Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
list to string
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: list to string (Read 1956 times)
whdjr
Guest
list to string
on:
December 09, 2005, 01:19:39 PM »
Brain Fart goin on here!
I have a list of lists that I want to write out each list to line in a text file.
How do I turn a list into a string?
Logged
whdjr
Guest
Re: list to string
Reply #1 on:
December 09, 2005, 01:24:10 PM »
vl-princ-to-string
Thanks guys I knew I could count on ya'll.
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: list to string
Reply #2 on:
December 09, 2005, 04:42:59 PM »
Hi Will, they make pills for that these days.
Logged
whdjr
Guest
Re: list to string
Reply #3 on:
December 09, 2005, 05:36:51 PM »
Are those Domestic here or just Down Under?
Logged
David Bethel
Swamp Rat
WWW
Re: list to string
Reply #4 on:
December 10, 2005, 08:17:27 AM »
(prin1) will work as well. You just need to send a newline command as well. -David
Logged
R12 Dos - A2K
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
list to string
