator "-" so do nothing
Case 6 'Close
MsgBox "User Clicked Close"
End Select
'reset the label to normal
Label1.SpecialEffect = fmSpecialEffectFlat
Private Sub Label2_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
Label2.SpecialEffect = fmSpecialEffectSunken
MenuLine = Menu.NewMenu((UserForm2.Left + Label2.Left) / 0.75, _
(UserForm2.Top + Label2.Top + Label2.Height + 20) / 0.75, _
"File", "-", "Edit", "Close") 'This line contains your menu items
Case 3 'File
'Case 4 'A separator "-" so do nothing
Case 5 'Edit
Case 6 'Close
End Select
Label2.SpecialEffect = fmSpecialEffectFlat
Private Sub Label1_MouseMove(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
'present a scrolling effect when users move the mouse over
'the labels across the top of the form
'implement this in each label MouseMove event
Label1.SpecialEffect = fmSpecialEffectRaised
Private Sub Label2_MouseMove(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
Label2.SpecialEffect = fmSpecialEffectRaised
Private Sub UserForm_MouseMove(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
'reset all labels to flat when users move the mouse off
'of the label. To get a better result, make sure you have
'a minimum value of 1 for any label top and left position
This is the code for the class required for the popup menus -- you need to call the class module clsPopupMenu for it to work
Option Explicit
Private Const MF_ENABLED = &H0&
Private Const MF_SEPARATOR = &H800&
Private Const MF_STRING = &H0&
Private Const TPM_RIGHTBUTTON = &H2&
Private Const TPM_LEFTALIGN = &H0&
Private Const TPM_NONOTIFY = &H80&
Private Const TPM_RETURNCMD = &H100&
Private Declare Function CreatePopupMenu Lib "user32" () As Long
Private Declare Function AppendMenu Lib "user32" Alias "AppendMenuA" _
(ByVal hMenu As Long, _
ByVal wFlags As Long, _
ByVal wIDNewItem As Long, _
ByVal sCaption As String) As Long
Private Declare Function TrackPopupMenu Lib "user32" _
ByVal X As Long, _
ByVal Y As Long, _
ByVal nReserved As Long, _
ByVal hwnd As Long, _
nIgnored As Long) As Long
Private Declare Function DestroyMenu Lib "user32" (ByVal hMenu As Long) As Long
Private Declare Function GetForegroundWindow Lib "user32" () As Long
Public Function NewMenu(ParamArray Param()) As Long
Dim iMenu As Long
Dim hMenu As Long
Dim nMenus As Long
' create an empty popup menu
hMenu = CreatePopupMenu()
' determine # of strings in paramarray
nMenus = 1 + UBound(Param)
' put each string in the menu
' skipping the first 2 elements, those are the location for our menu
For iMenu = 3 To nMenus
If Trim$(CStr(Param(iMenu - 1))) = "-" Then
' the AppendMenu function has been superseeded by the InsertMenuItem
' function, but it is a bit easier to use.
' if the parameter is a single dash, a separator is drawn
AppendMenu hMenu, MF_SEPARATOR, iMenu, ""
Else
AppendMenu hMenu, MF_STRING + MF_ENABLED, iMenu, CStr(Param(iMenu - 1))
End If
Next iMenu
' show the menu at the current cursor location;
' the flags make the menu aligned to the right (!); enable the right button to select
' an item; prohibit the menu from sending messages and make it return the Index of the selected item.
' the TrackPopupMenu function returns when the user selected a menu item or cancelled
' the window handle used here may be any window handle from your Application
' the return value is the (1-based) index of the menu item or 0 in case of cancelling
iMenu = TrackPopupMenu(hMenu, TPM_RIGHTBUTTON + _
TPM_LEFTALIGN + _
TPM_NONOTIFY + _
TPM_RETURNCMD, _
Param(0), _
Param(1), _
0, _
GetForegroundWindow(), _
0)
' release and destroy the menu (for sanity)
DestroyMenu hMenu
' return the selected menu item's index
NewMenu = iMenu
End Function
