Author Topic: Fun : going Home ?  (Read 18031 times)
Fun : going Home ?
« on: December 14, 2005, 10:54:40 PM »
Just playing around ...
#region System using declarations
using System;
using System.Diagnostics;
using System.Collections;
using System.Text;
using System.Drawing;
using System.Reflection;
using System.Windows.Forms;
using System.ComponentModel;
using Microsoft.VisualBasic;
using System.Text.RegularExpressions;
#endregion
#region AutoCAD COM Interop using declarations
//// COM Interop References
//// AutoCAD 2006 Type Library
using Autodesk.AutoCAD.Interop;
//// AXDBLib AutoCAD/ObjectDBX Common 16.0 Type Library
using Autodesk.AutoCAD.Interop.Common;
#endregion
#region AutoCAD Managed Wrappers using declarations
//// Assembly acdbmgd .. ObjectDBX.NET Managed Wrapper
//// Assembly acmgd .. Autocad.NET Managed Wrapper
using Autodesk.AutoCAD.Colors;
#endregion
#region Alias using declarations
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
#endregion
// codehimbelonga kwb : posted@TheSwamp 20051215
[assembly: ExtensionApplication(typeof(ClassLibrary20051215.StartApp))]
[assembly: CommandClass(typeof(ClassLibrary20051215.Commands))]
namespace ClassLibrary20051215
    #region CommandClass
    public class
    Commands
        [CommandMethod("myHelp", CommandFlags.Modal)]
        static public void
        TEMPLATEHelp()
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("\n  Testing Assembly [kwb v:20051215]");
            ed.WriteMessage("\n  Commands : GoHome");
        [CommandMethod("GoHome", CommandFlags.Modal)]
        public static void Command_GoHome()
            Class1 tester = new Class1();
            tester.Method001();
    #endregion
    #region MainApp core
    public class Class1
        public void Method001()
            DateTime dt = DateTime.Now;
            bool yesnoResult;
            PromptStatus promptStatus = LibTools.TellmeYesNo(string.Format(
                "\nIt's only {0}, are you sure you want to quit ?", dt.ToString("HH:mm")),
                false, out yesnoResult);
            if ((promptStatus != PromptStatus.OK) || (yesnoResult == false))
                MessageBox.Show("\n.. Well get back to work, slacker .. !", "I'm the boss of you, OK !");
            else
                MessageBox.Show("\ngoodbye, slacker .. ");
    #endregion
    #region LibraryTools
    public class LibTools
        public static PromptStatus
        TellmeYesNo(string message, bool useYesDefault, out bool yesnoResult)
            yesnoResult = false;
            string defaultAnswer = (useYesDefault) ? "Yes" : "No";
            PromptKeywordOptions keywordOptions = new PromptKeywordOptions(message);
            keywordOptions.Keywords.Add("Yes");
            keywordOptions.Keywords.Add("No");
            keywordOptions.Keywords.Default = defaultAnswer;
            PromptResult keywordResult = ed.GetKeywords(keywordOptions);
            if (keywordResult.Status == PromptStatus.OK)
                if (keywordResult.StringResult == "Yes")
                    yesnoResult = true;
            return keywordResult.Status;
    #endregion
    #region Public class StartApp
    /// <summary>
    /// The entry point for AutoCAD.
    /// </summary>
    public class
    StartApp : IExtensionApplication
        public void
        Initialize()
            Commands.TEMPLATEHelp();
            ed.WriteMessage("\n  Type 'myHelp' at the Command Line for assistance ...");
        public void
        Terminate()
            // Does Nothing ... can't unload NET assembly ...
    #endregion
« Last Edit: December 15, 2005, 12:33:29 AM by Kerry Brown »
Re: Fun : going Home ?
« Reply #1 on: December 15, 2005, 12:06:57 AM »
heh, shouldn't they both say "...get back to work slacker!" :D
- John Carmack
- J.R.R. Tolkien
« Reply #2 on: December 15, 2005, 12:25:01 AM »
.. or :-
"Sure, you can go home. Grab a couple of beers from the frig' to take with you."
