Author Topic: Add attributes one the fly  (Read 19396 times)
Re: Add attributes one the fly
« Reply #30 on: December 15, 2005, 06:01:56 PM »
Just in case anyone wants to know, this is the final code that I will be using.  Thanks again for all the help.
(defun VALUE (num ent /)
  (cdr (assoc num ent))
(defun c:AddExtraAtt (/ *error* CreatAtt ActDoc Sel EntData tmpEnt flag Sel2 InsPt Ht Rot Tag Str Just tmpOpt
                        Just72 Just73 tmpEntData entmakeList)
; Add attributes until you hit enter to an existing block, while keeping the original attributes.
; Tim Willey 12/2005
; Sub's 'CreateAtt 'value '*error*
; Thanks to Jeff Mishler and Kerry Brown at www.theswamp.org for their input.
(defun *error* (msg)
 (princ msg)
 (vla-EndUndoMark ActDoc)
 (if Sel
  (redraw (car Sel) 4)
(defun CreateAtt (Tag Str InsPt Just72 Just73 Ht Rot / )
(list
 (cons 0 "ATTRIB")
 (cons 100 "AcDbEntity")
 (cons 100 "AcDbText")
 (cons 100 "AcDbAttribute")
 (cons 1 Str)
 (cons 2 Tag)
 (cons 6 "ByBlock")
 (cons 8 "0")
 (cons 10 InsPt)
 (cons 11 InsPt)
 (cons 40 Ht)
 (cons 50 Rot)
 (cons 62 256)
 (cons 70 0)
 (cons 72 Just72)
 (cons 73 Just73)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vla-StartUndoMark ActDoc)
(while
  (if Sel
   T
   (setq Sel (entsel "\n Select block to add attribute to: "))
  (setq EntData (entget (car Sel)))
  (= (value 0 EntData) "INSERT")
  (not (redraw (car Sel) 3))
  (setq entmakeList
   (list
    (if (not (assoc 66 EntData))
     (append EntData (list (cons 66  1)))
     EntData
  (setq tmpEnt (car Sel))
    (entnext tmpent)
    (= (cdr (assoc 0 (entget (entnext tmpent)))) "ATTRIB")
   (while (/= (value 0 (entget (setq tmpEnt (entnext tmpEnt)))) "SEQEND")
    (setq entmakeList (cons (setq EntData (entget tmpEnt)) entmakeList))
   (setq flag T)
  (not (initget "Type"))
  (setq Sel2 (nentsel "\n Select existing attribute to match, or Type in attribute properties: "))
  (if (= Sel2 "Type")
    (setq InsPt (getpoint "\n Select insertion point: "))
    (setq Ht (getdist "\n Height of attribute: "))
    (setq Rot (getangle "\n Rotation of attribute: "))
    (/= (setq Tag (getstring T "\n Enter tag value: ")) "")
    (/= (setq Str (getstring T "\n Enter displayed value: ")) "")
    (not (initget "L C R M TL TC TR ML MC MR BL BC BR"))
    (setq Just
     (if (setq tmpOpt (getkword "\n Justification [<L>/C/R/M/TL/TC/TR/ML/MC/MR/BL/BC/BR]: "))
      tmpOpt
      "L"
     ((= Just "L")
      (setq Just72 0)
      (setq Just73 0)
     ((= Just "C")
      (setq Just72 1)
      (setq Just73 0)
     ((= Just "R")
      (setq Just72 2)
      (setq Just73 0)
     ((= Just "M")
      (setq Just72 4)
      (setq Just73 0)
     ((= Just "TL")
      (setq Just72 0)
      (setq Just73 3)
     ((= Just "TC")
      (setq Just72 1)
      (setq Just73 3)
     ((= Just "TR")
      (setq Just72 2)
      (setq Just73 3)
     ((= Just "ML")
      (setq Just72 0)
      (setq Just73 2)
     ((= Just "MC")
      (setq Just72 1)
     (setq Just73 2)
     ((= Just "MR")
      (setq Just72 2)
      (setq Just73 2)
     ((= Just "BL")
      (setq Just72 0)
      (setq Just73 1)
     ((= Just "BC")
      (setq Just72 1)
      (setq Just73 1)
     ((= Just "BR")
      (setq Just72 2)
      (setq Just73 1)
    (setq tmpEntData (entget (car Sel2)))
    (setq Just72 (value 72 tmpEntData))
    (setq Just73 (value 73 tmpEntData))
    (setq Ht (value 40 tmpEntData))
    (setq Rot (value 50 tmpEntData))
    (while
      (not (initget "Under"))
      (not (setq InsPt (getpoint "\n Select insertion point, or Under selected text: ")))
    (if (= InsPt "Under")
     (setq InsPt
      (polar
       (value
        (if (and (equal (value 72 tmpEntData) 0.0) (equal (value 73 tmpEntData) 0.0))
         10
         11
        tmpEntData
       (- Rot (DTR 90))
       (DefaultTextSpacing (value 7 tmpEntData) Ht)
 (setq entmakeList (cons (CreateAtt Tag Str InsPt Just72 Just73 Ht Rot) entmakeLIst))
 (mapcar 'entmake (reverse entmakeList))
 (if flag
  (entmake
   (list
    (cons 0 "SEQEND")
    (cons 8 (value 8 EntData))
  (entmake (setq EntData (entget tmpEnt)))
 (entdel (car Sel))
 (setq Sel (cons (entlast) Sel))
(if Sel
« Reply #31 on: January 08, 2010, 12:25:30 PM »
Just found out that in the later version of Acad that the order of dxf codes is important, so here is an update that works in '09.  I think I have done other improvements since the last posting of the code also.
    Just72 Just73 tmpEntData entmakeList Lay Wid LastAttTag tmpNum NewTagDft Num Sty)
        (princ msg)
        (if Sel
    (defun CreateAtt (Tag Str InsPt Just72 Just74 Ht Rot Sty Lay Wid / )
        (list
            (cons 0 "ATTRIB")
            (cons 8 Lay)
            (cons 6 "ByBlock")
            (cons 62 256)
            (cons 10 InsPt)
            (cons 40 Ht)
            (cons 1 Str)
            (cons 50 Rot)
            (cons 41 Wid)
            (cons 7 Sty)
            (cons 72 Just72)
            (cons 11 InsPt)
            (cons 2 Tag)
            (cons 70 0)
            (cons 74 Just74)
    (setq Num 1)
    (while
            (if Sel
                T
            (setq EntData (entget (car Sel) '("*")))
            (setq entmakeList
                (list
                        EntData
                    (entnext tmpent)
                    (setq LastAttTag (cdr (assoc 2 EntData)))
                            (wcmatch (strcase LastAttTag) "EXTRA LINE*")
                            (>= (setq tmpNum (atoi (substr LastAttTag 11))) Num)
                        (setq Num (1+ tmpNum))
                        T
                (setq flag T)
            (setq NewTagDft
                (strcat "EXTRA LINE"
                    (if (< Num 10)
                        (strcat "0" (itoa Num))
                        (itoa Num)
            (if (= Sel2 "Type")
                    (setq Just
                            tmpOpt
                            "L"
                        ((= Just "L")
                            (setq Just72 0)
                            (setq Just74 0)
                        ((= Just "C")
                            (setq Just72 1)
                            (setq Just74 0)
                        ((= Just "R")
                            (setq Just72 2)
                            (setq Just74 0)
                        ((= Just "M")
                            (setq Just72 4)
                            (setq Just74 0)
                        ((= Just "TL")
                            (setq Just72 0)
                            (setq Just74 3)
                        ((= Just "TC")
                            (setq Just72 1)
                            (setq Just74 3)
                        ((= Just "TR")
                            (setq Just72 2)
                            (setq Just74 3)
                        ((= Just "ML")
                            (setq Just72 0)
                            (setq Just74 2)
                        ((= Just "MC")
                            (setq Just72 1)
                            (setq Just74 2)
                        ((= Just "MR")
                            (setq Just72 2)
                            (setq Just74 2)
                        ((= Just "BL")
                            (setq Just72 0)
                            (setq Just74 1)
                        ((= Just "BC")
                            (setq Just72 1)
                            (setq Just74 1)
                        ((= Just "BR")
                            (setq Just72 2)
                            (setq Just74 1)
                    (setq Just74 (value 74 tmpEntData))
                    (setq Lay (value 8 tmpEntData))
                    (setq Wid (value 41 tmpEntData))
                    (setq Sty (value 7 tmpEntData))
                    (not (initget "Under Above"))
                    (setq InsPt
                            ((getpoint "\n Select insertion point, or [Under/Above] selected attribute <Under>: "))
                            (t "Under")
                    (if (not (equal (type InsPt) 'LIST))
                        (setq InsPt
                            (polar
                                (value
                                    (if (and (equal (value 72 tmpEntData) 0.0) (equal (value 74 tmpEntData) 0.0))
                                        10
                                        11
                                    tmpEntData
                                (rem
                                        Rot
                                            (* pi 1.5)
                                            (* pi 0.5)
                                    (* pi 2.)