« Reply #3 on: December 15, 2005, 01:17:39 AM »
We could add this in for you Mick .. !
        public void Method002()
            bool yesnoResult;
            PromptStatus promptStatus = TellmePerhaps("\n Like a cold beer Mick ?",
                out yesnoResult);
            if ((promptStatus == PromptStatus.OK) && (yesnoResult == true))
                MessageBox.Show("\n.. Help Yourself to a couple .. !", "It's beer o'clock !");
            else
                MessageBox.Show("\n too bad, so sad .. ");
        TellmePerhaps(string message, out bool yesnoResult)
            string[] options = { "Yes", "No", "Perhaps", "noSir" , "BloodyOathMate" };
            PromptResult keywordResult = ed.GetKeywords(message, options);
                if ((keywordResult.StringResult == "Yes")
                    || (keywordResult.StringResult == "BloodyOathMate"))
                    yesnoResult = true;
added: corrected the option of providing beverages if ESC was hit :-)
« Last Edit: December 15, 2005, 01:44:05 AM by Kerry Brown »
« Reply #4 on: December 15, 2005, 01:45:08 AM »
heh, you have 4 too many key words now Kerry...... I s'pose you could set the 5th as the default  :laugh:
- John Carmack
- J.R.R. Tolkien
« Reply #5 on: December 15, 2005, 01:50:57 AM »
They should all be default YES , heh.
It's Difficult using a keyword list like this though, there are no PromptKeywordOptions as far as I can tell ; so no default CAN be set.
Options are :
GetKeywords
Autodesk.AutoCAD.EditorInput.PromptResult
GetKeywords(
   System.String message,
   System.String[] globalKeywords)
or
GetKeywords
GetKeywords(
   Autodesk.AutoCAD.EditorInput.PromptKeywordOptions options)
« Reply #6 on: December 15, 2005, 01:59:25 AM »
I'm just about to venture into keywords so this topic will come in handy.
Have you tried to handle an 'esc' from the user yet (in mid command that is), I've noticed using Prompts and ed.get##### etc. that when you escape it goes on to the next prompt instead of exiting the function. I haven't had time to explore this as yet but it's worth discussion when using/getting user input.
- John Carmack
- J.R.R. Tolkien
« Reply #7 on: December 15, 2005, 02:07:03 AM »
I've done a little with that.
Have a look at Lab 02 Reworked  http://www.theswamp.org/forum/index.php?topic=7904.msg100396#msg100396
There's a couple of getxxx options there.
case PromptStatus.Cancel:
« Reply #8 on: December 15, 2005, 02:29:19 AM »
While discussing Keywords ...
If ANYONE knows of a way to add Keywords from a list,
rather than one at a time in the PromptKeywordOptions Class,
I'd be happy to hear about it  :lol:
I've tried a few variations, but gave up.
eg: There must me a better way than this  .. I'd enjoy being corrected.
            keywordOptions.Keywords.Add("Perhaps");
            keywordOptions.Keywords.Add("Absolutely");
            keywordOptions.Keywords.Add("Never");
            keywordOptions.Keywords.Add("Sometimes");
« Reply #9 on: December 15, 2005, 02:41:09 AM »
.. cont ..
Seems to not compile if the Options are :-
and spit the dummy if a normal string ..  - --> System.ArgumentException: No bracketed keyword list
« Reply #10 on: December 15, 2005, 02:47:09 AM »
I just had another try ...
The answer may be in the Exception Message.
I wonder what this PromptOptions.SetMessageAndKeywords(String messageAndKeywords, String globalKeywords) is ? ?
Time to look at the Object Browser .. < tomorrow>
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ArgumentException: No bracketed keyword list
   at Autodesk.AutoCAD.EditorInput.PromptParser.Parse(String promptAndKeywords, String globalKeywords)
   at Autodesk.AutoCAD.EditorInput.PromptOptions.SetMessageAndKeywords(String messageAndKeywords, String globalKeywords)
   at Autodesk.AutoCAD.EditorInput.PromptKeywordOptions..ctor(String messageAndKeywords, String globalKeywords)
« Reply #11 on: December 15, 2005, 03:20:27 AM »
How about a 'for' loop
Just a sketch
for(int i = 0; i <= options.Length; i++)
      KeywordOptions.Keywords.Add(keywords;
- John Carmack
- J.R.R. Tolkien
« Reply #12 on: December 15, 2005, 03:27:16 AM »
I'm sure something like that would work Mick.
I'd just particularly like to know why the overloaded PromptKeywordOptions constructor is failing.
« Reply #13 on: December 15, 2005, 04:36:40 AM »
I've never tried but if it expected an array wouldn't the constructor be -
(string messageAndKeywords, string [] globalKeywords)
- John Carmack
- J.R.R. Tolkien
« Reply #14 on: December 15, 2005, 04:43:19 AM »
yes. !
It's declared as a string.
The error message mentions a 'bracketed keyword list'.
I'm guessing that it expects a 'special' formatting.
Thats the problem .. I'm guessing. !