                    (if (= (setq Tag (getstring T (strcat "\n Enter tag value <" NewTagDft ">: "))) "")
                        (setq Tag NewTagDft)
                        Tag
        (if (not Lay)
            (setq Lay "0")
        (if (not Wid)
            (setq Wid 1.0)
        (setq entmakeList (cons (CreateAtt Tag Str InsPt Just72 Just74 Ht Rot Sty Lay Wid) entmakeLIst))
        (if flag
            (entmake
                (list
                    (cons 0 "SEQEND")
        (entdel (car Sel))
    (if Sel
« Reply #32 on: March 23, 2011, 04:48:46 PM »
I messed up when letting the user enter information, so here is an updated version.
        (princ msg)
        (if Sel
        (list
            (cons 0 "ATTRIB")
            (cons 8 Lay)
            (cons 6 "ByBlock")
            (cons 62 256)
            (cons 10 InsPt)
            (cons 40 Ht)
            (cons 1 Str)
            (cons 50 Rot)
            (cons 41 Wid)
            (cons 7 Sty)
            (cons 72 Just72)
            (cons 11 InsPt)
            (cons 2 Tag)
            (cons 70 0)
            (cons 74 Just74)
    (setq Num 1)
    (while
            (if Sel
                T
            (setq entmakeList
                (list
                        EntData
                    (entnext tmpent)
                        T
                (setq flag T)
            (setq NewTagDft
                    (if (< Num 10)
                        (itoa Num)
            (if (= Sel2 "Type")
                    (setq Just
                            tmpOpt
                            "L"
                        ((= Just "L")
                            (setq Just72 0)
                            (setq Just74 0)
                        ((= Just "C")
                            (setq Just72 1)
                            (setq Just74 0)
                        ((= Just "R")
                            (setq Just72 2)
                            (setq Just74 0)
                        ((= Just "M")
                            (setq Just72 4)
                            (setq Just74 0)
                        ((= Just "TL")
                            (setq Just72 0)
                            (setq Just74 3)
                        ((= Just "TC")
                            (setq Just72 1)
                            (setq Just74 3)
                        ((= Just "TR")
                            (setq Just72 2)
                            (setq Just74 3)
                        ((= Just "ML")
                            (setq Just72 0)
                            (setq Just74 2)
                        ((= Just "MC")
                            (setq Just72 1)
                            (setq Just74 2)
                        ((= Just "MR")
                            (setq Just72 2)
                            (setq Just74 2)
                        ((= Just "BL")
                            (setq Just72 0)
                            (setq Just74 1)
                        ((= Just "BC")
                            (setq Just72 1)
                            (setq Just74 1)
                        ((= Just "BR")
                            (setq Just72 2)
                            (setq Just74 1)
                    (setq Sty (getvar 'TextStyle))
                    (setq InsPt
                            (t "Under")
                        (setq InsPt
                            (polar
                                (value
                                        10
                                        11
                                    tmpEntData
                                (rem
                                        Rot
                                            (* pi 1.5)
                                            (* pi 0.5)
                                    (* pi 2.)
                        Tag
        (if (not Lay)
            (setq Lay "0")
        (if (not Wid)
            (setq Wid 1.0)
        (if flag
            (entmake
                (list
                    (cons 0 "SEQEND")
        (entdel (car Sel))
    (if Sel
chlh_jd
« Reply #33 on: March 24, 2011, 05:30:05 AM »
so Great , T.Willey
In my ACAD2004 version , it can add the atts, however , the block can't used in command "_refedit" .
« Reply #34 on: March 24, 2011, 10:06:49 AM »
I never use ' refedit ', so wouldn't have found that out.  I think the issue would be that the block definition and the insert are not exactly the same anymore, so the command doesn't know what to do.
Hugo
« Reply #35 on: January 30, 2012, 03:49:11 AM »
Hallo
Get this message
Another question to
Because I can immediately select multiple blocks, or just one more.
Thank you
Have brought the Lisp and running, but if I use one ATTSYN disappears again the ATT.
why   :-( :-( :-(
Befehl:
ADDEXTRAATT
 Enter tag value <EXTRA LINE01>: Dober
 Enter displayed value: Dober
; Fehler:  Ausnahmebedingung aufgetreten: 0xC0000005 (Zugriffsverletzung)
; Warnung: Unwind übersprungen bei Ausnahmebedingung
Bekomme diese Meldung
Noch eine Frage dazu
Kann ich da gleich mehrere Blöcke auswählen, oder nur immer einen.
Hab das Lisp zum laufen gebracht, aber wenn ich ein ATTSYN verwende verschwindet das ATT wieder.
Wieso
Danke
« Last Edit: February 01, 2012, 10:04:56 AM by Hugo »
